Results 1 to 7 of 7
    Uncut
    Apr 2013
    New question here. Finding the right tight for my links. BLUR LT2
    I have a Blur LT2 and recently took apart all the linkages (minus bearing removal) so that I could get a bunch of grime out. All the parts/bearings are good.
    Now re-installing and am wondering how tight my pivots should be? When I leave them loose enough for the rear triangle to fall free w/ gravity, the linkages have play. When I tighten them up, the rear triangle still moves nicely, but not free fall. It will actually move easily when I move it, but it tends to want to hold the position I leave it in. Also, when using the grease ports post factory setup, grease would bulge out and I would know the pivots were full. When the lower linkage is tightened to no play, when I grease the port the gun soon locks up, grease is pressurizing inside the pivot body because it cannot escape (which is also tightening up the motion of the pivot). I figured Id adjust the axle torque such that grease could bulge out, but that left the linkage loose.
    So what Im trying to find out is if, when fully installed, the rear triangle ought to be moving as free as the bearings spin, or should it have (or is it ok to have) a little bit of resistance on it?
    May 2010
    Go to Santa Cruz website under maintenance it will tell you torque on all pivot bolts
    Uncut
    Apr 2013
    Completely missed that on their site. Thnx Shreddin
    May 2010
    No problem have a good season
    Tight enough to remove play, but loose enough such that there isn't any binding when you move the rear triangle through travel with the shock removed.
    May 2010
    Have a good season
    Uncut
    Apr 2013
    Thnx you too
  1. multiple quick links (power links)
    By BmoreKen in forum Singlespeed
    Last Post: 02-12-2013, 11:23 AM
  2. How tight is too tight.....seat post clamp?
    By rsolti13 in forum 29er Components
    Last Post: 07-24-2012, 07:17 AM
  3. Replies: 14
    Last Post: 12-20-2011, 04:51 PM
  4. Chain tension - how tight is too tight?
    By djork in forum Singlespeed
    Last Post: 10-14-2011, 04:02 PM
  5. Ti links on BLUR Classic
    By paxar in forum Santa Cruz
    Last Post: 03-24-2011, 06:30 PM
