Page 5 of 21 FirstFirst 12345678915 ... LastLast
Results 401 to 500 of 2066
  1. #401
    Reputation: tboned's Avatar
    Frame swap... sold the nomad 1.5.
    New frame is XL nomadc (6.6 lbs.), 27.6 lbs. w/ pedals. The rp23 works well with the bike, I think I will stick with it for now. I can't get over how light the back end of the bike feels on the trail. Yes there seems to be a small bump comp. loss but I kind of like how sensitive the suspension is now, especially for xc riding. Also, couldn't resist switching to 1x10. Only complaint is the paint is a little prone to chipping.
  2. #402
    Hey tboned, what tooth u run in the front?
  3. #403
    Just bought a salsa 32t and running a mrp 1x guide.
  4. #404
    I am a Nomad
    Reputation: tp806's Avatar
    Nov 2008
    Quote Originally Posted by gticlay
    Here's a dirty NomadC.
    Hey gticlay, how do you find riding the Nomad C 1x9/10?
    I am thinking of going 1x9 on my alu Mk2 Nomad as well.
    Is it worth it for aggressive all-mountain riding? How is the suspension behaving?
    Currently I am running a XT triple with e13 heim 3rs
  5. #405
    Reputation: gticlay's Avatar
    Quote Originally Posted by tp806
    I like everything about it except it's not an easy thing to pedal on some trails here - 32 front and 36 out back is the same as running a 24t granny with a 27 tooth in back. Pretty hard to push in the mud up a steep trail. But it does get rid of the pedal kick back feel in granny gear which is nice and it's super quiet, etc.
    "It looks flexy"
  6. #406
    Reputation: Balakeka's Avatar
    I use a triple XTR with the e13 heim 3 and is a good solution that calms the chain, that allow you to climb everything and go really fast down or in the road when is necessary.
    Not yet sure on the reliability.
    Ride More, Drive Less
    ____________________________________
    2017 Nomad CC, 2016 SC Tallboy CC, 2014 Pinarello Paris, 10973
  7. #407
    Oct 2010
    hello tintr,
    can you send a picture on your frame, how many spacers (1mm or more?) you add to install your mrp G2 mini sl? please? because i install now this, and i want to be sure at which distance to the base /frame the pulley should be...
    does the lower guide pulley should be over or in front of the right base aluminium piece? or a bit at the same area?
    if you have lots of pics from top down etc... and the distance that you can provide me, it will be great, mate.
    thanks a lot
  8. #408
    Reputation: Jimba's Avatar
    Just got this together, it's replacing my Ellsworth Moment. have not been out on it yet.
    1 X 10 Sram.
  9. #409
    You will EFFIN love that bike. Just rode mine on a nice 1 hr night ride. Worked awesome as usual! It'll be perfect once you go Shimano anyway
    Quote Originally Posted by Jimba
    1 X 10 Sram.
    "It looks flexy"
  10. #410
    Jimba - what chainstay wrap is that?
  11. #411
    Quote Originally Posted by baltik
    :LOL: That is how it comes from the factory.
    "It looks flexy"
  12. #412
    Yup, stock, and funny you ask because I normally wrap it with 3M wrap that works great.
    gticlay, funny you say that about Shimano, I have been a Shimano guy for a long time and recently switched to Sram, so far i'm impressed with Sram shifting. they both have their strength and weaknesses though.
  13. #413
    What position is your LG1+ to get it to mount correctly? Would you mind snapping a photo of any spacers etc. that you needed to get it to run. The LG1+ is a pain on this bike, but I've got my mind made up already.
  14. #414
    Yea I did have to fool with spacing quite a bit but got it really good now.
    Ended up with no spacer between the drive side BB cup and frame. I used the thin gold washers under the LG1, in fact i used a file and knocked the bur off the sharp edge of the washer to make it as flat as i could. the bottom guard is on the "W" position and you can see the clocking i mounted it at.
    When I'm in the 36 in the rear the chain does not rub, when it is in the 12 it gets just a bit of rub.
    pretty happy with it over all.
  15. #415
    I am a Nomad
    Nov 2008
    Quote Originally Posted by Balakeka
    Hey Balakeka, can you post a pic of your setup with the triple and chain guide?
    Also how is it behaving when in the big ring, and doing drops, jumps, rock garden and generally aggressive all-mountain rinding?
  16. #416
    Dec 2010
    Jimba, what cables are those?
  17. #417
    Hardyboy404
    May 2010
    Nice looking bike Gripo. I'm back on the DHX-Air on mine. The RP23 (to me) wasn't really working out. The 23 seems to work real well on my Firebird though so I swapped the shocks and all is well again on the Nomad. I still have my RC4 shock as well for heavier duty stuff.
    can you a make a couple quick comparisons between the nomad/firebird? might get either one, handling, jumpability, climbability etc. THANKS man
  18. #418
    Quote Originally Posted by Michael Hardy
    I wish they made a Carbon Firebird. They are both pretty good bikes but I guess I'd pick the 'bird if I could only have 1 bike. They both jump great, the Firebird, IMO, has a better HTA for a long (170 or 180) fork, and climbs well with more small bump sensitivity. I guess search for firebird with gticlay as the author in advanced search as I have put up some stuff in the past.
    "It looks flexy"
  19. #419
    Reputation: disjointed's Avatar
    Dec 2008
    gticlay - Did you ever put the RC4 on the NomadC, if so, how did it ride compared to the RP23? Any improvement with small bump compliance?
  20. #420
    Hardyboy404
    May 2010
    well I don't think I need to go bigger than a 160mm fork and ya I can only have one bike so you would go with the bird huh? thats what i'm leaning toward gotta see the price comparison tho.
  21. #421
    Question for everyone running a float or any other non-travel adjust fork. How does the nomad carbon climb with said fork, does it flop around/require a lot of body English?
  22. #422
    Quote Originally Posted by disjointed
    I did on my aluminum framed nomad 2. Maybe its time to give it another try, especially since I dropped the granny when I bought the carbon. I'll report back ASAP... probably tomorrow night.
    "It looks flexy"
  23. #423
    I have a 36 Talas on mine and have not been compelled to drop it from 160 to 130 very often,
    as compared to my Turner RFX, which was definitely more squirrely in 160. The NomadC
    climbs like a dream.
  24. #424
    Quote Originally Posted by tim_k
    The brake lines are Goodridge SS braided with clear, so your seeing the SS braid.
    The rear derailleur is a Jagwire Sterling silver. matches the above pretty well.
  25. #425
    So I threw an RC4 on my NomadC
    Feels weird putting a coil on the carbon bike, but what the heck. It's been so long since I rode VPP2 with coil..... back when I had the aluminum Nomad2.
    "It looks flexy"
  26. #426
    But the Firebird is one ugly bike!
  27. #427
    Nov 2008
    [QUOTE=Jimba]Just got this together, it's replacing my Ellsworth Moment. have not been out on it yet.
    1 X 10 Sram.
    Curious... How come the 719' as opposed to the 819's?
  28. #428
    Quote Originally Posted by curbhuck
    I think a 170 fork with a regular stack headset is really pushing it. I never have problems, but it rode better overall with a 160 Float 36 on there. I don't really feel like the extra 10mm helped it much pointed down either. There's a magical jump going from 160 to 180 that just doesn't happen when going from 160 to 170.
    If you run a 160 fork, you absolutely do not need travel adjust, IMO.
    "It looks flexy"
  29. #429
    x2!
    In fact, I have a Talas 36 that I'm trying to get rid of so I can get a Float 36.
  30. #430
    Dec 2008
    Ever get out for that ride? Any improvement over the RP23?
  31. #431
    I have the shock on my bike but something weird happened with my back. I've NEVER had back problems but as of about 6pm last night I could barely move it. Painful to breathe all last night. This morning it was difficult to put my socks on. Some shooting pains when walking up steep steps at work today.... But as of right now, I'm getting way more mobile. I'm going to go to the gym in the morning and do cardio on the elliptical machine and hopefully that'll loosen up everything and I can at least to a short ride on Sunday.
    I think I landed funny off a jump on either my Sunday, Monday, or Tuesday ride and hurt something that didn't stiffen up for a few days but ????? Getting close to 40 and people tell me that this chit just happens when you start getting older.
    "It looks flexy"
  32. #432
    Reputation: q2xltrgt's Avatar
    Curious... How come the 719' as opposed to the 819's?[/QUOTE]
    My guess is that has discovered that you can put light tubes in a given tire and it will be lighter than most ust tires.
    I was going to buy a set of the carbon haven wheels (according to easton are the lightest all mountain wheel out there) but after calculating tire wt. into the wheel the mavic 521's with king hubs was only .2lbs heavier than the havens, plus I can build 3 sets of them for the price of the havens.
  33. #433
    Wait til your 46 ! !
  34. #434
    #THELEGEND
    Reputation: Guy.Ford's Avatar
    Booooooo!!! Excuses thats all they are. Never grow up, never get old!! FWIW I will be 40 in july and I feel like a 19yr old!!
    Hang in there pops!
    #THELEGEND
    2016 RSD Mayor
    2017 Diamondback Haanjo Trail (Alu)
    Coming Soon
    2017 Guerrilla Gravity The Smash
  35. #435
    Quote Originally Posted by mrbeef523
    27.4 lbs ftw.
    But you have built versions - "28.24 lbs with the Command Post. Not too bad. A new 36 Talas RLC would drop a little weight..."
    You will send photos of these versions
    thanks
  36. #436
    [QUOTE=mbc4386]
    1 X 10 Sram.
    Didn't want UST.
  37. #437
    Calm Like a Bomb
    Reputation: pipes10's Avatar
    Quote Originally Posted by tomo358
    thanks
    He doesn't own this bike anymore.
    '17 Hatchet Carbon
    '17 Troy Carbon
    '16 Django Carbon
    '16 Wilson
    '16 Farley 5
    https://www.instagram.com/jayparrington/
  38. #438
    Rode the RC4 a bunch today. It's pretty darn fantastic. It's easy to dial the shock in with all the adjustments available. For instance, the RP23, IMO, has too much LSC and like a click too little HSC. No problem with the RC4.
    The bike still isn't "PLUSH" like an old school Stinky with a coil felt back in the day. It's more of the modern control over comfort feel. The bike is very tight... but I will say it felt like the bike had more travel than when running the RP23. It also tended to run higher in the travel than with the RP23. Hmmmmmmmm.
    Anyway, not worth buying an RC4 with a ti spring if you already have the RP23 but it felt pretty, ahem, rad today.
    "It looks flexy"
  39. #439
    Dec 2010
    This is my Carbon c, amazing bike!!!
    Attached Thumbnails Attached Thumbnails Carbon Nomad Gallery-p1040876-edited.jpg
  40. #440
  41. #441
    Hey tomo, why no gold chain? I love the custom ano parts.
    "It looks flexy"
  42. #442
    Damn! he fixed that quick!
    Looks good Tomo.
  43. #443
    Reputation: evil zlayo's Avatar
    now this is just stupid. i'm all for light bikes, but my WW 7.9kg xc hardtails has bigger tires.
    ~ Too weird to live, too rare to die ~
  44. #444
    I did not build this bike. I wait for Nomad C.
  45. #445
    fraid of heights
    Reputation: stiingya's Avatar
    Quote Originally Posted by evil zlayo
    Well obviously the tires don't exactly match the frames best attributes, but stupids a bit harsh.
    During winter I do mostly desert XC riding, so I put similar "light" tires on my long travel bike. (granted we got a bit of an early thaw and went up on the mountain and I used those tires on a few rocky downhill runs and got my @$$ handed to me!!!) BUT, my point is that there's nothing wrong with setting up your bike for specific riding conditions. You don't always need big rubber...
    Quote Originally Posted by the_owl
    Everytime you ride in mud, god kills a kitten.
  46. #446
    Hardyboy404
    May 2010
    what seat post is that?
  47. #447
    May 2005
    Small Nomad C
    Does anyone know if it is possible to use a flush headset on a small Nomac Carbon frame or will the fork knobs hit the downtube? Thanks
  48. #448
    Reputation: cuore di tenebra's Avatar
    Carbon Nomad Gallery-foto0675.jpgClick image for larger version.
ID:	595771Attachment 595772I took it today from the store, (the bike, not the girl...) 33,7 lbs, i'am waiting for a titanium spring, 33, 3 lbs finally
  49. #449
    Time to get her dirty,....
  50. #450
    The bike or the girl?
    Tomorrow morning at dawn.
  51. #451
    What size front ring are you running? That's the setup I am planning on running glad to see it works.
  52. #452
    Nov 2008
    One from down under... Australia. 27.3lbs with the E2200's. Very happy with how it ended up.
    EDIT: 28.7lbs... my mistake.
  53. #453
    Dec 2005
    I have a nomad C with RP23 shock, I'm not really liking the action of this shock, the Pro pedal doesnt appear to make much difference to action..
    What shock does everyone think works best with the Nomad C ?
    Cheers
  54. #454
    I am a Nomad
    Nov 2008
    Why don't you try this, for a refreshing change
    http://www.chainreactioncycles.com/M...?ModelID=59821
  55. #455
    Shut up and RIDE!
    Reputation: doc-ock's Avatar
    Jan 2005
    Quote Originally Posted by mobywan
    i'm calling bs on this one.. 27.3 pounds? i find that hard to believe
    Santa Cruz Nomad Carbon
    Intense M9
  56. #456
    Me too, I think that scale needs adjusting.
  57. #457
    Reputation: V.P.'s Avatar
    definitely doable with that spec
  58. #458
    Nov 2008
    Quote Originally Posted by doc-ock
    Oops... you'd be right. I was converting from Kgs... that clearly didn't go so well.
    It's 28.7.
  59. #459
    Hello guys, I noticed on my nomad c that the rear triangle is very flexible in the sense that it twists a lot. I tried to push the rear wheel with his hands and the rear triangle moves very laterally, while the rear triangle of my blur lt alu is very hard compared to this .... What about?
  60. #460
    Quote Originally Posted by cuore di tenebra
    First check to make sure the pivot are tight. Mine needed re-torturing (er, torqing!) after a few rides. Second check to make sure your wheel bearings aren't somehow loose. I had that happen too. Where are you grabbing to check?
    "It looks flexy"
  61. #461
    First check to make sure the pivot are tight. Mine needed re-torturing after a few rides. Second check to make sure your wheel bearings aren't somehow loose. I had that happen too. Where are you grabbing to check?
    I took the bike Saturday, February 5, I have not used yet, except a little around town. I do the test by taking the top of the wheel and moving from right to left. I think the pivot are tight but I have to check. The wheel bearings are ok.My impression is that the rear triangle is very flexible( too much?) when compared to an aluminum frame .... I hope not to the point of breaking
  62. #462
    Yeah, check the links first. Check your wheel anyway. It should be rock solid. Maybe take the wheel off and see why the triangle wiggles. It's a very stiff trangle.
    "It looks flexy"
  63. #463
    Reputation: p0r0y's Avatar
    Finally she's done. Thanks to Fernando and Curtis of Bicycle Emporium for building the bike can't wait to ride and get it dirty.
  64. #464
    I did this test because during the tour on Sunday, when I looked at my bike while a friend tried, I saw that the rear wheel moving in a strange way ..... but the rear wheel bearings and Qr are new
  65. #465
    Reputation: Dogboy's Avatar
    Your impression is not correct. It is much stiffer than the aluminum frame.
  66. #466
    In my case I've changed the frame from Al to C, keeping all the rest, just to feel the difference.
    So I'm positively, absolutely, completely sure that you need to some look for another cause, because is very clear the stiffness improvement from one model to another, even if there is not a version without the standard QR in the rear wheel, which is a pity by the way.
  67. #467
    I did the same thing when I switched. No comparison - the "C" was way stiffer.
    "It looks flexy"
  68. #468
    You are mistaken. Carbon = Stiffer. end of story.
  69. #469
    Dec 2009
    I would say, failing loose links and pivots (which would be unlikely) I would be pointing my finger at the wheel.
  70. #470
    Now I'm waiting to arrive the same bike to my friend and check if it is my impression or is it a feature of this frame. I confirm that the wheel bearings is ok and the pivot is tight.
  71. #471
    The wheels in your picture don't look very stiff either. They look like lighter wheels.
    "It looks flexy"
  72. #472
    Dec 2008
    What do you guys expect! Buying plastic bikes! AL all the way. hahah jk love the nomad c
    Your big wheels are so awesome!
  73. #473
    Are dh wheels, rims mavic 823 ust, hubs hope pro II and spokes dt swiss 2mm, Ant 20mm PP, rear Qr 10mm by Protone components. Very Stiffer wheels.....
  74. #474
    Oct 2010
    nice bike
  75. #475
    OK, my mistake. lo siento. I thought they looked like the lower end mavic wheels.
    "It looks flexy"
  76. #476
    Rider
    Careful with those XT wheels, look what happened to mine:
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/my_jBZZQ0XEQeIQk9Ro6rkCKY6djIisEb1uO78RTyVg?feat=e mbedwebsite"><img src="https://lh5.googleusercontent.com/_T6QN5GZ_JD8/TEyFLGo4YBI/AAAAAAAAC7I/0T457jHfX5A/s640/IMG_0485.JPG" height="360" width="640" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/galindo.d/MTB?authkey=Gv1sRgCLXxz_3r0uqMnQE&feat=embedwebsit e">MTB</a></td></tr></table>
  77. #477
    Holy crap - what did you do? I've been riding mine hard for 2 years, including at Whistler and they are still perfect.
    Quote Originally Posted by Febo
    "It looks flexy"
  78. #478
    Looks like a unique Valentine for someone special.
  79. #479
    Rider
    I lost control and went down the side of a steep hill, everything was fine until this last drop/jump where the front wheel couldn't take it and failed.
    To be fair, it was a pretty big drop and I was going very fast but had the wheel not failed then I would have made it all the way down...
  80. #480
    Bent wheelWhat
    What wheelset wouldn't have bent from that impact?!
  81. #481
    Reputation: Trojan's Avatar
    Nov 2006
    Quote Originally Posted by Mr.P
    But you would need pedals to ride....
    P
    Tintr/Mr.P where do you see that minus 1 Lb?? Is that in the X0 Group set? or the wheels and tyres?? those Ardents are heavy ish? are the WTb tubeless??
    Love the idea of a 26lB with reverb post, is that a large frame? 26.5 with pedals?
    thanks
    Solo C 32@140
    Nomad 3 C, Pike.
    Cube Stereo Hybrid 140 (recovery rides & grin inducing blasts/uplifts)
  82. #482
    build question
    New to the forum. Just about to order my NomadC frame and get to building. I'll post some photos and spec as I start the process. Some beautiful builds in this forum!
    I have a question for any of you with experience installing headsets in carbon. I like the idea of building this completely on my own but I don't have any experience with pressing headsets or crown races. Am I asking for trouble or is it fairly easy with carbon? My understanding is the headtube does not need to be faced - so just clean it, grease it and press it? Nothing against my LBS, I just like being able to do things on my own.
    I searched a bit for answers but didn't find any. If I missed a forum discussion on this I apologize. Just link me over and I'll start there.
    BTW, in case it is relevant, the only place I really went cheap is with the headset - FSA Gravity 1. On a budget and I wanted a KS i900 more than a nice headset. Anyway, thanks in advance for any help.
  83. #483
    Velvethammer: You do not need to worry about corrosion at the headset with carbon. Just press and go.
    "It looks flexy"
  84. #484
    hi guys. wanna try out 2x10 on my nomad c but damn sram made their 2x10 x0 cranks with an other size for the chainguides. So you must take the 3x10 - but can I put every chainring on ? cause wanna swap the 22-33 to 24/36 . does anyone of you guys who is running 10speed know if you need special chainrings for it? or does it work out also with usual 9x chainrings?! for example normal truvativ rings?
  85. #485
    The old
    air/air
    air/coil
    Coil/air
    The New
  86. #486
    Reputation: ThePunisher's Avatar
    Feb 2006
    how do you like that BOS fork boubouleroi?
    were pics taken at a different time? noticed the different saddles.
    nice bike!
  87. #487
    I'm french and i find this bos fork as well as a Fox 36 VAN
    The saddles are différent becquée the wtb syndicate is New
    I've also put the santacruz logo sticker near the headtube
    29 lb or 13,6 Kg
    Frame large 6 lb
    Fork BOS deville 6,3 in or 160 mm *TRC
    Headset christ King red
    Stem DM3 (french brand) 1,4 in or 35 mm
    Easton monkey dh white carbon bar
    Thomson Elite Black Seatpost
    Wtb silverado team syndicate saddle with Ti rails
    Hope tech M4*
    Sram xo red 9v
    Sram xo red triggers
    Jagwire white
    Shimano SLX
    Shimano SLX 22-36
    DM3 carbon bash
    Mavic crossmax SX
  88. #488
    HEY BOUB!
    Nice bike man. Love the build.
    "It looks flexy"
  89. #489
    Oct 2010
    tiens un frenchie !
  90. #490
    I am a Nomad
    Nov 2008
    Hey gticlay, what size chairing did you use upfront with the straitline guide and what cassette on the back?
    Did you have to use narrow or normal chainring outer bolts on the front to attach the bash to the front ring?
    How do you find AM riding with a 1x9 on the Nomad so far? Especially going on uphill technical rocky trails?
  91. #491
    Actually it's 1x10. I'm running the 11x36 with a 32 up front (and the smaller of the two Straitlines). I ride pretty muddy, steep stuff so it's been somewhat hard going for me but I've stuck with it anyway. I think I'm using regular bolts with the Straitline and some wide Raceface nuts with the Gamut bash that is on my Firebird because it's thicker.
    "It looks flexy"
  92. #492
    I'm really curious on the BOS Deville at Nomad.
    Since the improvements when I changed the FOX DHX5air for the BOS Stoy were just amazing, I expect that the transition from FOX 36 Talas to the Deville would cause the same effect. Probably not possible since they both are air forks, but the BOS hidraulic system should make a big diference.
  93. #493
    I am a Nomad
    Nov 2008
    Thanks a lot for the info, mate.
    I have a 11-32 XT cassette on the back and initially I was thinking of putting a 34T front chainring, but on second thought perhaps it would be better to start my 1x9 setup with a 32T front.
    I think it will make my foray into 1x9 a tad bit easier for general AM riding.
  94. #494
    Shut up and RIDE!
    Jan 2005
    Hi! I would like to share some pics of my nomad carbon.
    thanks for looking
    Intense M9
  95. #495
    Reputation: Yippee_Ki_YayMF's Avatar
    Jan 2011
    thanks for looking
    Is there a jealous button I can press somewhere??
    Nice ride.
  96. #496
    Jan 2011
    Does anyone have any photo's and opinions of the stock X0 1x10 Kit? I'm leaning towards getting a Nc with it. Cheers.
  97. #497
    Reputation: wrecker74's Avatar
    Okay, heres a story.......
    Originally ordered a Bullit, which i have bought many parts for (including a 2010 boxxer wc fork). The Bullit order had lots of delays and the shop then asked whether I wanted to take another frame at a discount.
    Having been reading more on nomad c's (yes its a bit of a step up from a bullit!) I decide to order one and take advantage of a good discount.
    Now i'm faced with a dilemma - do i fit the boxxers to the nomad c (?). The head angle might be a bit slack (but form what i've read the talas 180's have a similar A to C distance to the boxxer wc's) but what else?
    SCruz also say "no more than 180mm in their website for warranty etc - but then claim that the nomad c is their strongest frame?)
    Input required from fellow nomad c riders! (i'm going to be mainly using for AM and lite DH duties and I am not a heavyweight rider at 74kg - approx 164lbs)
    Alternative is to ebay the boxxers and get 160mm fox/rockshox.....
  98. #498
    Quote Originally Posted by wrecker74
    If you are stuck with the fork, it's already been done. I think people checked the ATC with the Boxxer vs with a Totem and they are the same. You could lower the front a little bit with the right stem, a low stack headset, and low bars (although only the headset and lowering the crowns on the stanchions will make a difference to your angle).
    "It looks flexy"
  99. #499
    thanks for your input gticlay. What do you think about the 200mm front and 160mm rear - unbalanced to say the least?!!
    I think i'll go with it and see what happens. 8 weeks before the frame arrives - can't wait!
    Cheers
  100. #500
    Nov 2008
    Can't you also decrease the travel on the Boxxer? There's a guy on here that did it with a '09 Boxxer WC, don't know about the newer ones though.
