Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 75
    Sep 2014
    Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?
    Looking at carbon rims/wheelsets for my N3 (can't afford Enve).
    What are people using and what's your thoughts?
    Currently running Stans Flow EX on Hope hubs.
    Cheers
    Chris
    I have Light Bike, hookless 35mm iirc and have used them on my Nomad, decent rims and no real difference to either pair of my ENVE's. If I was buying again I would probably buy Derbys though.
    Sep 2014
    Quote Originally Posted by Rick Draper View Post
    Thanks Rick - just the sort of user info I'm after.
    Illuminati
    Reputation: scant's Avatar
    have a look at Atomik Carbon
    Reputation: ScottW's Avatar
    Derby rims, Hadley hubs, DT Swiss spokes on my Nomad.
    Sep 2014
    Quote Originally Posted by ScottW View Post
    Cheers - Any feedback on them?
    Derby are top of my list at the moment.
    Reputation: mestapho's Avatar
    Derby, Kings, Pillar 1420 spokes on my 5010.
    Can't recommend highly enough.
    Strong and stiff. Wide rims are the real deal.
    If you ever have a problem Ray is awesome to work with.
    Reputation: BTTR's Avatar
    Jun 2012
    35mm LB rims with Hope hubs here
    Love them and so far not a single issue. You can't go wrong with them.
    Derby's are nice too, but still a good bit more expensive.
    Reputation: 11053's Avatar
    35/30 Light Bicycle hookless "DH" rims on Hope Pro 2 evos.
    Wheelsmith DB spokes and brass nipples.
    Light + Strong + "inexpensive".
    No burping. Easy tubeless set up.
    Like any wheel, just have an excellent builder put them together for your best shot at performance and long service life.
    Reputation: Pau11y's Avatar
    I just built up a pair of LB's 38mm/31.6mm (ext/int) 27.5 rims for me new DH bike. I had specifically asked that they increase the weight on them to 500g or above, but they only did that to 1 rim. the other was 476g, so it ended up as the front. The built went well, except you'll have to measure the ERD when you ask for more carbon.
    Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?-p4pb11883990.jpg
    Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?-p4pb11883989.jpg
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    Just found this today. Definitely should be considered.
    Quote Originally Posted by mestapho View Post
    FYI, those Ibis look like they use the DMR Revolver front hub...a LOT alike! If so, you can get end caps to convert the front hub to 20mm. I have a pair of old Reynolds MTN-C that used hubs that looks VERY similar to those hubs and I was able to get some 9mm QR, 15mm QR, and 20mm axle end caps for mine.
    Now, if I can find out more about the 142x12 rear and if I can convert my Reynolds...
    Quote Originally Posted by Pau11y View Post
    Unfortunately these can't be converted to 20mm t/a per the ibis website. The rear can be 142x12 or 135x10
    Reputation: expatrider's Avatar
    Jun 2010
    Light Bicycle 35/30mm rims - outstanding so far - with DT spokes, and 240s hubs.
    Reputation: dirtbiker's Avatar
    Jan 2005
    IBIS carbon wheels, same as Derbys, Jenson had them on sale last week for $999, hard to beat that price for a wide stiff carbon wheel.
    2015 SC Nomad C
    2014 Bronson C
    2015 5010 C
    2013 Jackal
    Quote Originally Posted by dirtbiker View Post
    Splitting hairs, but they are extremely similar, not the same.
    Aw yeah, I guess, looking at the front hub shell dimensions, there's just not enough room in the front hub for a 20mm TA. Had to look to confirm, but my Reynolds are fatter.
    Thanks for the clue on the rear tho!
    oracle
    Derby HDs with I9 Torch hubs and spokes work well on my Nomad...
    On my new 27.5 Nomad I built up a set of Derby DH rims laced to DT Swiss 240s with DT Aerolite spokes and 16mm DT Al nipples. The longer nipples allowed me to use a box of spokes I had from another wheel build, I'm not sure I would go with long nipples if I built them up again. They haven't caused any problems, but there are a few spokes where the nipple stayed perpendicular to the rim (rather than angling with the spoke) and I think the affect is more pronounced with longer nipples. The wheelset (with XX1 driver, Al valve stems, and tape) came out to 1678 g on a 5 lb postal scale.
    I'm 230 lb out of the shower and I'm not the smoothest rider. I've ridden these wheels at Mammoth for the Kamikaze Enduro and on all my local trails in So Cal. I have ZERO complaints about the rims. I love the wider rim, they feel noticeably stiffer and more precise through chunky rock gardens. I've banged them off a few things and had a few pinch flats in Mammoth cause my tires were too lightweight and the rims show no signs of damage. I run about 24 psi in the front (Conti Mountain King) and 22 psi in the rear (HR II). I no longer worry about my rear sidewalls flexing when I load the rearend in a turn.
    Reputation: flyinmike's Avatar
    Dec 2005
    Derby-Cx Ray-King
    Derby I9 combo with an HD rear and AM front. Wheels have been solid and I have several other friends on them now too with either I9 or King hubs.
    ban
    ban is offline
    Another vote for Derby, I-9 hubs and CX-ray spokes
    Attached Thumbnails Attached Thumbnails Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?-imageuploadedbytapatalk1422217962.097510.jpg
    My Nomad 3 is equipped with Roval Traverse Fattie Carbon SL.
    Top wheels and zero problems so far! And with a weight 1500 grams!
    Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?-10390446_815094095217455_8497767867135458180_n.jpg
    Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?-10620636_2025147820957280_4030522793211055722_n.jpg
    Nov 2014
    Re: Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?
    Nextie 40mm (35mm internal), CX Ray's, King Hubs.
    Nice and stiff, only a few rides in but they seem great so far.
    Sent from my SM-G9008V using Tapatalk 2
    Attached Thumbnails Attached Thumbnails Carbon Rims/Wheesets (not Enve) for Nomad 3 - what you using?-uploadfromtaptalk1424128924990.jpg
    Sep 2014
    Wow - thanks everyone.
    Lots to think about and look at here!
    I'll summarize the options later ;-)
    Cheers
    Chris
  1. Carbon Rims worth it on a Nomad 27.5?
    By scepticshock in forum Santa Cruz
    Last Post: 11-10-2014, 04:52 PM
  2. Enve AM 29er Rims...The last word in carbon?
    By Ironbar81 in forum Wheels and Tires
    Last Post: 04-10-2014, 10:11 AM
  3. Enve 29'er carbon XC rims cosmetic question
    By bassn in forum Wheels and Tires
    Last Post: 11-25-2012, 05:28 PM
  4. Replies: 3
    Last Post: 04-14-2012, 08:12 PM
  5. Enve XC or AM rims or just get Roval SL carbon 29er's
    By crimecrusher in forum Wheels and Tires
    Last Post: 01-31-2012, 07:11 AM
