Results 1 to 13 of 13
    FAIL in Bronson frame ...Breakege...???
    Pic´s in french forum....
    Cedric Gracia Bike.
    Infos VTT : Le Santa Cruz Bronson de CĂ©dric Gracia
    FAIL in Bronson frame ...Breakege...???-c41e9867e0a1c7baabb0f29cadafb46413816696031.jpg
    There is another picture floating around the boards showing a collapsed shock on his Bronson. No evidence of breakage just extreme tire rub.
    Reputation: wilsonblur's Avatar
    Quote Originally Posted by masemoto View Post
    True could be that he's running a tire to tall for the tolerances on the Bronson. Its interesting how we jump to frame fail so quickly.
    Narrow is the path to life, few are those who find it.
    GUIDANCE COUNSELOR
    Reputation: NoahColorado's Avatar
    I'm sure that happened in conjunction with the failed shock pic you posted in your other post.
    I've run those tires quite a lot (HR2 2.4) this year - including trips to Whistler, Moab, and several Colorado resorts - and have never had contact with the seat tube. I've used a Van RC, Monarch +, and CCDB Air.
    NOAH SEARS
    MRP - Brand Manager
    Pivot Cycles - Team Rider
    Quote Originally Posted by NoahColorado View Post
    You are probably right. Are your running that tire on a Bronson? All the SC bikes have slightly different tolerances for tire height.
    GUIDANCE COUNSELOR
    Yeah, XL Bronson. I dunno if Cedric rides a L or XL.
    Just a hypothesis, but if there was a failure in his shocks damper (ie a loss of damping), and he continued to ride it (perhaps in a race run) the repeated top out force could destroy the shock and could eventually snap the shaft (which is what looks like happened in that other pic).
    What's amazing is that the frame is fine after the shock snapping. So I believe this a case not of a "frame fail" but a "frame win".
    NOAH SEARS
    MRP - Brand Manager
    Yes...this is a positive look....
    Apr 2013
    I'm seeing tire rub, not breakage.
    Handmade in Switzerland
    Reputation: maettu's Avatar
    Most likely he does not use the standard shock (length / stroke) to squeeze more travel out of the Bronson. So he accepted that the rear tire touches the seat tube.
    No big deal for a sponsored rider...
    Reputation: Rhialto's Avatar
    In the comments on the Velo Vert site, someone comments that Cedric installed offset bushings that, in conjunction with his riding style, caused the tyre to rub. I have no idea how the commentor knows this but it does look like (severe) tyre rub.
    Reputation: Gman086's Avatar
    What was your fave shock out of those?
    And agree with you and the others - this is a frame WIN! Offset bushings and a blown lame Fox shock are to blame for the tire rub.
    Have FUN!
    G MAN
    "There's two shuttles, one to the top and one to the hospital" I LOVE this place!!!
    So how many different pictures of the same bike are you going to use to start yet more threads with frame fail, frame breaks, frame utterly destroyed etc..?
    OG Ripley v2
    Carver 420 TI
    Sorry for the confusion ...
    I wanted to provide two different information
    But I knew not add.
    I close previous post....
  1. Replies: 4
    Last Post: 06-22-2013, 04:55 PM
  2. Bronson C or S Works Enduro Frame???
    By AaronJobe in forum Enduro Racing
    Last Post: 05-16-2013, 09:33 PM
  3. bronson frame weight?
    By gnomer in forum Santa Cruz
    Last Post: 04-18-2013, 08:56 AM
  4. Frame FAIL!
    By Univega777 in forum Passion
    Last Post: 12-27-2012, 05:08 PM
  5. prophet frame fail - what now?
    By freeriderB in forum Cannondale
    Last Post: 04-22-2012, 04:21 AM
