Results 1 to 1 of 1
    zon
    zon is offline
    Scofflaw Mountain Biker
    Reputation: zon's Avatar
    Going from gen 2 to gen 3
    I am getting a crash replacement for my 2014 Tallboy and it will be a 2017 Tallboy C. Unfortunately it doesn't look like much from my '14 can be used on the '17.
    What I have identified so far is the rear shock, front der, rear wheel, seatpost, and possibly crank need to be updated. The biggest thing is the "Boost" issue with the rear wheel. I will either have to get an adapter for my Haven wheel to go 148x12 or a new wheel.
    Not sure if I need a new crank as well, (add 3mm spacer to drive side?). I run 2x10 and hope to keep it that way to save $$.
    And finally, what size is the seat post clamp diameter?
    Any input on what can be swapped over and what needs to be replaced?
    ΜΟΛΩΝ-ΛΑΒΕ
