Results 1 to 6 of 6
    Apr 2013
    Headset for Blur XC w/ 1-1/8" steerer
    I just got the Blur XC Carbon frame (excited!) and want to put my 1-year old 32 Float 100 FIT RLC on it. It has a 1 1/8" steerer.
    My understanding is that there is a some sort of headset adapter that I can use for the fork
    According to the SC website:
    "The Blur XC uses a tapered headtube often called "mixed taper". This setup uses a standard 1.5" external lower cup (49mm bore) and an internal 1 1/8" upper cup (44mm bore). Almost all headset manufacturers make this product."
    I'm wondering what I'd need to do to fit this for to the Blur -- is there a additional headset/crown race combo that would fit into the mixed taper headset they're talking about?
    Fork specs are here, btw: FOX Racing Shox 2012 / 32 FLOAT 100 FIT RLC
    Reputation: robsetsfire's Avatar
    You'll be getting a new headset, not an adapter. You have an option to run a lower zero stack (ZS) or a traditional external cup style (EC) lower headset cup. Here is what you want:
    Top Headset:
    SHIS:ZS44 - 1-1/8" ZeroStack (ZS) Threadless
    Bottom Headset:
    SHIS:EC49/30 - 1.5" Traditional to 1-1/8" Conversion
    -or-
    SHIS:ZS49/30 - 1.5" Traditional to 1-1/8" Conversion
    (This assumes you meant that your fork was a non-tapered 1-18".)
    I was a King fan for years, but I'm sold on Cane Creek's stuff now. I'd check them out, but this is a normal style headset now, many places will make them. If you don't want to pay for a 110, the 40 headsets are great too.
    Apr 2013
    Perfect. Thanks for the clarification. I've also heard only good things about CC, but have so far only used their crown race (no problem, as you'd expect) on a different bike.
    Yes, fork is non-tapered 1-1/8"
    It seems like the two bottom assemblies would give you just a slightly different geometry, or is there a functional/quality difference otherwise?
    With these bottom headsets, is it safe to assume that the crown race is the same as what I was using before, which I assume was a standard (what was shipped w/the fork) 1 1/8" crown race diameter?
    Quote Originally Posted by countgrover View Post
    Just geometry... ZS = steeper, EC = slacker... depending on what you want. The stack heights are 4mm vs 12mm.
    May 2010
    I'm running a cane creek on my Santa Cruz I just built and I am super happy. I have non tapered tube so I picked up a Cane Creek S-8 headset. Fully sealed angular bearings!
    Apr 2013
    Thanks everyone. Just ordered 'em (EC).
  1. Correct headset for 1.5" straight to 1 1/8" straight steerer?
    By Muffinhead in forum Beginner's Corner
    Last Post: 09-10-2012, 03:58 PM
  2. 44mm headtube and a 1.5" non-tapered steerer, headset?
    By haymitch in forum General Discussion
    Last Post: 07-26-2012, 01:30 PM
  3. 1⅛" Steerer Tube in a 1" Tapered Headset.
    By Ronnie in forum Shocks and Suspension
    Last Post: 01-03-2012, 12:54 PM
  4. steerer tube extension options for 1.5" steerer
    By bigfoot_mt in forum General Discussion
    Last Post: 12-10-2011, 04:58 PM
  5. Blur LTC, Angleset & 1.5" tapered steerer?
    By -C- in forum Santa Cruz
    Last Post: 06-02-2011, 04:23 AM
