Results 1 to 37 of 37
    Cane Creek DB Air on Heckler?
    I am looking to replace my horrid Float r shock. I live in NJ and ride just about all terrains on my heckler. I love grinding out long climbs and hitting some XC, but nothing gets me more excited then hitting some fast gnarly downhills and tech stuff (hitting fruita and moab this summer too). I have been looking at all the different options for replacing my current shock and am torn. I keep reading the coil is the route to go and it may be, but will it slow me down a lot with the weight penalty in the climbs. My bike is already a hefty 33lbs. How is the DB air. It sounds like an awesome shock and was wondering how it mates up with the single pivot design of the heckler? Any other opinions or suggestions would be well appreciated... WHAT SHOULD I DO!!!???
    Thanks guys!
    Reputation: jaymo's Avatar
    I would like to know also. I just got the 13 Heckler and love it, but think a sprung rear shock would handle the rocks I see daily.
    Reputation: 11053's Avatar
    You'll get great results from a 2013 RP23 on the Heckler.
    Low volume air can + the ability to tune in low speed compression in trail mode for the climbs is what you need.
    Open it up for the descents and you'll love it.
    RS Monarchs are good too.
    Depending on the year of Float R it's likely you are blowing through travel on big hits and don't have the low speed compression dialed in for the climbs and body movement/weight shifts. It's a good shock, but not very tuneable in stock form.
    CCDBA is an awesome shock, but you don't need it for the Heckler.
    You can certainly get the CCDBA dialed in on that bike, but you would also see a big improvement from the latest RP23 Factory model.
    Reputation: woahey's Avatar
    I've got the Monarch Plus on my Heckler, upgraded from the Float R. It like it a lot. A lot of my local trails are similar in feel to Fruita and Moab and it handles the chunky stuff well. Also, it's good for the days when I wind up climbing for a couple of hours before bombing back down the trail.
    The secret to mountain biking is pretty simple. The slower you go the more likely it is youíll crash.
    - Julie Furtado
    Feb 2007
    Low volume with no ProPedal is the way to go on the Heckler. I have had a Fox DHX5.0 coil, Fox Float R standard can, and Rockshox Monarch RT3 HV and standard cans. The Monarch RT3 standard volume can feels as good as the DHX5.0 coil did, although I miss the easy bottom out adjustment. As long as it's not a high volume canister, the Cane Creek Double Air should be amazing on your bike. Just make sure to take the time to dial it in!
    Reputation: ATXZJ's Avatar
    If I remember correctly, the heckler uses an 8.5 x 2.5 shock, so you have a few options. I ran the marzocchi Roco Air WC piggyback shock on my butcher and liked it quite a bit. The shock was a huge step up from the float and the bike finally felt like it had 150mm of travel. The shock had no pro pedal or platform, but never felt like it wallowed through travel like the float. On downhill sections it soaked up chatter and had enough bottom out resistance for the bigger drops along the way.
    Either way, I think your on the right track buying a CCDB or piggyback for use on a single pivot.
    My 2c
    Mountain at Tree Fort Bikes
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
    Does the dbair actually fit the heckler? Or are there clearance issues with that big air canister which i know is bigger then the coil.
    Ordered the dbair for my heckler
    Good choice!
    Post a few pics and give a ride report once you get it dialed in
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
    I dont have much experience with tuning suspension, hopefully I get the hang of dialing this puppy in quickly. Im leaving on my road trip out west in 2 weeks!
    Ill definitely leave a report on how it feels on the single pivot design for sure.
    I fix choppers
    Reputation: HELLBELLY's Avatar
    I have had Double Barrels on 3 different SC bikes. A Heckler (2.0), a Nomad (1.0) and now my Butcher (DB Air). They are the best shock on the market for Enduro/AM/Freeride/DH or whatever the hell you wanna call your aggressive riding. While I think the DB is great on all of those bikes, the differences are more pronounced on single pivot bikes. I will be very surprised if you don't love it. Cane Creek provides fantastic customer support too. You will be ripping it up in no time.
    "Everything popular is wrong." -Oscar Wilde
    Thats very encouraging to hear! You had the coil on your heckler? Hopefully the air works out well with it.
    I fix choppers
    Quote Originally Posted by Baller30 View Post
    Yeah the Schmeckler had a DB coil. The DB Air feels very similar. I had a Pushed Fox on my Butcher for a year and a half and it was decent especially considering that I scored of eBay for $120. However, the DB Air is at another level entirely. You'll see.
    So my Heckler has transformed in the past couple weeks. Finally got my DBair mounted on in place of my float r. Swapped out my avid juicy 3 brakes for Shimano xt's with 180 icetech rotors front and back. New continental tires all around and converted to tubeless. Blackspire stinger installed. And a KS dropper post. Hopefully she is all set to take on the likes of Moab, Fruita, Monarch Crest, Sun Valley etc.. On my 1 month road trip out west next week.
    Good to hear! Now post some pics........
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
    Jun 2010
    Pics! Pics! Pics!
    Aug 2013
    Thanks guys!
    The ccdb air Santa Cruz heckler combo works like a dream. The shock fits easily into the frame. The ride is improved exponentially
    eb5
    eb5 is offline
    Reputation: eb5's Avatar
    Jun 2010
    Here's what mine looks like I'm still dialing it in, but so far its been an improvement to the Float I blew out.
    Dec 2014
    BUMP!
    Has anyone fitted a CC DBAIR CS or Inline to their 650B Heckler?
    I am looking at replacing the Fox CTD and wouldn't mind hearing your impressions with a Cane Creek setup.
    May 2014
    Quote Originally Posted by _10speed View Post
    BUMP!
    Just tagged you to someone on IG using the DB on his new heckler.
    Dec 2004
    CCDB CS, and its a remarkable improvement and I am still dialing it in...
    Dec 2014
    Thanks for the replies. I did some more searching and it seems nearly everyone has enjoyed great success with the DBAIR CS on their 650B Hecklers.
    I haven't seen anyone on a DBinline yet though.
    Most of my riding is up and down. But I think the DBAIR would be better suited for my bike based on what I like to ride. We have some steep rocky descents and lots of rooty trails.
    Dec 2004
    Should have mentioned that the SC Tech help guys said that they had not done inline testing, but don't see it being as capable as the DB Air CS. I needed two large volume spacers, both per their recommendation and info I found on the CC Lounge.
    Dec 2014
    I ordered the DBAIR CS last night. Good Presidents Day sales everywhere. Take advantage! I'll come back to update this thread after I get a few rides in.
    May 2014
    Sweet. Where did you order from? And what size did you get?
    Dec 2014
    Worldwide Cyclery - 8.5"x2.5" standard can per recommendation from CC + 22.1mm hardware.
    May 2014
    Thanks. do you need new mounting hardware when switching the shock or just doing it to be safe?
    Dec 2014
    Quote Originally Posted by molon_labe View Post
    It might work. CC could not confirm the compatibility. So yeah, playing safe.
    May 2013
    Works for me. Enjoy
    May 2013
    Oh, and I reused the mounting hardware (actually originally from a Fox RP23) and all is fine. This bike rips with the CCDB
    Dec 2014
    So I wanted to chime in on how the DB AIR CS was working on my 2015 Heckler. Well it's pretty much awesome. I've been tuning on it quite a bit. Up and down on all the settings and here is what is working for me:
    85psi - 33% sag - 150 lb rider - no volume spacers
    HSC 1
    LSC 9
    HSR 2
    LSR 9
    I can see how 2 riders would like two separate tunes as you can really use this shock to make the bike ride a number or ways. There is a fair amount of pedal bob while sprinting out of the saddle but for me it has been an excellent trade off as the ride is very plush in rough terrain.
    I'll probably tune on it a little more but I am pretty happy with it for now.
    Reputation: ryanmj's Avatar
    Aug 2014
    HSC 1
    LSC 9
    HSR 2
    LSR 9
    how aggressive do you ride, do you blow through your travel easily?
    I currently have a large spacer and 2 small spacers
    100psi 175 lb rider 30% sag
    Hsc 2.75
    Lsc 11
    Hsr 2
    Lsr 14
    Aug 2014
    Quote Originally Posted by topcatno1 View Post
    what tune are you running?
    Dec 2014
    Quote Originally Posted by ryanmj View Post
    Hsc 2.75
    Lsc 11
    Hsr 2
    Lsr 14
    I started riding the shock with a similar setup to yours at first. I wasn't getting full travel ever. I ended up going down to HSC 1 and it uses full travel without bottoming out. HSR feels just right at 2. My descents are littered with rock gardens. The bike was riding too harsh with the higher LSC/LSR settings. Of course it comes as a compromise. I haven't done any long climbs up forest roads yet on this new tune but I imagine it won't be as efficient. I will say, there is a steep section with a couple of large roots that I managed to climb all the way for the first time - only with this new tune. The rear end was planted and never spun the tire. I was surprised / impressed.
    As far as how I ride, I like fast, flowing descents. The terrain on my local trails is littered with rock gardens and roots but without a lot of drops. jumps, etc.. The shock does move through it's travel quite a bit but I like the active feeling. I feel like I am pretty close to having the shock complete tuned Maybe within +/- 2 on LSC/LSR.
    Aug 2014
    I had a set up similar to yours when I first got the shock but I felt like I was blowing through the travel on jumps and drops so I made some adjustments. It isn't nearly as active now and it I havn't used the last inch or travel so I have some more adjusting to do. I loved how plush it was at first, maybe I should of kept the settings and added some spacers instead of tweaking it. I have the Cs version so im not worried about climbing.
    Dec 2014
    I would drop the HSC a bit if you want to get the rest of that travel.
  1. Cane Creek 110/40
    By kragu in forum 29er Components
    Last Post: 10-21-2012, 07:47 AM
  2. Anybody use a Cane Creek Angleset on their Heckler?
    By Lowkey1505 in forum Santa Cruz
    Last Post: 02-21-2012, 05:49 PM
  3. Replies: 0
    Last Post: 10-29-2011, 06:32 PM
  4. Cane Creek DB Air Can
    By Karve in forum Shocks and Suspension
    Last Post: 06-04-2011, 03:52 PM
  5. Cane Creek AER
    By TheRedMantra in forum Weight Weenies
    Last Post: 05-28-2011, 07:00 PM
Members who have read this thread: 4
