Page 39 of 47 FirstFirst ... 29 35 36 37 38 39 40 41 42 43 ... LastLast
Results 951 to 975 of 1157
  1. #951
    Reputation: TwoHeadsBrewing's Avatar
    Quote Originally Posted by sooner518 View Post
    im kinda having the same problem. right now, i just have the cable routed below the top tube, but above the shock. im thinking ill just cut the full length housing, and use the cable stops that are there, i just havent gotten around to it.
    You can use the stops and cut the cable housing, or you could also use these little guys:
    Universal Cycles -- Sram PitStop Rotating Dual-Line Hooks
    If you have a front derailleur cable going through the other stops, just clip those to the housing.
    "Got everything you need?"
  2. #952
    My aluminum frame cracked, so I had Santa Cruz upgrade me for a few bucks to the Blur LTc. Just got it back from the shop today, and I'll be hitting the trails tomorrow. Setup as pictured is 28 lbs. 10 oz., weighed on the shop scale. Not too bad considering the dropper post and some meaty 2.4" Purgatory carcasses on there.
    Specs:
    Frame: 2012 Blur LTc Medium, Matte Carbon and Silver
    Fork: Revelation RL Solo Air 150mm
    Shock: Fox RP23 Kashima
    Drive Train: Shimano XT 2x10
    Wheelset: Shimano XTR Trail
    Tires: Specialized Purgatory 2.4
    Brakes: Shimano XT
    Seatpost: KS LEV 100mm 30.9
    Saddle: WTB Volt Race
    Stem: 80mm Easton Haven
    Bars: 711mm Easton Haven
    Grips: ODI Ruffian
    Pedals: Shimano XT Trail
    Gotta love the clutch mech:
    Due to the strange cable stops for the dropper post routing, I made some cuts in the housing for the KS LEV. Came out pretty clean!
  3. #953
    Reputation: dytrdr5's Avatar
    Mar 2006
    Hello all, I am hoping you guys can give me some information on sizing. I have a 2012 blur lt carbon sitting here in front of me, it was to be my wive's new trail bike but due to some circumstances it's going to be either sell it or built it up for myself. I am 5'6" and I do prefer smaller bikes but was wondering if this would be too small.
  4. #954
    Medium would fit, but you're right on the edge of small/medium. If you prefer smaller frames, go with the small size.
    Quote Originally Posted by dytrdr5 View Post
  5. #955
    May 2012
    M 5.6", own blt alu M and blur trc small bfore. My blt m good in climbing tarmac road and trc blur good in aggresive decsending(easy in manover n flickable) but on road i need to push my ass behind. Choose the size depends on your riding style.
  6. #956
    Sucks to see the Blur LTC drop out of the Santa Cruz lineup. I'll be enjoying mine for many years to come if it holds up. Right now I don't have any desire for bigger wheels but a short shocked 650B conversion might be a nice option in the future.
  7. #957
    Mar 2006
    I went ahead and just built it up, I really like the way it feels.
  8. #958
    Gangreen
    I've been through the 650b conversion experiments, and once the dust settled, the LTc with 26" wheels is by far the best trail bike I've ever ridden. I see no reason to change anything. I admit I was a bit shocked to see it dropped, but understandable from SC perspective. We're officially retro-grouches!
  9. #959
    LOL, full suspension carbon fiber frame dropper post riding retro-grouches. I like it!
  10. #960
    What are you 5'10"-5'11" guys on large frames running for stem length?
  11. #961
    Blur LT Carbon Setup Thread
    Quote Originally Posted by kan3 View Post
    50mm Thomson x4 is great, much more stable bike on steep rollers than a 65mm 5 deg rise. Running 720am answer carbon barsBlur LT Carbon Setup Thread-imageuploadedbytapatalk-21372293235.105905.jpgBlur LT Carbon Setup Thread-imageuploadedbytapatalk-21372293287.230740.jpg
    Also have 2 degree angleset offset cups
  12. #962
    Quote Originally Posted by dukemasterpro View Post
    50mm Thomson x4 is great, much more stable bike on steep rollers than a 65mm 5 deg rise. Running 720am answer carbon barsClick image for larger version.
Name:	ImageUploadedByTapatalk 21372293235.105905.jpg
ID:	811349Click image for larger version.
Name:	ImageUploadedByTapatalk 21372293287.230740.jpg
    Oops forgot to mention forks are 36 float lowered to 150mm travel
  13. #963
    5'11"
    60mm stem
    725 race face sixc
    Revelation rlt ti 150........ Trail destroyer
    Plans for Xfusion vengeance 160hlr
    750 bars........... Hopefully am machine
  14. #964
    Actually brain fart -I'm 5 ft 8.5 but found a medium blur lt too be too short in the top tube with a 65mm 5 deg stem and sketchy with an 80 mm 5 deg hence the upgrade to a larger frame with short stem
  15. #965
    Reputation: Southbay Bomber's Avatar
    I dropped down to a 65mm until I went with a wider bar, now I'm running a 50mm.
    I still feel like a large frame is a touch big for me. A medium Bronson or Solo may be next.
  16. #966
    Quote Originally Posted by sra1218 View Post
    5'11"
    60mm stem
    725 race face sixc
    This is what I actually planned on starting with. 60mm stem on a 725 bar and 150mm fork. I have 50, 60 and 90mm stems but no 70 or 80mm.
  17. #967
    Reputation: CrozCountry's Avatar
    Mar 2011
    Large frame with 140mm X-Fusion Velvet (almost the same axle to crown as fox 32 150mm)
    Raceface Next 725mm carbon bar 3/4" rise
    90mm 5 degree stem with 1/2" spacers under
    Feels little cramped but I got used to it (my other bike is a shorter DJ and does not feel as tight, go figure).
  18. #968
    007
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    As an aside, but to others who may be reading, I rode the BLT2 with a 150mm Fox Float for a long time, and it was good. Dropped it to 140mm and its excellent. All aspects of handling are spot on with the shorter travel . . . more stable up hill, and way more precise downhill.
  19. #969
    I'm really interested to get a 160mm fork on my LTc. At this point, I think I'll wait for the X-Fusion Slant. 34mm stanchions, 15mm thru, and comes in a 130/160 travel adjust(DLA). A few stores have them listed, but they are not in stock yet. Pretty competitive pricing at around $700, especially when comparing the Pike and Fox 34 CTD forks at ~$1000.
    http://www.xfusionshox.com/product/f...t-rl2-dla.html
    WANT: Universal Cycles -- X-Fusion Slant RL2 DLA Fork 2013
  20. #970
    Gangreen
    5' 10", running a 55mm with a 750mm wide bar. Love it!
  21. #971
    Really nice setups, will post mine as soon as itīs finished.
    I see some of you are running XT/XTR trail pedals... was wondering what (enduro, AM, trail) shoes you would recommend for those pedals. Donīt mean to hijack the thread but havenīt found any info regarding this.
  22. #972
    RTM
    RTM is offline
    #1 Latex Salesman
    Reputation: RTM's Avatar
    Quote Originally Posted by schnell318 View Post
    I've been wearing the shimano sh-m162 for about a year. Really like them.
    "The bitterness of poor quality remains long after the sweetness of a low price is forgotten." - Benjamin Franklin
  23. #973
    Few updates on my Blur so I thought I would post a new picture. The 2014 damper on the fox floats is a massive improvement.
    Attached Thumbnails Attached Thumbnails Blur LT Carbon Setup Thread-blur.jpg
  24. #974
    Reputation: J0hnnie's Avatar
    Jul 2013
    Nice
  25. #975
    Jul 2013
    Can I use this rear shock on 2012 Blur LTC?
    Sent from my iPhone5 using Tapatalk
