Results 1 to 2 of 2
    Upset Blur XC seatstay bridge limited tire clearance
    The tire clearance below the seatstay bridge/brace on my mates new Blur XC is extremely limited, does anyone know if SC are going to change the seatstay design to allow more clearance for taller tires and muddy conditions?
    His new Maxxis Larsen 2.0 rubbed on the seatstay brace at about 35psi, had to wear down the centre knobs first before the rub went away...
    If there is a new seatstay design in the pipeline will SC swop out older seatstays to make the change less expensive?
    Just seems like a design oversight as big volume tall tires are becoming more popular.
    Enduro races often end up as mudfests as well.
    I searched this topic but could not find any answers.
    If SC is NOT planning to change the design then what big volume race tires do fit?
    I guess the Blur XC was designed and tested in a dry climate.
    Any help will be appreciated!
    - It's not the destination that counts but how you get there -
    That sounds too tight with 2.0 with tt larsens. Perhaps he should take a picture and send it to santa cruz. His rear triangle could be out of spec. I have a few millimeters with kenda karma 2.0 and those are fairly large volume....but I have not tried tt larsens.
