Results 1 to 9 of 9
    Blur LTC Reverb cable routing
    I was kind of surprised to see the dropper post cable routing on my new 2012 Blur LTC uses cable stops instead of housing guides. Any good solutions for Reverb hydro cable routing? I tried Shimano cable stop to cable guide adapters (Universal Cycles -- Shimano Hydraulic Line Guides) but they wouldn't stay put. Problem Solvers makes a more secure version but it doesn't look like it will work well with the beveled exit of the cable stop. Are stick on cable guides worth trying? Or route it down with the rear brake cable?
    MountainGoat aka OldGoat
    Reputation: pachaven's Avatar
    Dec 2005
    The best way is zip ties to the other cables. That's what I did on my TBc and my TBLTc.
    Vote with your feet.
    No bike is perfect!
    Reputation: TwoHeadsBrewing's Avatar
    Do you mean you don't want to use zip ties?
    "Got everything you need?"
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    I feel your pain. Always thought those cable stops were a bit of a head-scratcher. Its such a shame to have to zip tie the cable to the frame or patch together a routing solution on that masterpiece of a frame. could have been so neat and clean if they were cable guides. I know its not worth getting worked up over but just would have been nice.
    Yeah, obviously zip ties are the way to go but I thought I was getting a frame with dedicated dropper cable routing so it could have been cleaner.... It's still an amazing frame I got at a great price so I'm stoked overall.
    Ah, I think I understand. Could you possibly drill out the cable stops and use hose/cable ferrules? I did this on my old Cannondale frame so I could make an uninterrupted cable run for the rear derailleur.
    RTM
    RTM is offline
    #1 Latex Salesman
    Quote Originally Posted by TwoHeadsBrewing View Post
    I bet that could work. I have an extensive tool set and am very comfortable with power tools. But man, i don't think I could take a drill to that frame!
    May contain nuts
    Reputation: Haggis's Avatar
    Drill it. Early TBc frames were the same - takes a steady hand, some good cutting bits & a flexible hand-piece and then some filing to finish. The stops are aluminium and you need to take care not to overheat the epoxy.
    Reputation: flyinmike's Avatar
    Dec 2005
    If you don't want to drill.. these could work --> RockShox Reverb Hydraulic Tubing Frame Guide | RockShox | Brand | www.PricePoint.com
    Rock Shox Reverb dropper post frame guides
  1. Ideal Reverb cable routing 2010 DW Spot
    By empy in forum Turner
    Last Post: 05-10-2015, 07:28 PM
  2. SX Trail Reverb Cable Routing
    By citizenlee in forum Specialized
    Last Post: 10-19-2012, 03:29 AM
  3. Endorphin reverb cable routing
    By jubilee in forum Knolly
    Last Post: 02-11-2012, 11:46 AM
  4. Cable routing for Rockshox Reverb on a Tracer
    By brenrub in forum Intense
    Last Post: 11-02-2011, 04:39 AM
  5. Reverb cable routing on Firebird?
    By istvisinet in forum Pivot Cycles
    Last Post: 03-06-2011, 01:38 AM
