Page 36 of 50 FirstFirst ... 26 32 33 34 35 36 37 38 39 40 46 ... LastLast
Results 876 to 900 of 1248
  1. #876
    Now I see why you wanted the 36!!! I would too if I got to ride that all the time!
  2. #877
    Nov 2007
    So I just got my medium anodized skidmark frame from UPS. From reading the older posts, it seems like at one point the frames came with the BB and head tube already faced? The frame I got still got paint on both the BB and the head tube so I guess they've stopped doing that? Question is, should I go and get the BB and the head tube faced since I'm probably going to take it to the shop to get the bearing cups pressed in anyway.
  3. #878
    Facing BB and head tube
    Quote Originally Posted by pwu_1
    Yes, everything will line up correctly after being done. This is particularly important for your bottom bracket.
  4. #879
    007
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    How can you tell if a frame has been faced after assembly? (noob question!)
  5. #880
    Nov 2007
    Quote Originally Posted by OO7
    I don't think you can. With the headset, you probably won't be able to tell unless you remove the bearing cups. With the Bottom bracket you will need to remove the bearing to tell.
    I just called a local bike shop and the guy I talked to said that generally speaking, the newer frames are good enough quality that they don't bother facing the head tube or BB if external bearings are being used. Interesting. Should I listen to their advice or take my frame some where else? They charge $40 to install the headset. It'll cost extra if I wanted to get the headtube faced.
  6. #881
    I would always have a bottom bracket shell faced on a new frame. Especially if using a hollowtech bottom bracket style setup.
  7. #882
    Reputation: wilsonblur's Avatar
    I just got mine 10 days ago and have 6 rides in on it. I love it. I had an Intense 5.5 that I really tried to like, but its nowhere as good as this bike. This is one of those great Chainlove buys.
    Build is as follows:
    Formula K24 Oro's
    DT swiss 240/Mavic 717
    Schwalbe Nobby Nic 2.4's or Albert 2.25 depending on where I am riding
    Stan's NoTubes
    Race Face Dues BB and Cranks
    Candy Pedals
    Salsa Stiff Upper Lip 80mm stem
    King hdst + a 5mm base plate spacer to slacken the head angle
    Flite Gel Saddle
    Easton Post
    Carbon bar
    Talas 140
    SRAM Rocket 9spd shifters
    XT shadow derailleurs
    Narrow is the path to life, few are those who find it.
  8. #883
    Reputation: oakhills's Avatar
    clear over raw finish
    I know, crappy snap.....
    But the Blur LT in the flesh????
  9. #884
    Reputation: kdiff's Avatar
    Quote Originally Posted by Katana
    Looks good. Anyway we could get a better picture?
  10. #885
    007
    007 is offline
    b a n n e d
    Jun 2005
    Man, WTF?!? Where the heck is MY raw frame?! I was told LAST weekend while out of town that SC shipped it and it would be waiting when I got back. STILL no word!
    Well, at least now I know what mine will look like (and it looks great!)
  11. #886
    Are they shipping the new frames with the tapered head tubes ?
    I am waiting for one to be shipped to NZ
  12. #887
    Reputation: weasy's Avatar
    Here is my Chainlove deal....
    Exactly 26 lbs.
    2009 Float R 140 and yeah that is an old 752 crank (had it in box for 5 years).
    Mostly XT with XTR RD
    Elixir CR brakes.
    Pure BWW rear wheel, custom Mike Garcia oddsandendos front wheel.
    Taking her out for christening on local trails tomorrow... Came from an '03 Superlight. We will see how the extra travel and new technology measures up.
  13. #888
    Nov 2007
    Just finished putting this together. 27.6 pounds total weight
    RockShox Revelation Team U-Turn 120-150mm fork
    Easton Monkeylite XC high-rise
    Truvativ AKA 70mm stem
    Magura Louise BAT brakes 180 front/160 rear
    XT Crankset with big ring replaced with bashguard
    XTR everything else.
    Mavic Crossmax ST wheels
    Specialized the Captain Armadillo tubeless
  14. #889
    [B]
    ^^^^ New photos ^^^^
    Frame - 2010 Santa Cruz Blur LT - Anodized Black (XL)
    Rear shock - Fox RP23
    Front shock/fork - Fox TALAS FIT 32mm (110/130/150)
    Handlebars - Easton EA70 MonkeyBar 685mm Lo Riser
    Stem - RaceFace Deus XC (100mm)
    Headset - RaceFace Deus
    Grips - ODI Rogue
    Saddle - Fizik Gobi XM K:Ium
    Seatpost - Crank Brothers Joplin 4 Remote
    Front brake - Elixir R w/ Straitline lever
    Rear brake - Elixir R w/ Straitline lever
    Cranks - SLX
    Chainguide - N/A
    Chain - SRAM PC951
    Pedals - Shimano M540
    Front derailleur - XT
    Rear derailleur - X9
    Front shifter - X9
    Rear shifter - X9
    Cassette - SRAM PG 980
    Front hub - XT
    Rear hub - XT
    Front rim - XT (tubeless)
    Rear rim - XT (tubeless)
    Spokes - No idea
    Nipples - No idea
    Tyres - Maxxis Ardent 2.2" (Tubeless)
    Tubes - N/A
  15. #890
    How do you find the Straitline levers Maxwolfie ?
    They make much of a difference or was it more of a bling factor thing ?
    Nice bike btw
  16. #891
    Definately make a big difference. I come from a bit of a DH background, where I got used to the levers. I don't think I could go back now, they make an incredible amount of difference in terms of having confidence in only your index fingers - They don't move around at all.
  17. #892
    is there a reason why you have the crank brothers post back to front?
  18. #893
    Yeah, it's fixed now
  19. #894
    Skidmark
    The anodized Skidmark color seems to change colors in different lighting. I took this picture on the summit of yesterday's ride.
  20. #895
    Nov 2006
    My BLT 2 ....
    Frame is 2 years old - everything else (besides cranx and stem) recently upgraded....
  21. #896
    Lt2
    my blur with lizard
  22. #897
    Lt2
    sori, unable to upload the photos
  23. #898
    Finally added some custom wheels and a new fork!!
    Wheels;
    Spank Subrosa Evolutions (Gold)
    Hadley Hubs (Blue front / Gold rear)
    DT Swiss Comp. Spokes with Blue/Gold alt nipples
    Fork;
    2011 Fox Van FiT RC2 Kashima (160mm)
  24. #899
    Quote Originally Posted by kdiff
    Just finished building my LT2 last Saturday. Took it out for two ride two rides on Sunday. I was originally going to buy an Intense or a Scott but bought this on Chainlove when it popped up a few weeks ago. I think I'm becoming a Santa Cruz fan because I'm loving this bike, if only it was made in the USA (though it wouldn't have been this cheap).
    http://www.hkdphoto.com/personal_pho...e/IMG_2770.jpg
    I ordered the same frame in Skidmark color this week and should be getting it early next week. Originally I was not very interested on the color, but after seeing this very balanced color scheme on your bike I fell for it.
    What color is the headset on the frame? I assume it is this Brown CK:
    Am I right?
  25. #900
    Yeah it's the brown CK. I also have CK brown hubs. I think the whole thing looks good. Originally wasn't crazy about the skidmark color but the price was right. After the frame arrived I fell in love with the color seeing it in person!
