Results 1 to 2 of 2
    Bullit with 5th questions
    Ok well I did some searching but still couldn't figure it out.
    I want to know how it costs to service the 5th element coil shock, I am assuming its probably around 100 dollars or so but would like to know a rough estimate beforehand.
    Also in the rear spacers that hold the end of the 5th element to the frame, one of the spacers spins freely and has a small (very small amount of back and forth movement). The other spacer does not move at all and the spacers at the front of the shock don't move either. All the bolts are tight and I can't get them any tighter. I was wondering if this was normal or not, or if I need new spacers and bushings?
    If I sent in my shock to progressive can they give me all the mounting hardware so that I can put it back on my bike when I get it?
    Thanks in advance.
    TNC is offline
    noMAD man
    Reputation: TNC's Avatar
    I've seen everything from $75-$125. If you tell them what bike your shock was installed on, they can send the new spacers for your bike with your shock. They'll install new bushings in the eyelets of the shock.
