    Oct 2007
    Info rqd on dhx spring rate on 05 bullit ?
    just got a new shock for my 05 bullit, a dhx4 and am trying to workout the best spring rate for a 200lb rider ?
    dont want waste money on one that wont suit !
    ive only the 5th ti 375 spring to try and its giving me 26 mm sag which i think is too much.
    according to the fox guide it should be 16/17mm
    i was thinking 500 or 550 spring would do.
    anyone any pointers ?
    cheers D
    Reputation: Toasted BLT's Avatar
    TFTuned Spring Calculator
    A call to Fox or the SC site if your looking for recommendations:
    http://www.santacruzmtb.com/bullit/index.php?setup=1
    If you want to dig a little deeper, check out the TFTuned spring calculator. It does a pretty good job and give you some insight into the trades.
    http://www.tftunedshox.com/tech-area...alculator.html
    Reputation: geinsteder's Avatar
    I have an 08 bullit, not sure if the year makes a big diff. Im 200lb geared up and use a 550lb spring. Go straight to Fox for the correct spring. I looked and asked all over. Fox will give you the correct answer the first time.
    good luck
    Oct 2007
    tried 550lbwhich felt a bit too stiff compared tothe fifth, running a 450lb which seems good only had a short run so id give it a while if not 500 wil be nxt
    cheers for the info
    D
