Results 1 to 6 of 6
    May 2005
    Heckler with a Float R
    Ive just got a 2006 pro-pedal Fox Float r rear shock for my Heckler, how does it ride with this? Ive got a Swinger 4-way coil fitted at the moment but am wanting to fit the float for XC epics to lighten her up a bit.
    Got A Lust for Life...
    Reputation: indyfab25's Avatar
    I would send it right in to PUSH. Have them valve it for your weight and add the piston.
    I am immune to your disdain.
    What are you looking at?
    Reputation: R1D3R's Avatar
    Jun 2005
    I had the 05 float R and I hated it... it bottomed out if I gave it a bounce... not the best AM FR shock... I have an 05 swinger 4-way air and it's much better... but it will work well if your an XC rider...
    Orange Heckler
    Blue Pinscher
    The Float R give a little harsh ride on the Heckler. I have tried it, and after that a DHX Air on the same bike and the DHX seemed a lot plusher.
    For these reasons...I think the 150 bucks you would pay to PUSH would be worth every penny.
    29er wannabe
    Reputation: yagimax's Avatar
    Mar 2005
    Fox float r
    Choosing the right rear shock is dependant on many variables.
    Just dial in the correct air pressure on the float R and get out and have fun !
    I'm using the RP3 on my Heckler and it suits me just fine.
    The float r is is similar to the rp3 in it's mid propedal setting.
    Your probably saving a full pound in the switch from the coil.
    If you are turning into a weight weenie I say go for it.
    Gary
