Results 1 to 3 of 3
    Reputation: gexas's Avatar
    Disregard: it is fixed now. adapt 142x12 ra to fit 135x10 blt2 frame???
    embarrassed to say this but hopefully there is an easy solution. i just bought a 2012 crossmax st wheel set but when i went to put the rear wheel on my 2009 blt2 the hub didn't fit. surprise, surprise. after doing what i should have done before buying them i found out that the rear axle on my bike is a 135 x10 but the wheel is a 12 x 135 or something.
    Does anyone know what some possible solutions to this problem might be?
    thanks in advance for the help,
    E
    Reputation: dansMTB's Avatar
    if it is 12x135, get one of these:
    QR or Bolt-On Conv for 3.30HD 12x135 Rear Hub
    Thanks for the reply. an even more embarassing discovery is that i had a 10mm adapter in one side of the hubs and because the other side wasn't the same and was missing the other adapter it threw me off. by divine intervention i was looking around in the wheel packaging and found the other adapter that had dislocated itself from the hub in shipping. thank goodness the wife hadn't started cleaning up the place just yet.
    i tested it out and everything works like silk.
    e
