    wafflemaster
    DT 240s 135 to 142
    I have a 2013 TBc on order & getting wheels ready.
    Ordered a 135 to 142 x-12 w/ conversion kit (end caps, axle, 12mm skewer) for a 5-6 yr old 240s 6 bolt rear hub. Got this DT Swiss X-12 System 142mm Conversion Kit - Wheelbuilder.com which I believe is part HWYXXX0002877C from DT Swiss info http://www.dtswiss.com/Resources/Ima..._Kit_Style.pdf .
    The skewer is threaded on opposite side of the handle (drive side). No nut for the end like a 10mm I have on another bike.
    So I'm cornfused, does the frame have a threaded screw in for the skewer OR do I get a special derailleur hanger OR am I skewered & need another kit & skewer option?
    Appreciate your help as I'm new to this crazy 142 world.
    wafflemaster!
    The TB has a screw-through rear axle, so the frame will be threaded. Also, my Blur TRc frame came with a DT Swiss thru-axle, so your bike probably will have that as well.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    According to BTI:
    BTI part #: DT-0545
    vendor part #: HWYXXX0002877C
    EAN: 7613052075877
    converts to: 12x142mm T-A (X-12)
    stock configuration: <July 2010 10x135mm Q/R
    hub/wheel model: rear (IS/CL): 240s,440FR / 1540,1750,2350
    Kits can also be used for replacement axle caps if needed
    Most kits include a pair of adapters only (bolt, axle, and quick release available separately)
    DT-0534 include a pair of adapters and one hub axle
    DT-0545 include a pair of adapters and one hub axle and are compatible with 240s hubs/wheels produced prior to July of 2010 (chrome-style logo sticker)
    DT-0547 include end caps only and are compatible with 240s hubs/wheels produced after July of 2010 (white logo sticker)
    For 12x157mm conversion use DT-0547 (12x142mm conversion endcaps)
    IS: 6-bolt / 44mm BCD International Standard, CL: 35mm spline CenterLock
    Q/R: quick-release, T-A: thru-axle, T-B: thru-bolt
    So basically you have to swap out the end caps and axle on the older 240 hubs. The frame will still come with the threaded axle/skewer.
    I resolve to constantly assert my honest opinion on anything and everything - whether it is requested or not.
    Bucky the Cat
    wafflemaster
    DT 240s 135 to 142
    Good news, Thanks
    wafflemaster!
  1. DT 240s vs 350
    By equalme in forum Wheels and Tires
    Last Post: 12-31-2016, 12:43 PM
  2. Used DT 240s or new Hope Pro 2?
    By NslrPrtn in forum Wheels and Tires
    Last Post: 12-12-2012, 11:27 PM
  3. Really on the fence, CK or 240s.
    By D93 in forum Wheels and Tires
    Last Post: 05-05-2012, 03:25 PM
  4. Where'd this 24h 240s hub come from?
    By One Pivot in forum Wheels and Tires
    Last Post: 04-15-2011, 05:50 AM
  5. DT 240s for DH?
    By capturecolorado in forum Downhill - Freeride
    Last Post: 03-02-2011, 08:56 PM
