Page 47 of 62 FirstFirst ... 37 43 44 45 46 47 48 49 50 51 57 ... LastLast
Results 1,151 to 1,175 of 1534
  1. #1151
    Reputation: nightofthefleming's Avatar
    I was planning on eventually replacing my CTD shock with a CCDBA, but after seeing this from Sea Otter, putting one of these on my TRc eventually is the plan now. HI/LOW speed compression, rebound, and a platform lever. All at 368 grams versus the 500 gram CCDBA. Looks like the perfect agressive shock for the TRc.
    Blur TRc pictures-bos-kirk-enduro-shock-600x399.jpgBlur TRc pictures-boss-7-600x399.jpg
    2013 Medium Santa Cruz Blur Trc in Matte/Silver, full XT kit, 1x10 with 32T wolftooth ring, 25 pounds 7 ounces
  2. #1152
    Reputation: Znarf's Avatar
    That KIRK shock and the 2014 Deville 140mm - which is supposed to land at 1800g.
    That´d be really something!
  3. #1153
    Reputation: scfreak's Avatar
    Oct 2007
    Blur TRc pictures
    Low low I got all the normal wear spots cover now
    No noise from the rear D as of yet? You?
    Raced it at Sea Otter his past weekend in Cat 2 XC worked flawless
  4. #1154
    Quote Originally Posted by Znarf View Post
    Yes. Yes it would. Is a price on "Kirk" known yet? Hopefully about same as CCDBA,
    The new float X may have promise. Has:
    bottom out progressiveness
    Bottom out force adjust
    And the ctd lever thingy is on the side so it may be usable (not that i could tell a difference on my XCc)
    Also noticed the new RS Dig damper. I think pinkbike reported it as hi/lo compression adjust. A pike w/ lyrik rc2 controls would grab my attention and save $200 on the BOS (but definitely not compare on the boutique factor).
    believe in yourself! I believe in you!
  5. #1155
    No price stated yet, I will be checking the BOS site daily for when they officially add it to their line up. I am guessing it will be more than the CCDBA, as of now the BOS products are much more expensive, with their VIP'R shock being around 800 US dollars. Maybe they will bring their prices more in line with their competitors when selling in the US market. I have zero interest in the Float X. No hi and low compression adjustment, I'm out.
    EDIT: Just found price for the kirk, $720. So a little more than the CCDBA, but still somewhat reasonable. I'm definitely in.
    Pricing for the entire 2013/2014 product line for the American market:
    » 2013 / 2014 BOS Suspension in North America ? Idylle Air, Idylle RaRe, Stoy RaRe, Void, Kirk, and more - Sick Lines ? mountain bike reviews, news, videos | Your comprehensive downhill and freeride mountain bike resource
  6. #1156
    Reputation: quickneonrt's Avatar
    Bos was on the states a couple of years ago and their pricing was expensive
    2014 Santa Cruz Solo c.
    Moving on to better things
  7. #1157
    Finally found time to build an post my new ride. No idea about the weight, though.
    Frame: Santa Cruz Blur TRc, size XL
    Shock: Fox Float CTD Kashima
    Fork: Rock Shox Revelation RLT, tapered, 140 mm
    Headset: Chris King
    Handlebar: Race Face Sixc Carbon 750 mm
    Stem: Race Face Turbine 70mm
    Grips: ODI TLD
    Saddle: Selle Italia SLR
    Seatpost: Rock Shox Reverb
    Front wheel: Tune King laced to NoTubes ZTR Arch EX Rims with Sapim CX Ray spokes
    Rear wheel: Tune Kong laced to NoTubes ZTR Arch EX Rims with Sapim CX Ray spokes
    Front tire: Maxxis Minion 2.35 Tubeless
    Rear tire: Maxxis Ardent 2.25 Tubeless
    Crank: Sram XX1 32
    Cassette: Sram XX1
    Chain: Sram XX1
    Bottom bracket: Sram
    Rear derailleur: Sram XX1
    Trigger Shifter: Sram XX1
    Front brake: Sram X0 Trail
    Rear brake: Sram X0 Trail
    Front disc: Sram X0 Trail, 180 mm
    Rear disc: Sram X0 Trail, 180 mm
    Pedals: Superstar Components Nano Mag Ultra
    Blur TRc pictures-trc_1.jpgBlur TRc pictures-trc_2.jpgBlur TRc pictures-trc_3.jpg
  8. #1158
    Reputation: zauberer's Avatar
    Nov 2007
    a perfect TRc with top components
  9. #1159
    Reputation: mestapho's Avatar
    Blur TRc pictures
    Nice build. I'm going to guess its around 25.5 lbs. maybe a little less.
    And keep an eye on the drive side lower pivot for the circle crack. You may get a new frame.
  10. #1160
    Just how capable is a TRc? Watch and see
    Anyone else seen this video? It's amazing how capable our bike is. I've only had mine for 3 weeks, and it's already the best bike I've ever owned.
  11. #1161
    Quote Originally Posted by mestapho View Post
    I would guess sub 25
  12. #1162
    Blur TRc pictures
    Thanks for all the positive feedback. I'll put the bike on a scale some day and let you know the exact weight.
    Thanks for the advice on the circular crack. Not to keen on getting a replacement, although 142x12 would be a nice bonus.
  13. #1163
    Reputation: kdiff's Avatar
    I've noticed that I always get dirt that collects here
    ...and was wondering how long until it started to crack. I'm wondering if I can just keep riding it until the new frame colors come out.
  14. #1164
    that's a 2013 frame?
  15. #1165
    Yep
  16. #1166
    Dec 2010
    Quote Originally Posted by kdiff View Post
    Honestly you could wait for the new colors HOWEVER if SC still had your rear triangle in white in stock they will send you that. The only time they replace the whole frame is if they no longer have your matching rear triangle in stock.
  17. #1167
    Reputation: Steve.E's Avatar
    Does anyone have a guess as to when the 2014 models may be coming out?
    I'm wondering if SC have updated the way the lower pivot bolts into the rear triangle. The bonding here is obviously an area that's prone to failure. I think I read someone comment on the Bronson and mention that they've changed how this bolts together, I wonder of the TRc will get this redesign?
  18. #1168
    Dec 2010
    Finally got my replacement frame built up and have put 50 miles or so on it. I gotta say coming from the older 135QR setup to this new 12x142 setup the rear end feels much stiffer! I gives me much more confidence kicking the rear end out and provides better tracking and feedback. I also switched up from a 90mm to 80mm stem and it handles like a surgeons scalpel. I could not be happier with with this bike!
    BEWARE OF GUARD DOG, he will lick you to DEATH!!!
  19. #1169
    May 2013
    This thread gave me some inspiration so here is some back in the form of my new bike. Weight is 10.87kg/23.91lbs.
    Amazing bike.
  20. #1170
    Te mortuo heres tibi sim?
    Threw the Lyrik Solo Air on for a bit - it's normally on the front of a TransAM hardtail that doesn't see much use. I'm either on this bike or my Chromag hardtail msot of the time. Travel is dropped to 145mm. It's white, because when it needed new lowers a while back, it was on a white bike. I'd gladly go for black lowers is someone wants to pony up the dough for them!
    I very much like the Revelation/Sektor Solo Air bastardised fork that's been on there, but wanted to see how the bike felt with the stiffer Lyrik chassis.
    The tweaked Lyrik damper is for sure nice, I far prefer the 6mm allen controlled Maxle vs. the QR version. It's a straight steer tube model vs. the tapered Rev/Sek fork. Not insanely stiffer, but enough so that it's noticable.
    A tapered Lyrik with black lowers would be sweet...
    The only downside is the Lyrik being just shy of a pound heavier, something I can live with for the performances difference. Bike is just over 26# as shown. Going to ride it a bit this way, probably swap back and forth a bit before deciding which fork to keep on there.
  21. #1171
    ^do you have any issues with the compression range on the lyrik now that its lowered? Mine is at 135 and I have basically lost low speed. Need to have it tuned or figure something out for mine... luckily I'm very light and dont need a lot anyway so it still rides great
  22. #1172
    Quote Originally Posted by nightofthefleming View Post
    Not that I've noticed, but have only had one ride on it, in a smooth and fast trail area. A couple rides on the usual chunky trails will let me know if it feels different than before.
    Left them the same as they've been since getting them all dialed in and it felt pretty good. I've also done some shimstack mods and removed the floodgate, which sorta' turns it into a poor mans RC2DH damper.
    Granted, the damping is enough nicer feeling than the Rev/Sek that I've gotten used to, I may not notice those other subtle differences!
  23. #1173
    ahhh I see, I have the RC2DH damper already and am having this problem. Mine rides just great right now, I got lucky that at my weight it rides well even without much range of adjustment on low speed compression. Now to just figure out how to fix it
  24. #1174
    I've got a Totem RC2DH on another bike, and they feel pretty similar. Only running a couple clicks of low and high on both.
    So you feel you've got no adjustment with the Low? Too divy at low speeds, or what? Maybe low oil level?
  25. #1175
    wheelie king
    Reputation: 661lee's Avatar
    Scrub, is that a Turbine stem mounted with negative rise? What length? Thanks.
  1. Replies: 9
    Last Post: 04-14-2008, 01:02 AM
  2. New Blur 4X pictures
    By Banshee Rider in forum Santa Cruz
    Last Post: 02-07-2007, 06:54 PM
  3. BLUR XC Pictures please!!!
    By oscarc in forum Santa Cruz
    Last Post: 05-26-2006, 11:38 AM
  4. Hey need some pictures on blur xc
    By stephanmol in forum Santa Cruz
    Last Post: 10-18-2005, 01:01 PM
  5. Santacruz Blur Pictures
    By Col5 in forum General Discussion
    Last Post: 06-28-2004, 12:20 PM
