Page 42 of 62 FirstFirst ... 32 38 39 40 41 42 43 44 45 46 52 ... LastLast
Results 1,026 to 1,050 of 1535
  1. #1026
    just ride
    Quote Originally Posted by rage-day View Post
    Finally got mine, 25.5lbs, went to the Lakes this weekend and it was rocking
    Attachment 773524
    Wow! Impressive weight with trail pedals, 2x setup, dropper post with HD tires @ 25.5 lbs is very good!
  2. #1027
    May 2012
    Thanks Tjay, I turned into a real weight weenie specifying the build!
  3. #1028
    May 2005
    Blur TRc pictures
    Those that are running the new CTD Fox shock what are your Boost Valve/Velocity/Rebound tunes?
  4. #1029
    Reputation: kdiff's Avatar
    Attachment 773524
    Very nice!!
  5. #1030
    Reputation: zauberer's Avatar
    Nov 2007
    Quote Originally Posted by Gripo View Post
    175/velocity L/rebound M
  6. #1031
    May 2012
    Quote Originally Posted by zauberer View Post
    voilŗ
    Great find Zauberer, I've now got these on mine too, very impressed, quick delivery from France to the UK as well.
    Saved my down tube from a number of rock strikes at the weekend.
    Drilling holes to bolt it to the bottle cage mounts is much better than using the plastic ties provided.
  7. #1032
    Reputation: mestapho's Avatar
    Blur TRc pictures
    Latest incarnation:
    Switched to XT trail pedals. Tired of replacing shredded needle bearings on my Candy 3's.
    2.35 NN front, 2.25 NN rear
    Fox DOSS 5" dropper - needed to have the Command Post Blacklite warrantied for the second time and wanted something new. I was going to get a GD Turbo (primarily for reliability), but couldn't fit their 5" dropper due to the large frame and my short legs. The DOSS barely works, it as low as it can go. Only one ride on the new post and it feels REALLY nice so far.
  8. #1033
    Nov 2007
    Nice! How is the clearance with 2.25 NN in the back? You had 2.35 NeoMoto front and back before right? The 2.25 NN is narrower? How about diamater? NN is smaller too?
  9. #1034
    Quote Originally Posted by pwu_1 View Post
    Yeah, I was running 2.35 NM F/R before.
    There is more clearance with the 2.25 NN both in between the chainstays and in front of the tire. Didn't measure so just by eye.
  10. #1035
    Reputation: quickneonrt's Avatar
    Finally finished mine. Pics to come later
    2013 TRc matte black small
    2013 Fox Float CTD adjust at 130
    RaceFace Sixc cranks 36.24. Bash ring, KMC x10sl dlc chain, Bionicon C-guide
    Twenty6 Ti Prerunner pedals.
    XTR trail brakes 180f 160r, Easton Haven carbon wheels, Specialized Purgatory control 2.2 rear, Eskar2 2.3 front tubeless.
    XTR shadow plus mid rear der, XTR 11-36 cas, XTR front der, XTR shifters
    WTB Devo Ti saddle, KS LEV dropper post, Twenty6 seat clamp,
    Easton Haven carbon bars, Shimano Pro Tharsis grips, Point One stem, Cane Creek 110hs
    Heli tape on cranks and dt, mastic tape on lower link.
    25.06 lbs.
    2014 Santa Cruz Solo c.
    Moving on to better things
  11. #1036
    Wish I could get those in the states
  12. #1037
    Quote Originally Posted by WilliamK View Post
    Well it is interesting to read all the speculation about a new bike etc. It sure will be intense come April. So before the hype re new bikes, new Rockshox forks, new XC dropper posts and the like become a reality, I thought Iíd share some pictures of my bike in its latest guise, as of the last 6 months actually. Before I am totally obsolete.
    To work with the CCDBa I have added a Lyric, solo air with mission control. I have set it at 130mm travel, and that seems to have slacked the bike out to less than 67⁰ now. It sure does feel very nice on the steeps and at speed.
    There is a small loss of small bump compliance; more noticeable at slower speeds and only noticeable at slow speed, once the speed is up it is very sweet indeed. It entices more speed...
    The best way to sum it up is that the bike is just so very composed. And, you can get very aggressive and it maintains an impressive level of composure that is just confidence inspiring and I am sure takes the bike into territory that a 5Ē travel bike has no right in ruling. I love riding it.
    And to repeat what I have said before, the technical climbing is amazing with the rear shock, there is just so much grip, it is a supple grip when tech climbing. I have cleared some pretty rocky and rooty climbs while my mates unclip and I to would have done so previously.
    The bike is a rewarding challenge both up and down. And itís all about the ride, or how rewarding the ride is in the end. For me, itís the beeís knees.
    Happy riding guys.
    Attachment 772954
    Attachment 772955
    Attachment 772956
    You hit the jackpot on thar build - I'm on a blur XCc, 1st gen without tapered head tube, so I'm limited in forks an rear shocks - but if I wasn't I would have mimicked that build on a slightly smaller scale. Insted am Rocking afox 831 and the stock rp23.
    I'm envious of that frame/fork combo! Enjoy it!
    believe in yourself! I believe in you!
  13. #1038
    Dec 2010
    Here is mine. XTR 2x10, Stans Arch EX with Hope Pro II Evo's, Talas 140-110. Here it is after assembly, then jumping it 20 minutes later. Love this bike, I have the XCc as well and its really tough to tell which one is quicker.
  14. #1039
    May 2012
    second stage upgrade
    brakeset
    haven carbon bar
    ks seatpostBlur TRc pictures-20130222_174805-199150020.jpgBlur TRc pictures-20130222_1748151694140502.jpg
  15. #1040
    May 2012
    Nice rig H20-50 , do you use the 110 on your talas, I have a 150-120 and haven't reduced to 120 yet. Only had three rides though and still dialling in.
  16. #1041
    Dec 2010
    Cant say that I have. Iv'e put around 100miles on it so far and still trying to figure out the suspension. I'm more of an aggressive rider and hit anything on the trail so Im trying to find a happy medium for taking hits and still trail riding comfortably. Loving the frame but it does take some getting used to. Im used to standing and riding (bmx racing background) so my ass never touches the seat but this bike just plain handles!
  17. #1042
    Reputation: Steve.E's Avatar
    I took my TRc to Lee Quarry yesterday (small UK trail centre), the place is full of berms and jumps. I've read that everyone says the TRc is hilariously fun at cornering; but until yesterday I'd only ridden mine on natural trails, yesterday I was amazed at how easy the TRc is to lean over in berms, I think I'm pretty good at cornering but how thing this is in berms is like something else! It's as though you get to a point where you think you can't corner any faster and the thing just pivots, feels a bit like playing Wipeout
  18. #1043
    Oct 2011
    When drilling these frames for internal cable routing for a dropper post, where is the best place to place the hole?
  19. #1044
    Reputation: Znarf's Avatar
    You might have to wait quite a while then.
    Take a look at the SC site. They just updated the colors on the trcs.
    White and matte black.
    In my opinion the sleekest and nicest paints SC currently offers.
    Very, very nice IMHO.
    Greetings Znarf
  20. #1045
    Delete please. Double post.
  21. #1046
    May 2012
    Quote Originally Posted by quickneonrt View Post
    25.06 lbs.
    Very nice build , I 'd be interested to see the pictures of the heli tape as I have just used duck tape for the moment until I decide on frame protection.
  22. #1047
    May 2012
    Quote Originally Posted by h20-50 View Post
    So am I and at the moment it is feeling quite a hard ride, but I keep killing my section times on Strava so am not too bothered. The word "handles" is something you will see everywhere in this thread, lot of happy bunnies here!
  23. #1048
    May 2012
    Might be a bit of a pain, but I have just put in a Colorado post code to check delivery cost and it is 25 euros, which is about 33 dollars. Twin pack is 89 dollars, url for the pack is PACK BLUR TR CARBON 2011-2013 - Leoseven
  24. #1049
    I want to play.
    Just under 27lbs. with tube and two CO2 cartridges strapped to the frame.
  25. #1050
    Blur TRc pictures
    Here is mine. I could not wait to ride it so it's 25.5lb in a temporary build.
    Next up a new fork , dropper post and eventually some 650b wheels.
  1. Replies: 9
    Last Post: 04-14-2008, 01:02 AM
  2. New Blur 4X pictures
    By Banshee Rider in forum Santa Cruz
    Last Post: 02-07-2007, 06:54 PM
  3. BLUR XC Pictures please!!!
    By oscarc in forum Santa Cruz
    Last Post: 05-26-2006, 11:38 AM
  4. Hey need some pictures on blur xc
    By stephanmol in forum Santa Cruz
    Last Post: 10-18-2005, 01:01 PM
  5. Santacruz Blur Pictures
    By Col5 in forum General Discussion
    Last Post: 06-28-2004, 12:20 PM
