Results 1 to 5 of 5
    Redwood Dancer
    Reputation: whangen's Avatar
    Experiment: A Nomad running a Fox Talas 130mm fork... Waz up wid that?
    I recently bought a large Nomad frame and built it up. That's all fine except, last year I bought a new Fox Talas R (130mm max - 5.1") front fork. Nomads are spec'd for 140mm minimum fork, however I decided to try The Talas on my new Nomad BEFORE I plunked down almost a thousand bucks for a Fox 36'er. Here's what I discovered so far. Yes, I do plan to get a 6" fork when I round up some serious dinero.
    I've only been on moderate trails so far, but initally: with no modification, the front end did seem a little low and the geometry somewhat off. First off I put a fatter 2.35" tire with a tall height profile on the front and a smallish 2.1 on rear, ie one end goes up the other goes down which supposed will bring the frame geometry more in line with spec. (the SC tech support guy thought this might work). I also set the sag a little deeper by maybe 3/8" at the Fox DHX shock shaft. I also put on a 100mm stem to slow down the steering a little bit (remember less wheelbase/steeper head angle equals faster steering). Fortunately, my old Talas old fork's steerer tube was pretty long, so that and a few 3/16" spacers got the handlebars up to where they felt pretty good and the cockpit was nice and roomy enough... plus I wasn't too upright. Anyway, here's my initial impressions on a few short moderate test rides.
    Downhill seems fine on moderate stuff. There's no feeling that the fork is 'too far out ahead of the bike" or "under your feet" or that the geometry is off. Control and stability is just fine and there's no tendency to get that 'pitched forward' feeling when hitting rock ledges uphill. I think the frame design is pretty forgiving and accounts for most of that. Oh yeah, DOWNHILL THIS BIKE WANTS YOU TO KEEP YOUR WEIGHT CENTERED OR ELSE BLOODBATH! I'll have to try it on some more radical stuff when I get a feel for the bike.
    The cornering is a obviously a lot different than Norba geometry bikes, but with my mods it doesn't jerk or spaz during tight corners, that is, unless you really lean too much or get you're weight too forward of center of the cockpit or just plain oversteer (wide bars good!). Anyway, it stays reasonably stable. I also set the compression on my fork a little bit higher so it doesn't dive with more weight centered forward from the short fork. My rear smaller tire grabs great since its slightly softer and I keep the front tire pretty full at about 38psi to keep the front end up. Take a pump for flats or better go with UST.
    I like a roomy cockpit but the Nomad's actually isn't much bigger than its cousin, the Superlight (which I also own). Much better standover on the Nomad tho!
    I'll still continue to experiment with my 130mm Fox fork and by the time I figure it all out I'll have the bucks for the fox 36'er!, By the way, don't be afraid to play around with this - in spite of what you LBS sez, you're not going to void your warranty!
    Let me know your experiments and tips, please.
    TNC
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    No pedal smacking? I have a large Nomad with a Van 36, and I seriously wouldn't want a shorter fork on this thing. We may have more rocks than some places, but mine was at about the minimum ride height I'd like to deal with in rocks. I even switched over to a 170mm crankset for this weekend to see how that works out.
    Redwood Dancer
    Quote Originally Posted by TNC
    Not too many rock gardens or boulders around Santa Cruz, where I live, tho we do have a lot of ramps over logs, plus elevated ladders and slippery roots. When I do big drops over root ledges and dirt embankments I usually don't pedal over and down them full speed like a downhiller but instead I level the pedals and wheelie drop them or just launch them full speed. Six foot is about the biggest drop around here (come to daddy, Nomad), unless you go downhill specific areas.
    Thanks for the heads up tho, I'll keep an eye out for the baby heads in my path (I do ride the Sierras once or twice a year for a little painful rock reality. Hopefully by the time I get up there next, I'll have a Marz 66 or a Fox 36 something or other.
    hands up who wants to die
    Reputation: rpet's Avatar
    I wonder why SC bikes often have low BBs? ha ha
    I can't wait for my trip back to my homeland. My 4X really wants to rail at Wilder/UCSC/Demo. I bet I could ride those places with a 4" BB height as long as I didn't pedal through corners.
    Rocks are fun, but so is going 30mph on redwood forest singletrack.
    -rob in NYC
    The server is too busy at the moment. Please try again later.
    Redwood Dancer
    Never thot of it that way...
    Quote Originally Posted by rpet
    -rob in NYC
    Now that I think of it, rpet, SC bikes do have generally lower B/Bs, and you're probably correct about the Santa Cruz factor (ie. no real nasty rock gardens).
    Come to think of it, my old FSR had a higher B/B and a much longer wheelbase. I know Mike Sinyard, the CEO, tested them at Henry Coe SP and at Rockville, two fairly rocky places for the SF Bay Area. I've seen their riders there many times thrashing bikes. Thus, the Enduros and FSRs reflected the environment where they were born. Makes sense. Glad I've never met anyone testing bikes at China Camp!
    Just for kicks heres a snap of my large Nomad frame before buildup.
