Results 1 to 3 of 3
    Jan 2005
    Heckler Front Mech
    I need a front mech for my 2004 Heckler.
    I quite fancied going for the SRAM X-Generation Front Mech to match the rest of the SRAM system I have.
    But, I've read that the SRAM X-Generation front mech is too bulky for mounting on the Heckler, in that there is insufficient clearance between the seat tube and the swing arm.
    Can anyone confirm this?
    If I can't go with the SRAM unit what front mech would you recommend?
    Thaks in advance...
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    The sram will not work. The clamp is up too high. After trashing an xt and an xtr I threw on a deore and it worked just as well as the higher end fr ders. That said, none of them worked well in my opinion and I ended up climbing everything in my middle ring anyway. So, I dropped the front derailleur all together. If dudes on singlespeeds can climb like banshees with one gear, you can do it with nine.
    I am immune to your disdain.
    Jan 2005
    Actually, given that my other bike is a SS, that was my first thought...sod the front mech, replace the outer ring with a bash ring and hey presto
    Thanks for the reply.
