Won't actually be 'set up' for a couple of days; but, looks really sweet out of the box! 5.68 lbs. More to come. Thanks Zach at Competitive Cyclist.
Cheers.
Cheers.
That is pretty porky. It was only supposed to be 5.6 lbs! Here's a photo courtesy of Competitive Cyclist.dogo said:you lucky bastard, but cmon 5.68lbs? Thats kinda heavy!
Ahh the .08lb is the seat post clamp and the dust on the framem_driscoll said:That is pretty porky. It was only supposed to be 5.6 lbs! Here's a photo courtesy of Competitive Cyclist.
What did you think of your test ride?Pedalhead said:Steve, tell us more!
Awesome, that's what I really liked about the BLT, it felt really connected to the trail, but at the same time with a feeling of having a good amount of travel available if needed. Bearing in mind the traits of carbon over alu, I wouldn't be surprised if this one felt even more so.smittylube said:>>>but also felt tighter...not as plush<<<
I'm telling you the 'feedback' feel was unlike anything I had ridden before. I really think it will be unreal in the technical trails. Much more than the plush or pogo of my vanilla.
The other thing I dont know if you caught was how much rear susp travel there was (or I used) . I think it will even climb better with it setup slightly stiffer/ more air psi in the rear...
steve
Im nor trying to turn this into a carbon vs.. thread, but this frame is claimed to be significantly stronger than its alu counterpart (which I have LT2 'a' XL Ano Black)Gripo said:I'm curious as to what you think the LT2c will be of benefit to you over a more durable alloy frame.
I don't doubt the outright strength of carbon but could see an issue with durability/longevity. True about it's strength, how long has it been used in the aerospace industry or sports like F1/Moto GP etc. but then how often is a carbon component replaced in those arenas?Huck Banzai said:Im nor trying to turn this into a carbon vs.. thread, but this frame is claimed to be significantly stronger than its alu counterpart (which I have LT2 'a' XL Ano Black)
My experience with carbon, and exposure to it in diff applications agrees with that, as do the engineers.
Maybe Im misinterpreting, in which case - oops, but it just seems a casual allusion to a commonly held, but incorrect, belief that carbon/thermo-plastics are weaker or more prone to failure than aluminum when the opposite is true.
Yup, I agree 100%.Huck Banzai said:Im one that would prefer a matte finish, but you cant stop the sexiness that is the BLT
