FAT BIKES
WINTER APPAREL
TRAINERS
Page 43 of 47 FirstFirst ... 33 39 40 41 42 43 44 45 46 47 LastLast
Results 1,051 to 1,075 of 1154
  1. #1051
    What are you guys doing to protect the low hanging pivot? Mine took a direct hit on Saturday
    Also thinking of throwing some innertube on the link area behind the bb to cut down on mud buildup in there.
  2. #1052
    Reputation: Pau11y's Avatar
    Quote Originally Posted by sonic reducer View Post
    Cytoe plate.
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    ╭∩╮( º.º )╭∩╮
  3. #1053
    Reputation: BTTR's Avatar
    Jun 2012
    I have a kit from Amygos AMYGOS - Blur LT carbone
    If you just want to protect the VPP then you just need this AMYGOS - Protection biellette pour Santa Cruz Blur LT (not sure if the carbon version is any different)
  4. #1054
    Reputation: sooner518's Avatar
    Got the new Pike today. Install was a breeze. Took it for a quick ride. Sooooo plush. Love it.
  5. #1055
    Re: Blur LT Carbon Setup Thread
    Quote Originally Posted by Pau11y View Post
    Cytoe plate.
    Does he make plates for the BLTc? They all seem to be mounted using water bottle mounts on the down tube, which my BLTc doesn't have.
  6. #1056
    Quote Originally Posted by thepotatokid View Post
    I used dual lock, a 3M product, and backed it up w/Velcro straps.
    Did you click on that link I posted earlier? You can see how I looks on the BLTc.
    ╭∩╮( º.º )╭∩╮
  7. #1057
    Ah, right - had a look. Looks like a good solution.
  8. #1058
    BTW, that dual lock stuff doesn't really need the two velcro straps...it's some stouty stuff! I use it alone on my Jedi to hold the Jedi's Cytoe plate on...
    2014-Canfield-Jedi Photo Album - Pinkbike
    Just get the surface warm, stick it on, roll out the air bubbles, and done.
    ╭∩╮( º.º )╭∩╮
  9. #1059
    In terms of aesthetics, I think the dual lock without velcro straps would work better. That's great advice - thanks for that.
    Does the plate act as a mudguard for the bottom part of the linkage? Seems to be a bit of a mud magnet down there...
  10. #1060
    Mud, rocks, all except light dust.
    ╭∩╮( º.º )╭∩╮
  11. #1061
    Here's mine - running XT drivetrain, RS pikes, reverb post and Stans Flows on American Classic hubs.
    Got 60mm stem on there at the moment - think that's the right length.
  12. #1062
    Hi everyone - so I have a stupid question that I absolutely cannot locate the answer to. SC's site no longer has any info about the LTc, and I'm getting different answers from both the bike seller and Joe at SC Tech Dept.
    I'm currently shopping a 2013 SC BLTc, and can't figure out the rear axle setup. Did the frames come with a 12x142? 12x135? 10x135? Also, for the rear....does SC use a thru-axle or thru-bolt?
    13' Should have the 12x142 dt swiss rws thru axle. If not actually a 13 then it will have a quick release 135.
    Quote Originally Posted by chrisingrassia View Post
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    I bet it is a 12x142 since it is a 2013 (but do not hold me to that). I do not think they ever had a 12x135. Do you need to know before you buy? Even if you get one with a 10x135, you can always use a thru-bolt or bolt-on with the correct hub. That is what I do.
    Oh, and the 12x142 comes with its own bolt (or should). The 10x135 will be whatever hub you have--QR, thru-bolt, bolt-on.
  15. #1065
    Quote Originally Posted by xhailofgunfirex View Post
    Quote Originally Posted by clydecrash View Post
    Thank god I spotted this in the ad pictures. He had the bike listed as a 2013 Blur LTc, but I asked for pics of the rear axle setup. Sure enough, the frame has standard dropouts and he was running one of those 5mm skewer QR's. Total fail.
    Thanks a lot for your help guys, I relied on your knowledge as the basis for challenging him. Hope someone else doesn't get ripped off for $3500 and then find that little surprise.
  16. #1066
    Quote Originally Posted by schnell318 View Post
    Updates:
    - 1x10 drivetrain: OneUp 42 tooth cog and Race Face 32 Narrow/Wide
    - Monarch Plus RC3
    How do you find the monarch shock? Much on an improvement on the original shock?
  17. #1067
    Anyone had 650b fork on their Bltc and still running 26" wheels? Would be great to hear what it's like as I won't have a new frame for a few weeks and pikes are getting cheaper! ( would be the 160mm pike but lowered to 150 ) currently running a 36 float at 150mm with a 1.5 degree minus Angleset
  18. #1068
    You know, the qr dropout frames are really pretty stiff too when you run a bolt on wheel. Yes there is a small weight penalty and pulling the wheel takes slightly longer. But they don't command a premium like the thru axle frames do.
  19. #1069
    Jun 2012
    Mine in her last incarnation... she inherited the carbon wheels from the Nomad C
  20. #1070
    I have leftover custom Amygos frame protectors from my sold Blur LTc frame. Let me know if you are interested.Blur LT Carbon Setup Thread-th_img_9952.jpg
  21. #1071
    Jun 2012
    Since you've dug this up here's how my BLTc currently is. Got her an Inline a few months ago.
    Still love to take her for a ride sometimes.
  22. #1072
    Quote Originally Posted by dukemasterpro View Post
    How did the 36 perform w/ the angleset? I've shorten mine to 140 and have a -2* Works headset but haven't had time on the bike yet...friggin' Colorado is turning into Oregon w/ the damn rains!
    I stuck on a pair of Conti TK 2.4s...they're like only 1/4" short of a 27.5 HR2 2.3s in diameter.
    ╭∩╮( º.º )╭∩╮
  23. #1073
    Quote Originally Posted by tonik666 View Post
    I have leftover custom Amygos frame protectors from my sold Blur LTc frame. Let me know if you are interested.Click image for larger version.
    I'm interested... PM'd.
  24. #1074
    May 2015
    Can anyone illustrate how to tell the difference? I'm looking at a used one, and the seller says it's a 2013 but after reading this post I've done about an hour of research and it looks like the bike may not have the new style through axle.
  25. #1075
    How about asking the seller directly? They will be noted as either 135x10 Or 142x12 qr and thru axle respectively.
    Qr dropouts are a slot that is vertical on the frame and the rear axle is part of the wheel and slides into them vertically. On a thru axle the dropout appears as a round hole in the frame, the wheel has the same thru hole and the axle slides through all.
Follow MTBR on Facebook
