Results 1 to 2 of 2
    Oct 2007
    Butcher shock options ?
    recently got a new to me butcher and was thinking of upgrading the standard float R shock. Its marked up with a L rebound tune and a L compression tune. The shock im looking @ is a fox RP23 BV Kashima shock with a M rebound tune and a L velocity tune. The rebound will prob be about the same due to the kashima coating but is a L velocity tune comparable with a L compression tune. In short will the above RP23 suit butcher.
    Thoughts ?
    cheers D
    Reputation: ATXZJ's Avatar
    Congrats on the find!
    Have a butcher as well and the only shortcoming so far has been the float shock. I think your best bet is to contact PUSH and see what they recommend. I'm considering either having PUSH revalve the float or buying another shock from them.
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
