Results 1 to 8 of 8
    Tear it all out! SuperModerator
    Reputation: CraigH's Avatar
    Blur seat post shim (30.9mm OD) Anyone make one?
    I'm looking for a seat post shim with an OD of 30.9mm so I can continue to use my RaceFace post with a 27.2mm OD.
    Does anyone make a 30.9mm to 27.2mm seat post shim?
    Quote Originally Posted by CraigH
    USE makes them. USE is a UK company, so I'm not sure the best (i.e. cheapest) place to get them in North America.
    I see that Excel Sports lists them on their website:
    http://www.excelsports.com/new.asp?p...vendorCode=USE
    Cambria also has them on their website, but they only list the 25mm ID version. USE also makes a 27.2 ID version, so you might give Cambria a call and see if they can get it.
    http://www.cambriabike.com/seatposts...ucer_shims.htm
    http://www.cambriabike.com/seatposts/seatpost.htm
    Otherwise, you can order them from several different UK websites:
    http://www.wiggle.co.uk/v2_product_d...dID=5300002210
    http://www.chainreactioncycles.com/v...ms&ModelID=820
    USE's website:
    http://www.use1.com
    Problem Solvers also makes a shim...
    I stumbled across these when I was looking for something else. It looks like Problem Solvers also has a 30.9 to 27.2 mm seat post shim, and it's a bit cheaper than the USE shim. Bikeman has them on their website:
    http://www.bikeman.com/miva/merchant...Code=COMPSPSHM
    Also, it is worth noting that Bikeman sells the 30.9mm Thomson post for $59.95, so that might be an option as well.
    Thanks! That looks like what I was looking for.
    I just couldn't recall the manufacturers name, which makes searching difficult.
    Found another one.
    Tamer makes them.
    http://www.nashbar.com/profile.cfm?c...ype=&estoreid=
    27.2mm ID by 30.9mm OD
    Nashbar has them on sale for $7.95
    Since Nineteen Forgotten
    Reputation: RiftZone's Avatar
    Found another one.
    Tamer makes them.
    For $7.95 that's a bargain, but I already got mine though. Ordered the USE one (27.2mm to 30.9mm) which is made of thermoplastic and in black for $12.00 w/free shipping from speedgoat. But, I really like the USE shim being made of plastic, makes it easier to use without excessive grease on the post. They are durable too, have one on another bike for 4 years.
    "No, it's not Ron Jeremy in tight Lycra Shorts"....
    Reputation: Dogboy's Avatar
    Cane Creek too!
    www.canecreek.com
    I bought one but didn't end up using it, so if anyone needs one...
  1. Seat post clamp size for a 31.6 post?
    By AMcK in forum Weight Weenies
    Last Post: 01-19-2004, 09:27 AM
