Results 1 to 5 of 5
    Reputation: grahamt's Avatar
    Blur TRc - fox fork travel change question.
    Anyone know whether the 'custom' 130mm Fox 32 CTD fork specced on the TRc can be changed to 140 by simply removing spacers, or is there more required? Presumably its a standard 140mm fork chassis reduced to 130mm. The SC FAQ's say forks can be "extended to 140mm by changing the air spring" - although normally with fox forks all that is required is spacers. Does 'change' in this case mean a new air spring or just change the spacers?
    PAINT IT BLACK
    Reputation: BPSarge's Avatar
    Oct 2007
    It has a 10mm Spacer in the air chamber side. Takes about 20 min to remove with basic tool
    Feb 2013
    So does this means that it is originally a 140mm fork?
    Fox don't make a 130 as standard - so presumably they are 140mm custom modified to 130mm for Santa Cruz.
    PAINT IT BLACK
    Feb 2013
    Thanks for the clarification... just need to clarify this to justify if i need to buy a new fork or not... in this case u saved me some $$$
  1. SID XC travel change question
    By Retro Dude in forum Vintage, Retro, Classic
    Last Post: 12-13-2012, 07:09 PM
  2. 2001 SID XC travel change question
    By Retro Dude in forum Shocks and Suspension
    Last Post: 12-13-2012, 06:34 PM
  3. travel change question.
    By jojokaizer in forum Beginner's Corner
    Last Post: 04-16-2012, 11:26 AM
  4. How bad is it to change fork travel?
    By buddy2525 in forum Shocks and Suspension
    Last Post: 02-18-2012, 09:15 PM
  5. F29RL travel change question
    By lolaralph in forum Shocks and Suspension
    Last Post: 12-11-2011, 12:32 PM
