    DHX5 Air setup advice
    I've just bought a Heckler frame with a DHX5 air shock which I want to setup for my weight.On the Santa Cruz UK website they have a table of settings for the shock.For my weight,approx 180 lbs,they suggest 170psi air pressure,140psi boost valve but for the propedal, bottom-out and rebound they suggest 10 ret,2.0 ret and10 ret,what do they mean by ret? Any ideas? Neal
    "The number of clicks out from the fully closed position"
    Reputation: Sugar_Brad's Avatar
    the setup guides are way off. Are you 180 geared up? You will also notice a difference when it breaks in. I ride an 07 bullit so the geometry is similar. Try 200 psi main and about 130 psi boost with 1/2 to 2/3 of bottom out. This will help with the lack of midstroke the dhx air has. I run my pp wide open. I weigh 170 with gear and I run 190psi main, 125 psi boost, 2/3 bottom out, 1 pp click. I have excellent small bump sensitivity, 30% sag, good midstroke support and I can do 6 foot drops to flat without bottoming. Cheers.
    Thanks for responding to my post.I should perhaps of said that the frame's not new,think it's an 05/06,but hopefully the shock should be good as new 'cos I've sent it off to be serviced,pretty expensive but at least I know the shock's doing want it's supposed to! The company doing the service asked what weight I am and what sort bike the shock's off (I'm probably nearer 190lbs with my gear and fully loaded Camelback) so with any luck I won't need to mess about with it too much!
