Results 1 to 3 of 3
    Doe!!
    Reputation: Frednic's Avatar
    Can you put a Float RP23 on a 2001 Superlight?
    Can you put a Float RP3 on a 2001 Superlight? I bought a RP23 off of ebay and discovered the eyelet is a smaller size than the original Float RL. Is it possible to make it work on my bike?
    Reputation: Bromine's Avatar
    Yes. You need to order the correct bushings for the shock. Call Fox Shox tech and they can help you out.
    Doe!!
    Thanks a lot. I'll give them a call.
    Quote Originally Posted by Bromine
