Results 1 to 10 of 10
Thread: Blur LT Squeak
    Reputation: Allamuchy Joe's Avatar
    Blur LT Squeak
    Okay -- I am going nuts here. My wife's Blur LT2 developed a very annoying intermittent squeak. It doesn't matter if she is pedaling or not, so that lead me to believe it was the suspension. But I am not sure now.
    Chasing this squeak, I have so far:
    1) Removed pivots, cleaned dirt, greased and reinstalled
    2) Rebuilt RP2 shock (new seals)
    3) Greased the head tube bearing shoulders
    4) Removed bottom bracket bearings, cleaned & greased threads, reinstalled.
    5) Took seatpost out, cleaned and reinstalled. (The seatpost is a Specialized Command Post II and the bike squeaks with the post up or down)
    6) Replaced her Terry Butterfly with a new Terry Butterfly seat.
    Still the squeak persists. And, to make matters more of a pain in the butt, it doesn't happen all the time. Most of the time, it seems to happen after she has been riding for a while (15 minutes+). Ugh. It is so annoying, she is starting to use her older bike instead.
    Does anyone have any other suggestions?
    Thanks,
    Joe
    Reputation: repoman's Avatar
    Possibly the DU bushings on your rear shock mounts.
    I fix choppers
    Reputation: HELLBELLY's Avatar
    I had the same problem with my Butcher and thought it was the bearings, but in fact it was the bushings in the linkage. I pulled everything out, cleaned, rotated them and all is well again.
    "Everything popular is wrong." -Oscar Wilde
    Pivot bearings
    At my case it was first time the upper pivot small bearing (other pivots have bigger size). Another time it was lower pivot bearings. They don't last forever, just change new set of bearings. During 4 years I've changed everything twice. If you hear the sound while you are standing, then it is not saddle or post. If you hear it when on seat but not weight in pedals, then it is not BB, pedals or chainrings. --> Pivot bearings, hub bearings (not likely), shock pushings. At my case, I have heard excess sound from all of those at some point
    Ps. It can be also fracture in alu frame or swing
    Reputation: kubikeman's Avatar
    Jun 2010
    Chasing down squeaks and creaks can drive you to insanity. More places to look:
    rear derailleur mount - make sure it's tight
    hubs - I had a set of Azonic outlaws and the end cap/seal was the culprit
    break rub - Avid brakes?
    Good luck
    The cake is a lie.
    Reputation: sooner518's Avatar
    another 2 places to look:
    pedals
    chainring bolts.
    Thanks everyone -- gives me more places to look. :-)
    It is not making the noise now, of course. It waits until we are a few miles into the woods first -- I think the bike got jealous when she demo rode the new Niner Jet RDO.
    Quote Originally Posted by HELLBELLY View Post
    By Jove, I think you got it. The squeak has been banished! The bushing on the shock was cruddy. I cleaned it and the squeak has not returned.
    I have had FS bikes for a long time, and this is the first time I had to clean the bushings on the shock.
    Thanks for your help everyone!
    Apr 2005
    Check this out:
    http://www.austinbike.com/repairs/11...shock-bushings
    Big improvement for my blur lt2
    Austin Mountain Biking and worldwide travel pictures:
    It could be both your cable rubbing against each other , which is tightly held by a bloody cable tie.
  1. my cranks squeak
    By SuperMtbDude in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-06-2013, 09:35 PM
  2. TB Carbon Squeak!!
    By rivertrash in forum Santa Cruz
    Last Post: 08-03-2012, 07:19 AM
  3. fork squeak; LBS won't help
    By zerohnine in forum Trek
    Last Post: 03-10-2012, 06:01 PM
  4. found my squeak
    By Joe Mama in forum Turner
    Last Post: 12-27-2011, 06:18 PM
  5. EX 8 Squeak
    By building_miracles in forum Trek
    Last Post: 07-13-2011, 06:17 PM
