Results 1 to 11 of 11
    Dec 2010
    Building a 2012 Carbon Highball, just bought a XX1 in BB30 - Did I screw the pooch?
    So I'm finally getting around to building the 2012 Highball Carbon I bought on closeout in February.
    I won this auction on E-Bay for an XX1 group, but I just realized it says it's a BB30, and from what I've read, BB30 doesn't work with the Highball.
    I haven't bought a bottom bracket yet, I was thinking Chris King.
    Am I screwed? Do I need to resell the group I just bought, and get a GXP version?
    It says the crankset is " XX1 BB30 156q 175mm crankset"
    This is my first "real" build, so I'm learning by bumping my head....
    Reputation: argibson's Avatar
    Yes, I think you are screwed unfortunately. I am aware of adapter cups to make a regular crankset work with bb30 frame, but not the other way around. Good luck.
    Giant Team Bike & Bean-Marin Co., CA
    https://www.facebook.com/GiantBikeandBean
    Dec 2010
    Thanks... seems like you're right. I'm trying to get him to switch the crank to the GXP. Otherwise, I'll be selling a BB30 group very soon!
    If you got a really good deal, why not keep the group, sell just the crank and BB, and buy the one you need?
    Jan 2009
    Would that work with E13 cups or is the spindle length all wrong?
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Zipp makes a conversion BSA to BB30 bottom bracket...
    Death from Below.
    Quote Originally Posted by Drider85 View Post
    No idea, but you'd want to make sure the diameter is correct as well as the length. Just get the proper crank and bb.
    Im just about to start building my Highball Carbon and there was no rear axle ... which ones fit?
    Is it a thru axle? theres a nice silver nut already in the one side but didnt want to waste time and effort buying the wrong thing.
    Quote Originally Posted by Andrewfuzzy View Post
    Why don't you break out a tape measure and see...or at the very least a camera and show us what you're talking about?
    Ah sorry guys thought being it was a SC Highball thread it was a bit more straightforward
    https://www.flickr.com/photos/11338513@N05/14360165738/
    https://www.flickr.com/photos/11338513@N05/14566865793/
    It's threaded ... But wasn't sure if I just buy an ethru and discard the nut end.
    So it does look like a 142x12 TA. You can confirm by pulling a tape measure between the dropouts. It should be around 140mm between the stepped down faces of the dropouts.
    And, this would be the OE skewer/TA: DT Swiss RWS Thru-bolt 12x142mm Conical Alloy Wheel Skewer from Bike Bling
    Shop around, I think you can find it cheaper.
  1. Largest XX1 Chain ring for 2012 Highball Carbon?
    By DeeZee in forum Santa Cruz
    Last Post: 05-23-2013, 04:06 PM
  2. Building a highball- which of these would you use??
    By imtheant in forum 29er Bikes
    Last Post: 05-12-2013, 05:18 PM
  3. I bought a Highball
    By LvilleFan in forum Santa Cruz
    Last Post: 07-25-2012, 02:08 PM
  4. Replies: 0
    Last Post: 04-23-2012, 09:48 AM
  5. Did I screw up on my new wheels I just bought?
    By trojans1993 in forum Wheels and Tires
    Last Post: 05-15-2011, 09:44 AM
