Results 1 to 25 of 25
    Reputation: nauc's Avatar
    ever hit this on rocks etc
    someday id like to get a SC full suspension bike, but im wondering, do you guys ever hit this on rocks etc. im assuming its pretty much a non issue, since a lot of their bikes are designed like this
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    MTBR user named Cytoe sells guards a lot of us use.
    http://classifieds.mtbr.com/showprod...-frames&cat=30
    Reputation: swoodbrn's Avatar
    I haven't in about 700 miles, but the alum bottom link in the middle has a 8mm chip out of it, and, I have a bash guard that protects a bit.
    i noticed the new Nomad isnt like that. maybe the next bikes wont be either. that would be cool
    Jan 2014
    Its not totally a non issue.
    I've slightly gouged the link and rear triangle there on both on a TRC and 5010.
    I think its mainly from slow speed manuevers like trying to climb over a small boulder.
    The link gets pulled out of the way as the suspension compresses so higher speed stuff is more likely to just contact the chain rings.
    Mine has a handful of chips/scratches on it from rocks kicking up, but nothing catastrophic that would keep it from functioning properly.
    Slower But Faster
    Reputation: BrentD's Avatar
    The link on my four year old Mk.2 Nomad is still in perfect condition. Non-issue as stated above. When the suspension is sagged (i.e. how it sits when you're actually riding) it is considerably less protruding.
    Feb 2012
    It only ever gets scratched if you're riding loose scree and stuff. It'll take hits from sticks and logs no problem, and most rocks aren't sharp enough to get in there without hitting the tire/chainring first.
    Nov 2012
    I've seen not seen a Santa Cruz broken there but have seen intense break there. It's completely vulnerable during low speed rock crawling type obstacles. Rocks and debris will also build up on top of the lower link then start getting smashed into the rear triangle. You should consider a guard but as another user stated both intense and Santa Cruz are starting to tuck the link up higher and makie it shorter
    Mar 2011
    I have owned several VPP-SC bikes and it can get scratched but is a non-issue for me.
    MarkyMark
    Reputation: MarkMass's Avatar
    I've got a huge chip there on my LTc. I think I got it somewhere in Downieville on one of the high-speed rocky sections, but it hasn't been a problem in 1+ year of riding. I'll upload a pic later.
    Adding the pic:
    Santa cruz blur ltc chipped carbon by markmass, on Flickr
    Jan 2015
    I just put a Amygos guard on my link. Nice piece and now I have peace of mind.
    Reputation: sooner518's Avatar
    it was always a concern when i first got the bike, but after 3+ years of riding it hard over some really rocky crap, its a non-issue.
    Had a rock strike on mine on the 3rd ride, So brought a plastic cover off ebay, No problems since.
    Did chip the paint on my 5010
    Reputation: nyrdrms's Avatar
    Other options
    ever hit this on rocks etc-p1040633.jpgever hit this on rocks etc-p1040637.jpg
    Reputation: wilsonblur's Avatar
    Yes I hit mine
    If you chose to climb the technical stuff with step ups and logs you can end up hitting the lower link. I had a chain guide on for the first year and then moved to a type 2 derailleur. So I am starting the 3rd full season with it exposed and this is what it looks like. Shop says its just cosmetic at this point.
    Narrow is the path to life, few are those who find it.
    Quote Originally Posted by nyrdrms View Post
ID:	971867Click image for larger version.
    where do you get those?
    thanks
    +1 for the Cytoe guards. Have it on my Bronson. Super easy to install and remove to clean the bike when needed, and it works great.
    I've had some hard contact there multiple times resulting in chipped paint. My LBS said it shouldn't be a structural issue, and if it becomes one, SC warranty will cover it.
    I should probably get the Cytoe-slider...
    Reputation: KRob's Avatar
    Quote Originally Posted by She&I View Post
    That's good to hear though I imagine it won't help my resale value.
    I've also noticed quite a few chips in the paint right in that spot too.
    Isaiah 58:14
    www.stuckinthespokes.com
    Resale value... We don't really care, hehe. Frame tape, what? I take a beating every time and somebody gets a great deal. As long as it's cosmetic, bring on the damage...
    LCW
    LCW is offline
    Reputation: LCW's Avatar
    The sooner SC eliminates that that low hanging fruit of a linkage from the VPP lineup the better... Let's hope the trend set by the Nomad 3 continues...
    Santa Cruz Hightower LT
    EVIL Following
    Yeah, I'm with you on that. I figure no matter how much protective tape and guards I put on my bikes, they're going to show some wear and tear. Ride the crap out of them then let someone else enjoy it.
    Isaiah 58:14
    Reputation: glenj's Avatar
    Quote Originally Posted by tommyt275 View Post
    Just checked out the Amygos site....pretty slick looking stuff! Where did you get yours? Is there a US distributor?
    I have the Cytoe and it works just fine, but I like the 'form fit' of the Amygos (plus it appears you can get it in a carbon-fiber "look").
    Jan 2015
    I ordered it direct so that's why it cost a bit more. It was definitely worth it and I love how it fits around the entire linkage rather than just a plate. It took 7 days from France to Idaho.
  1. Alafia Rocks!
    By Lactic in forum Southeast/Midsouth - GA, TN, AL, FL, MS, LA, AR
    Last Post: 08-31-2013, 09:54 PM
  2. The Delirium still ROCKS!!
    By RideEverything in forum Knolly
    Last Post: 08-11-2012, 06:59 PM
  3. Just some rocks and a Paradox [o]
    By ScottN in forum 29er Bikes
    Last Post: 01-22-2012, 07:20 PM
  4. Sram CS rocks.
    By patrickd72 in forum SRAM
    Last Post: 09-13-2011, 07:59 PM
  5. Stan's Rocks...
    By 2FewDaysOnTrail in forum Wheels and Tires
    Last Post: 08-17-2011, 02:26 PM
