Results 1 to 19 of 19
    Feb 2006
    bullit or heckler
    which is a better all around bike the heckler or the bullit?, which one has a stronger frame?. im 5'7 so what size should i take for the bullit? for the heckler?. im going to be doing trails and some jumps.
    Reputation: daisycutter's Avatar
    Quote Originally Posted by aljonn
    heckler the bullet is not being made this year
    Whoaohohohoh
    Guest
    Well if you can get an older model bullit you should get a medium. I am 5'9 and ride a medium bullit.
    If your going to do some medium size jumps or drops and want to have an all day trail bike the heckler would be just fine for you. If you are going to be doing more freeriding stuff then the bullit is what you need.
    You have to figure out the trail you will be riding and what you want to do with the bike.
    Feb 2006
    Quote Originally Posted by Whoaohohohoh
    does the bullit fit you perfectly or is it a BIT small. because if it is it would be perfect for me. theres not much freeride stuff here but i like the bullit better. it looks like a bike that will give you confidence. is the medium frame and the small frame different because i have seen different looks on the bullit the large and medium has a curve near the seat tower
    The Heckler is a better all around bike and can handle all types of riding. The Bullit can be a good all arounder as well, but is stronger with slacker angles and is better suited for true freeriding than the Heckler.
    Whoaohohohoh
    Guest
    Yea my medium fits me perfectly. I dont have any standover height though, which can be good or bad. The medium, large and x-large will have that bend on the top tube to seat tube. The small will have a straight top tube. The bullit is definately up for abuse and it will take everything that you give it.
    bump and grind
    Reputation: cobym2's Avatar
    Apr 2005
    ditto
    Quote Originally Posted by ronny
    The heckler can even go xc. At the same time, you can slap on a double crown fork and not void the warranty. The bullit is stronger though, for obvious reasons. But I think the heckler is pretty strong enough for anything but sick stunts, especially if you're not a heavy rider.
    Heckler = XC, trail, light FR. Bullit = trail, FR light DH.
    What are you looking at?
    Reputation: R1D3R's Avatar
    Jun 2005
    Quote Originally Posted by keen
    I'd agree with that...
    Orange Heckler
    Blue Pinscher
    Freeriding Feline
    Reputation: SuperKat's Avatar
    Mar 2005
    Bullit/Heckler
    I am 5'7" and have a medium Heckler, HAD a medium Bullit. I used my Bullit for DH runs like Platty and Diablo. I found it a bit heavy for trails here on the East Coast. My Heckler is for that stuff!
    "If you give up your dream, you die."
    Twitter - KIKat1029
    Jun 2005
    if you like a smaller bike run the small. im 5'11 and run a medium. Im right at the top of the size fitting for the frame, but a smaller bike for all around feels good. i come from a bmx background so thats why i prefer a bit more compact bike. I think there is only about 1lb difference in frame weights between hecklers and bullits. the big weight diff is in the builds. I say go bullit.
    Reputation: Sway?'s Avatar
    Feb 2006
    Perfect answer, although a Heckler with take a beating.
    PS... VP Free took the place of the Bullit.
    EDIT: as far as size, 5'7" will be a medium SC anything.
    Good luck
    Quote Originally Posted by Sway?
    Good luck
    Actually, With more reviews pouring in the Nomad may be closer to the Bullit than the Free.
    Feb 2006
    True, if you have no plans to DH.
    FishZapper
    Reputation: NoTreadOnMe's Avatar
    Feb 2006
    Quote Originally Posted by SuperKat7
    The difference in weight is .7 lbs. I doubt the frame made it heavy.
    FishZapper
    Feb 2006
    In my opinion, there is not a more "all-around" bike made than the bullit. I have seen them in XC races and DH races. That says something to me.
    Dont get caught up in the weight game, because the difference between the two is negligable. If you ride a bullit at 6'' with a 5 inch fork up front, the geometry is not slack like an FR bike. It rides like a trail bike and as long as you get one with a platfrom shock, pedaling isnt bad either.
    If i could have only ONE bike for the full spectrum of riding, the bullit would be it.
    Jun 2005
    nothing took place of the bullit,, the bullit will be back
    Cheesiest
    Reputation: intheways's Avatar
    Does anyone use their Heckler for riding lifts on a regular basis?
    I would vote heckler. mine is rock solid, there is only 1lb difference in the frames. the new heckler makes almost 6"s of travel with a dhx. the bullit is a great bike too. but there is just something extra about a heckler i cant explain. you will be super happy with either bike im sure!
