Results 1 to 6 of 6
    Reputation: heatstroke's Avatar
    Jul 2003
    Cane Creek DB Air Xvol CS - Nomad C, settings ?
    - moved from the suspension forum -
    Any Nomad C riders with this setup ? I've not had much luck finding base tunes for this setup, unless it's identical/similar to the regular DB Air (non CS).
    I've checked other bikes, and the base tune changes slightly between the CS and regular DBAir.
    FYI, AEBikes has some of the lowest prices, with a coupon code just over $520
    Cheers.
    Fence guru
    Nov 2008
    What is the coupon code I'm in the market ...?
    Reputation: expatrider's Avatar
    Feb 2005
    Hsc 0.5; lsc 5; hsr 2.25; lsr 8 is what I settled on. You can use less lsc and lsr because when you turn the cs on, it adds a few clicks worth of each.
    Feb 2005
    Also universal cycles has them - use code VIP15 to get 15% off, and you get free shipping too.
    Jul 2003
    more info
    rmn019284 retail me not website. 5%
    I had success with this coupon . including mounting hardware came to about 540
    Jul 2003
    $667 at Universal, -15% = 566, but they will price match so it will probably breakeven with AEbikes if the shipping adds up to 20USD
  1. Cane Creek DB Air Xvol CS - Nomad C, settings ?
    By heatstroke in forum Shocks and Suspension
    Last Post: 12-03-2013, 07:50 PM
  2. Nomad 2 settings
    By GrantR in forum Santa Cruz
    Last Post: 03-14-2012, 09:34 AM
  3. nomad c cane creek angle set
    By bhigdon101 in forum Santa Cruz
    Last Post: 02-17-2012, 10:01 AM
  4. cane creek double barrel settings
    By sundace in forum Shocks and Suspension
    Last Post: 11-23-2011, 07:19 PM
  5. Replies: 0
    Last Post: 10-29-2011, 06:32 PM
