    KS LEV for Nomad
    I have a Nomad size medium and I'm looking at getting the KS Lev dropper post. I know I need a 30.9mm diameter post. Am I correct that I should get the model with 150mm drop so the post drops all the way down? Thanks!
    k_z
    k_z is offline
    Been through this on Blur LTc - look at this thread : KS LEV Dropper post sizing for LTc
    I wanted to be able to fit mine so when it's fully extended, seat is at the "climbing" height so you need to measure the distance to the frame collar from where your seat is right now (assuming this is maximum height you want) and see if 150 mm will fit. You also need to look at min insertion and whether the part of the post that is in the frame is not going to be too long to fit it in - if Noman has anythin in the tube restricting insertion depth.
    Reputation: TwoHeadsBrewing's Avatar
    1. Set your saddle height at the highest you'd use for riding.
    2. Measure from seatpost collar to saddle rails.
    3. Use guide below to figure out what travel you should get. (F + B + I), where B is the amount of post travel.
    "Got everything you need?"
    Thanks for the good info!
  1. Do-it-all Nomad
    By aceospades1250 in forum Santa Cruz
    Last Post: 06-16-2012, 12:25 PM
  2. Nomad ?
    By Cycle64 in forum Santa Cruz
    Last Post: 06-29-2011, 08:19 AM
  3. Trade your VPP2 Sm Nomad for my VPP2 M Nomad
    By wilsonblur in forum Santa Cruz
    Last Post: 06-27-2011, 11:14 AM
  4. Changing my AM Nomad to DH Nomad
    By stunzeed in forum Santa Cruz
    Last Post: 04-09-2011, 06:15 PM
