Results 1 to 7 of 7
    Blur LT: carbon v. alum swing arm
    Santa Cruz just warrantied my broken aluminum swing arm, and they are sending me a carbon swing arm as a replacement. Does the rear (XT) brake attach the same way to the carbon swing arm? Or do I need to buy some kind of spacer?
    Are there any other differences between the two swing arms?
    Thanks.
    Reputation: dansMTB's Avatar
    brakes mount the same.
    Thanks dansMTB.
    The Blur LT2 lower link diagram says:
    P/N [08-11903] APPLY GREASE TO SHAFT, APPLY
    LOCTITE(242) TO THREADS. LIGHTLY TORQUE
    TO 35 IN/LBS TO REMOVE PLAY. 2 PLCS.
    ...in reference to the pivot axle collet bolt. What does "2 PLCS" mean?
    Dec 2005
    uh, 2 places.
    here we go again
    I guess omitting the A and an E saves a lot on ink?
    By the way, the carbon swing arm has a different derailleur hanger than the aluminum swing arm. So if anyone gets a carbon swing arm as a replacement for an aluminum swing arm, they should ask Willie to sell them a spare derailleur hanger and include it in the box.
  1. Blur LT2: second broken swing arm
    By happyriding in forum Santa Cruz
    Last Post: 10-27-2013, 05:53 AM
  2. Replies: 6
    Last Post: 06-07-2013, 08:58 AM
  3. Mach 5.7 Carbon or Alum?
    By yangpei in forum Pivot Cycles
    Last Post: 05-02-2013, 09:57 PM
  4. Carbon HT or Alum FS to replace my Alum HT Frame
    By TwoNin9r in forum 29er Bikes
    Last Post: 03-16-2012, 09:09 AM
  5. From Steel to Alum (or even Carbon)?
    By Casual Observer in forum 29er Bikes
    Last Post: 02-25-2012, 05:02 PM
