Page 49 of 50 FirstFirst ... 39 45 46 47 48 49 50 LastLast
Results 1,201 to 1,225 of 1248
  1. #1201
    I just reinstalled and remeasured everything on a super flat surface, without the offset bushing I had a BB height of 13 5/8". With the offset bushing I have a BB height of 13 1/2". So it seems 1/8" drop per bushing, so total you could get 1/4". 10mm drop seems pretty optimistic?
    Quote Originally Posted by liketoride View Post
    I deflated my shock until it sagged as close to 3.6mm as possible and that produced visibly different results in the BB height and HT angle- just under a degree in HT angle and ~10mm BB drop. Thank you for the information. I'll probably get a set.
  2. #1202
    Big Gulps, Alright!
    Reputation: Berkley's Avatar
    I use this imperfect method of calculating BB drop: Using two reducers of 1.8mm offset shortens your eye to eye measurement by 3.6mm. Multiply that by the frame's overall leverage ratio (2.2:1) and the geometry change would the the same as compressing the suspension by 8mm.
    Axle Standards Explained
    Founder at North Atlantic Dirt, riding & writing about trails in the northeast.
  3. #1203
    Jun 2013
    Anybody running a 650b fork on their BLT? Looking at some forks locally and figured it might be worthwhile to entertain this option... I can't seem to find the crown to axle measurements on the FOX forks, but I assume it would be a bit longer, may need to shim the fork travel down 10mm. Any other disadvantages? Figured this would be a good option to future proof the ride (if I decide to go 650b now or later)..
  4. #1204
    Reputation: smmokan's Avatar
    Yep, I am... here's a picture of my Blur from a few weeks ago. I just put new tires on it with a Trail Taker 2.4" on the front and an Ardent EVO 2.25" on the rear, and it's great. I haven't ever had an issue with the fork or shock bottoming out, so no shimming necessary in my case. I have a Fox Float 32 150 FIT RLC on the front.
  5. #1205
    So for those of you with the offset bushings...what is the verdict on the hta change? Does the st angle adversely effect climbing/comfort? Im not as concerned in the bb drop, but a little might b nice.
  6. #1206
    Dec 2010
    Santa Cruz Blur LT 2.2 Harbor Grey
    It is a used frame that comes from Florida USA to Mexico City... around 28.6 lbs final build
  7. #1207
    Apr 2005
    Curious about the aluminum LT2s - From the latest VPLS sales, I've seen two different stickers on the LT2.2s (aluminum, 135qr rear, tapered headtube) - one is the diagonal print, the other straight...
    Anyone else notice this?
  8. #1208
    007
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by larsbaby View Post
    Sticker guy came to work drunk one day . . . .
  9. #1209
    Reputation: ciocc's Avatar
    Dec 2005
    Cool-blue Rhythm Let's keep this thread going ...
    Have ridden this twice only, still trying to dial in.
    Blur LTa 2.3 Medium
    Lyrik U Turn 115-160mm Soft Spring
    Marzocchi TST R Coil 350lb
    Renthal Fatbar Lite + Duo stem
    Hope Pro2 Evo + Stan's Flow EX
    Schwalbe Han Dampf 2.35F / Bontrager XR4 2.2R
    Formula R1/X 180F 160R
    SRAM X9/X7
    MRP 2x Chain Guard
    Blackspire Sub 4 Pedals
    KS Dropzone
    WTB Speed V Saddle
    Weight: 34lb
  10. #1210
    7am Backcountry ;- )
    Reputation: capoz77's Avatar
    Quote Originally Posted by ciocc View Post
    Blur LTa 2.3 Medium
    Marzocchi TST R Coil 300lb
    Renthal Fatbar Lite + Dual stem
    Schwalbe Han Damf 2.35F / Bontrager XR4 2.2R
    SRAM X9/X7
    MRP 2x Chain Guard
    KS Dropzone
    WTB Speed V Saddle
    Weight: 34lb
    How do you find the Hans Damf tyres Ciocc? Great setup you have there! I'm looking at going tubeless and comparing nobby nics and hans damf.
    [SIZE="1"][SIZE="2"]i can't ride for sh*t but i'm good at extreme pushing[/SIZE][/SIZE]
  11. #1211
    Wasnt the sales only the LT2.3? 142 bolt through rear axle? I'll put some pics up of mine in a second.
  12. #1212
    Blur LT2.3 alu in harbour grey, upgrade from the Heckler...
    X9 and XT, Rockshox Pike Coil 426, Truvativ bars, steam + seatpost. Formula Oro Bianco brakes on 180mm.
    As time goes on i'll replace some of this stuff with lighter components. Weighs in @ 31 lbs
    Really happy with the ride quality! I'm going to cut the steerer down too once i've tried it at various heights.
  13. #1213
    007
    007 is offline
    b a n n e d
    Jun 2005
    Quote Originally Posted by capoz77 View Post
    I ran an HD front and NN rear combo for a while and it was superb. I ride exclusively dry, loose over hard terrain and started getting really familiar with the pair. The HD grips like high-end escort while the NN "holds on" like cheap hooker. I came to appreciate the NN, as the breaking point was very predictable and I was really starting to enjoy throwing the bike around. The downside is that I got less then 200 miles out of the NN before it basically disintegrated. I've heard of guys getting only a single day out of a Schwalbe tire out in Moab, and for that reason I'll never run a Schwalbe as a rear tire again.
    That same HD has a few hundred miles on it and is still running great, with plenty of tread. One thing is clear though . . . there is ZERO possibility that I'd ever run a NN as a front tire. None.
    An alternative which I am likely to try, is to run the HD front with a Specialized Ground Control in the read. Same tread design as the NN, with a firmer compound.
  14. #1214
    Dec 2005
    The HD I have is the gravity version, so it's a bit heavier than the regular Trailstar version. It tracks very well and the sidewall is pretty tough. I have no problem running it at 24psi. I would NEVER run a NN in the front again, at least not the 2.25. I had a UST version and even with low psi it wasn't in the same ballpark as the HD in terms of traction.
    I've also run the NN in the rear before. I thought it was ok. It has pretty good traction, but the sidewall is a little bit weak for a UST tire. A number of times I felt that it wanted to roll off the rim when landing from a few feet high. I'm running a Bontrager XR4 now (older version) and I like it a lot.
    I still run the HD/NN combo on my trail bike and I think it is a decent setup for So Cal's loose/hard pack terrains.
    When the tires wear out, however, I will try HD trailstar (non gravity) + XR4 (new version) combo.
  15. #1215
    Dec 2005
    Quote Originally Posted by 007 View Post
    Same here.
  16. #1216
    I had a 2008 Lapierre Zesty 514 that served me well, but after 5 years of hard riding it had several dents in the frame, one of which appeared to be developing some stress cracks. After days of scouring the 'net, I found a 2nd hand Blur LT frame that I bought for a reasonable price. As it turns out, it's nearly new and as a result, I have a beautiful new (for me) Blur LT. It has a QR back-end and a straight steerer tube and while that's not optimal relative to current standards, it did allow a straight swap of parts from the Zesty onto the Blur. Not that I did that - I purchased a new fork to complement the frame of course. It's hard to find a fork with a straight steerer these days!
    The forecast was looking good after several days (weeks?) of rain so I set out yesterday morning with my newly built Blur. I did a familiar loop that includes some flowy mountain singletrack and a couple of horrowshow, rocky descents, one of which was currently serving as a riverbed. My initial impressions, which might be biased by my wanting to like this bike, is that I like this bike. I really like this bike.
    Compared to the Zesty, it feels like it climbs better. That is, the rear wheel stays stuck to the ground more and there is visibly less pedal bob. It also feels like a better descender but I can't discount the effect of the new fork. I was blasting through the rock gardens and the bike felt stable and reassuring. It felt like I could roll over anything and I went looking for harder lines than I might otherwise. The Blur is more nimble than the Zesty, it's easier to manual (shorter chain stays?) and it feels lighter although I didn't think that the Zesty was more than 13.5 kg. I hate to use this word but I am stoked!
    I was planning on buying a Solo or Bronson in 2014 but I am so pleased with the Blur that I think that the new bike purchase may be delayed by a year or two.
    Frame: 2010 Blur LT, Medium, black anodized
    Fork: Rockshox Revelation RLT 150mm
    Shock: Fox Float RP23
    Drivetrain: 2x9 Shimano SLX, Saint shifters, PG990 cassette, Saint 22/36 double and bash cranks
    Wheelset: Shimano XT M775 wheelset
    Tires: Hans Dampf 2.3 f/r
    Brakes: Formula RX, 180mm SLX CL rotors
    Seatpost: Rockshox Reverb
    Saddle: Charge Scoop
    Stem: 70mm Raceface Atlas
    Bars: 725mm Raceface Atlas
    Grips: ODI Ruffian
    Pedals: Blackspire Sub4
    Weight: 13.6 kg / 30 lbs
  17. #1217
    Reputation: weasy's Avatar
    Lets see those LT2s-dsc_0984_small.jpgLets see those LT2s-dsc_0986_small.jpg
    Here is my 2010 BLT that I just 650b'ed. Will take it back out for it's maiden voyage as 650b and can't wait.
  18. #1218
    Reputation: gexas's Avatar
    i'll be interested to hear back if it works as a well as a bike that was designed from the factory as a 650 b. I think it would perform just as well as say a bronson.
    E
  19. #1219
    Most people say the bike gets too wobbly due to the high BB, but i'm always interested in hearing another review!
  20. #1220
    Apr 2005
    Nothing says christmas eve in texas like a ride on the greenbelt:
    Austin Mountain Biking and worldwide travel pictures:
    http://www.austinbike.com
  21. #1221
    007
    007 is offline
    b a n n e d
    Jun 2005
    I'm glad to see people still rollin' on the LT2. I'm still loving mine . . .
  22. #1222
    Apr 2005
    Yep, still running well after 2+ years of abuse. Even on Christmas morning. Lets see those LT2s-image.jpg
  23. #1223
    Dec 2005
    Cleaned up the cables and shortened the steerer tube. Converted to 1x10 with a Wolf Tooth direct mount 28T. Still waiting for the 42T OneUp cog to show up.
  24. #1224
    here's one i built for a friend of mine a few weeks ago.
    12.3 kg
    Pike SA 150, X0, Superstar AM Carbon wheels, Renthal stem/bar, Lev150, Conti MK tubless, sugarless angleset -1.5
  25. #1225
    Apr 2005
    28T with a 42 in the back? Wow. I am running a 30T with a 36 in the back and thinking about going to a 32T because in the 36 I can't get enough torque. What kind of hills are you riding that on?
