Page 28 of 31 FirstFirst ... 182425262728293031 LastLast
Results 1,351 to 1,400 of 1540
  1. #1351
    Jun 2010
    Quote Originally Posted by h20-50 View Post
    Are you running it at 150? If so how does it ride?
    I was running mine with a 140 Fox float 32 with a dual air system inside, the Fox stock air spring enters too quickly in its travel, cannot hold anything. So I'd a 518 A2C.
    I used a ZS bottom headset cup.
    I've just added a EC one, 1 cm more, the bike is just better !!! Brillant
    I going to mount a Deville 1'1/8 with the ZS, 530mm A2C+bottom cup.
    I's the best way to ride the trc. It's so well balanced.
  2. #1352
    Reputation: mint355's Avatar
    Mar 2012
    Blur TRc pictures
    Quote Originally Posted by flipnidaho View Post
    Here is mine with a Pike. Only a handful of rides on it but so far so good. Just a little bit more body english when climbing steeps but way better than the Float 32 130mm when the going gets steep and rough The Pike at 150mm (cut, with starnut, axle and crown race) weighed 4.06 lbs. The 32 Float CTD at 130mm that came off the bike weighed 3.97 lbs.
    Sweet TRc flipin. How are you finding the forks @150mm I never liked my fox at 150mm so I'm back down to 130mm seems to be the sweet spot I think... I have pikes on my bronson and they really are the best forks out there.
  3. #1353
    Reputation: flipnidaho's Avatar
    Quote Originally Posted by mint355 View Post
    I'm digging it so far. I actually have another TRc with a 140mm fork which I think is the sweet spot (I like a higher bottom bracket) but wanted to give the 150mm a try. It just takes some tiny adjustments in body position during very steep climbing, but the performance advantages of the Pike over the 32 Float more than makes up for the slight inconvenience.
  4. #1354
    May 2012
    My new to me TRC medium.
    XT brakes, shifters and derailleur. DTswiss wheels. Since I got the bike. I changed out the grip, raceface carbon handle bar, 50mm stem, odi grip, spanks spike pedal and took out the big ring and put a gamut bash on it.
    I drop the chain once, thinking about adding the chainguide to it if the chain drops again.
    Coming from a Blur LTC. This one is so much more fun that the LTC because this one fits me better as my LTC was a size too big for me. I found the TRC has a little bit of bob when pedaling. The LTC on the other hand doesn't have much bobing maybe because the Kashima is so much smoother or the higher leverage shock on the TRC compare to the LTC.
    But overall, This bike is perfect for where I ride and I love it so far.
  5. #1355
    Jan 2013
    hi all,
    has anyone swapped from a Float32 to Float36 or vice versa? is there a remarkable difference? i'm wondering if i really need to upgrade like all the mechanics at my LBS think i should.
    here's a little about myself. i'm a fit 265lbs. i'm 40yo, so i'm not hucking off any huge boulders... i'd say 5' is my max. i run the fork at 130mm. i've got a 203mm rotor up front and have only noticed it rubbing after a long downhill.
    open to all input. thanks in advance...
  6. #1356
    Hairshirt Rider
    Reputation: Loudpawlz's Avatar
    Re: Blur TRc pictures
    Quote Originally Posted by jcsjay View Post
    hi all,
    Yes and yes. You will notice the difference.
    Sent from my SCH-I535 using Tapatalk
  7. #1357
    Reputation: Steve.E's Avatar
    I'm still loving my TRc
  8. #1358
    Mar 2012
    Blur TRc pictures
    Here is an updated pic of my bike I'm getting it ready for a race this week.
    Here is the spec
    Frame - Santa Cruz TRc medium
    Rear shock - Fox Float CTD kashima
    Front shock/fork - Rock shox revelation rct3 140mm
    Handlebars - Truvativ jerome Clementz 750mm
    Stem - Race Face turbine 70mm
    Headset - Cane Creek 40
    Grips - Esi chunky
    Saddle - Fiziki gobi 00
    Seatpost - Thomson
    Front brake -Avid X9 trail
    Rear brake - Avid X9 trail
    Cranks - XX1
    Chain - xx1
    Pedals - xt trail
    Rear derailleur - XX1
    Rear shifter - XX1
    Cassette - XX1
    Front hub - dt 240
    Rear hub - dt 240
    Front rim - Enve Am 650b
    Rear rim - Enve Am 650b
    Spokes - Spiam cx ray
    Nipples - enve brass
    Tyres- maxxis Ikon2.35/ardent race2.20 both 3C TR EXO
    Tubes - Tubeless 2 scoops of stans in each
    Total weight - 24.1lbs
    It's an absolute rocket ship
  9. #1359
    Here is an updated pick with Enve AM 650b wheels and revelations set at 140mm
    hey hey, looks nice! is it 26" rev or 650b version?
  10. #1360
    Here it goes, in XC long distance setup, this bottle cage installed on seatpost is truly nice.
    Probably final iteration before move to 650b... No cracks nor dissbonding yet, so far so good
  11. #1361
    Mar 2012
    Blur TRc pictures
    Quote Originally Posted by osobny View Post
    It's the 650b model...
  12. #1362
    Feb 2014
    Blur TRc pictures
    Did u change the wheel set? Or it comes with it.
  13. #1363
    Dec 2012
    New to me, jusy converted to 650 lb wheels and a 2x10 xt crank. Also pit a 120/150 2014 talas on so it should be the best of botj worls
    Stem thomson
    Bars thomson
    Headset can creek
    Fox talas 120/150
    Xt brakes
    Xt derailuers
    Xt cranks
    Xtr chain
    Xt cassette
    LB carbon wide 650 rims on hope pro evo2s
    Schwalbe racing ralph/rocket ron
    Ks lev dropper
    Egg beater pedala
    Wtb saddle
    Odi grips
    Sent from my GT-I9192 using Tapatalk 2
    Attached Thumbnails Attached Thumbnails Blur TRc pictures-uploadfromtaptalk1400981080857.jpg
  14. #1364
    So how do you like how it rides after the mods?
  15. #1365
    Dec 2012
    Only had a quick spin but it feels amazing.
    Its not night and day but the weight difference in the wheels is very noticable and i hope the roll over will be improved when i get into some rock gardens.
    The longer travel is great, at 150 the front feels a little lighter on steep climps not unmanagble and of course i can drop it to 120.
    Only negative is the fork is used and makes a clunk when i pull ul hard... got some work to do to diagnose that.
    Have some flat pedas and a shorter stem on the way. It will have two personalities for play and racing by swapping out tje dropper/stem/pedals. Hoping it proves to be a true one bike quiver!
  16. #1366
    Reputation: road_donut's Avatar
    Hi All here is my TRc,
    Frame: Santa Cruz TRc + Kashima Shock- Large
    Forks: Fox 32 Float CTD + Kashima 140mm
    Bars: Easton EA70 Riser Bar
    Stem: Truvativ AKA - 70mm
    Headset: Hope
    Grips: Lizard Skin Charger
    Brakes: Shimano XT 180/160mm IceTech Rotors
    Seat: SDG Bel Air RL Cro‐mo
    Seat Post: RockShox Reverb Stealth
    Seat Post Clamp:Santa Cruz
    Shifters: Shimano XT
    Front Mech: Shimano XT
    Rear Mech: Shimano XT Shadow+
    Cranks: Shimano XT - 170mm
    Chain: KMC X10L
    Cassette: Shimano XT 11‐36t
    Pedals: Shimano XT Trail
    Bottom Bracket: Shimano XT
    Wheels: Hope Pro2 – Stans Arch EX
    Front Tyre: Nobby Nic - 2.25
    Rear Tyre: Nobby Nic - 2.25
    I've been riding this for a couple of months now and loving it
  17. #1367
    Reputation: kdiff's Avatar
    Figured I would post a picture of my after work ride. I'm really liking the Pike now that I've put a few miles on it and got it dialed in. This bike is seriously a blast to ride.
  18. #1368
    No TRc on the updated santacruz website, maybe I'm missing something but are we to assume it has been discontinued?
  19. #1369
    I think that's a pretty good assumption. I'm surprised they didn't post a V10 with 27.5's.
  20. #1370
    Quote Originally Posted by kdiff View Post
    How are you liking the DBAir on the TRc? I had one on my previous bike (Tracer VP) and loved it. Seriously considering the DB Inline if I keep my TRc. Are you running the pike at 140 or 150? Sweet setup. I ride Aliso about once a week, demo'd a new Nomad last weekend and took it for a lap at Aliso, super fun bike. Made the rock garden on Rockit feel like a carpet, ha.
  21. #1371
    Nov 2006
    I saw the same thing.... I assume that it is discontinued.... Lucky the ones who got it already and enjoy it
  22. #1372
    Reputation: jazzanova's Avatar
    I wonder if they will offer the remaining frames on sale, like they did 2 years ago.
    Or they might just keep them for warranty replacement.
  23. #1373
    Dec 2012
    Awesome build and weight. I am looking to lighten mine up for xc racing.
    What type of racing arr you using it for and how did you find it?
  24. #1374
    Dec 2012
    Here is the spec
    Grips - Esi chunky
    Seatpost - Thomson
    Cranks - XX1
    Chain - xx1
    Pedals - xt trail
    Rear shifter - XX1
    Cassette - XX1
    Front hub - dt 240
    Rear hub - dt 240
    Awesome build and weight. Im looking to lighten mine up for xc next year.
    What type of racig did you use it for and how did you find it?
  25. #1375
    Mar 2012
    Blur TRc pictures
    Quote Originally Posted by Steineken View Post
    Hi Steineken, I built it up for a point to point stage race 40kms but I ended up racing my bronson c it's a large and more comfortable. Being a medium and I'm 5'11 it's a bit small for me I prefer to take it out on shorter rides. I hope this helps cheers Clint
  26. #1376
    Quote Originally Posted by Bnorthro View Post
    Thanks! I'm loving the DBA! The stock RP23 was an improvement over the stock RP23 on my BlurLT, but the DBA is just so supple when the speed picks up. My one complaint is that I can't fit a waterbottle on it now for shorter rides. If I didn't already have the DBA I would get the DBInline in a heartbeat. The Pike is a 150mm. (The fork before that was a Fox Float 34 160mm lowered to 150mm.)
    I moved to Aliso in mid-January and didn't get a chance to ride for a few months, but I'm loving it now. Funny you demo'd a Nomad, I've been wanting to demo a Bronson on Rockit just to see what it feels like on the 27.5's. Now that I have the suspension pretty dialed my TRc rockets through the rock gardens pretty well. I just don't have the confidence yet to fully let it loose.
  27. #1377
    Blur TRc pictures
    Thanks! I'm loving the DBA! ... Funny you demo'd a Nomad, I've been wanting to demo a Bronson on Rockit just to see what it feels like on the 27.5's.
    Thanks for the info. When I had the Nomad my buddy was following me on his 5010. He's usually a little faster than me and he was blown away with how fast the Nomad was through the rock garden. I usually take the mid/left line and those huge holes at the very end are pretty harsh on my TRc. I wasn't even phased by them on the Nomad, it was crazy. I suspect the Bronson would be between the two. I'm currently debating selling my M9 and TRc and building up a Bronson or Nomad as my only bike. The Path has both for demo btw.
  28. #1378
    Reputation: l.j.silver's Avatar
    Mine....
  29. #1379
    Jan 2013
    what is the shock tune we should be using for the TRc? thinking of going Monarch DebonAir. any thoughts?
  30. #1380
    Reputation: Nico30's Avatar
    Jan 2015
    Cool-blue Rhythm
    Hey Guys,
    I guess I just get one of the very last Blur's!
    I offered me a TRC frame before Christmas.
    The building part is done now.
    Nothing very fancy but It's efficient enough in my opinion (and for now).
    I love the bike.
    I just noticed some flexibility coming from the lower link when I push hard on the pedals while braking. I guess it's normal...
    What do you think?
    Otherwise it feels stiff when I use it.
    Blur TRc pictures-cadre.jpgBlur TRc pictures-v-lo.jpgBlur TRc pictures-v-lo2.jpg
  31. #1381
    Hi Nico30,
    Nice one!
    This is 142model, don't think any flex should be easily feel. If I were you would check immedietly all axles.
    Pay atention do NOT overtighten... service pdf available on santa page
  32. #1382
    Jan 2015
    It just happen when I break from the rear and if I push on the pedal.
    I don't feel any play it only seems to flex. It did the same on my old bike, but I hoped it won't happen on this one!
    I live not far away from the french SC importator. Maybe I should go there and check.
    I don't have any torque wrench for now...
  33. #1383
    some upgrade...
  34. #1384
    Oct 2014
    Quote Originally Posted by Nico30 View Post
    Check and see if your rotors are tight. It could also be play in the brakes.
  35. #1385
    Jan 2015
    I really see the rear triangle moving to the right when the chain is under tension.
  36. #1386
    Jan 2015
    Here is a video.
    Note that the shock is not moving when I do that
    <iframe src="//player.vimeo.com/video/117604570" width="500" height="281" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe> <p><a href="http://vimeo.com/117604570">Blur TRC</a> from <a href="http://vimeo.com/nicolr">Nico LR</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
  37. #1387
    Reputation: mestapho's Avatar
    I had the same issue with my TRc. My crank would actually rub the driveside chainstay during hard climbing efforts.
    I know this doesn't help you, but the Solo is MUCH stiffer. If you are the original owner, just wait for the circle crack
    and warranty it to a newer/stiffer frame.
  38. #1388
    Jan 2015
    No it doesn't help!
    Especially because I bought it new less than one month ago!
  39. #1389
    Reputation: ColinL's Avatar
    Feb 2012
    I assume you've checked that all the pivots are torqued to spec? My new TRa does not move like that. I weigh 190 geared up.
    Don't crank on them for no reason, check the torque like this: Tech Tuesday: Adjust the Pivot Bearings on Any Santa Cruz VPP Suspension - Pinkbike
  40. #1390
    Reputation: macming's Avatar
    Blur TRc pictures
    Here are a few pictures of mine. I'm in the process of rebuild the pivots
  41. #1391
    taste it
    Reputation: craftworks's Avatar
    Good job! still Impressive
    the TRc still one of the great SC rigs
  42. #1392
    Nico30,
    You are overthinkig simple things, I guess. Can you sleep at night?
    It has been said, check pivots... Play is not normal, especially you dont look, pardon, to be heavy giant
  43. #1393
    And one more thing, Nico. Even racing road frame will flex if you hammer it strong while bike is standing stil, on brakes etc etc
    No one designs and builds absolutelly stiff frame cause it would weight double
    Check pivots!
  44. #1394
    Take the same video but this time use a high gear (big chainring / small cassette cog) and no braking. To me it looks like normal lateral flex caused by a high drivetrain torque load, while stationary.
  45. #1395
    Jan 2015
    Check pivots!
    Men, you may be right.
    I got a stressfull job, I managed to be not stressed anymore. And now I got stressed by a bike!
    Anyway when I bought a Santa Cruz I expected to buy engeneering and quality. I'm a bit disapointed. I just wanna know if what i see is normal or not. I'm not pushing hard on the pedals in the video... I'm not trying to break my chain!
    I biked all afternoon today though and, men, it is the best bike I ever owned!
  46. #1396
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    Nico30, I had to watch your video a few times to make certain I understand what you are talking about. I doubt anything is wrong with the frame, so it is just the design of the frame I guess. I have a TRc also, and it is not the stiffest frame I use. I can feel a little flex on the trail, but nothing extreme. As others have said, check the torque and watch for those cracks (though you may never have a problem).
    My main ride is a Blur LTc built big, which is much, much more stiff than the TRc. But then, the LTc is more stiff than a Nomadc or V10c that I have used.
  47. #1397
    Jan 2015
    Quote Originally Posted by clydecrash View Post
    Thanks for your answer.
    I didn't know the LTc was more stiff.
    I have no crack yet! Good thing because I've been riding this bike for less than a month!
    I don't have a torque wrench... That's a shame, I know! I'm gonna get one and check my pivots.
  48. #1398
    I wouldn't bother using a torque wrench, the rating they use 100 in/lbs if I remember correctly) is way OTT and I broke a couple of bolts, 50in/lbs is enough or just go sensibly and use grease and loctite as necessary.
  49. #1399
    Blur TRc pictures
    Quote Originally Posted by Steve.E View Post
    That's the locking bolts not the pivots, but yeah, that's still too high as admitted by SC.
  50. #1400
    Interesting observation. I don't see any reason why the Blur LTc would be stiffer than those others.
  1. Replies: 9
    Last Post: 04-14-2008, 01:02 AM
  2. New Blur 4X pictures
    By Banshee Rider in forum Santa Cruz
    Last Post: 02-07-2007, 07:54 PM
  3. BLUR XC Pictures please!!!
    By oscarc in forum Santa Cruz
    Last Post: 05-26-2006, 11:38 AM
  4. Hey need some pictures on blur xc
    By stephanmol in forum Santa Cruz
    Last Post: 10-18-2005, 01:01 PM
  5. Santacruz Blur Pictures
    By Col5 in forum General Discussion
    Last Post: 06-28-2004, 12:20 PM
Members who have read this thread: 17
