Results 1 to 2 of 2
    Reputation: henryl's Avatar
    Blur LT frame vibrating from brake - fixes?
    New alum Blur LT frame with my old components switched over. The rear brake wants to vibrate/squeal but this did not happen on my old Giant Reign with the same brakes (saint 810's). Set up as follows:
    Saint brakes
    185mm shimano rotor (not bent)
    tried metal and resin pads with no luck
    DT 240 hub with RWS thru axle
    Anyone else have this issue? Any fixes? Thanks.
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Nope, haven't had that before.
    Few things to try (and probably the order I'd follow):
    1. Realign the caliper using Hope's methods (not the "squeeze the lever and tighten the bolts" crap)
    2. Clean your piston's to make sure that they move freely and evenly
    3. Get the IS tabs faced.
    4. Replace (or at least try different) rotors
    My gut tells me that after steps 1 and 2, you'll be good . . . if not, then 3 should do it. However, you might need to try different rotors (if you have a spare, you might try that first actually). Some combo's just create a buzz.
  1. Speedball / Joplin Fixes
    By ramelzer in forum Maverick
    Last Post: 11-12-2015, 04:16 PM
  2. Front Derailleur rubs rear tire, fixes?
    By Kyuusei in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-09-2012, 05:24 PM
  3. XO front brake vibrating
    By circlesuponcircles in forum Brake Time
    Last Post: 08-03-2012, 01:55 PM
  4. Squealing / vibrating rear brake
    By bank5 in forum Brake Time
    Last Post: 11-02-2011, 12:08 PM
  5. Difficulty to Swap Blur XC Frame to Blur XC Carbon
    By alanmeyer in forum Santa Cruz
    Last Post: 06-10-2011, 10:59 AM
