• 02-21-2013
    Le Duke
    Hmmm. Good point about the BB height. I ride a HT 29er as my "main" bike, but it has a fairly normal BB height. This would push the BB higher than that, and stepover height might be a little too high with 650b.
    I'll look into it.
  • 02-21-2013
    CrozCountry
    My LTc has 1CM lower BB height with fat 26" tires. Skinnier 650B tires will probably not even get it to spec, at least nothing that fits in the back. There is also little gain in wheel diameter to be had.
    Measure your BB height.
  • 02-21-2013
    Le Duke
    Currently in AFG. I have the frame, fork, hubs, crank, etc. Nothing put together, so I couldn't measure anything even if I was in the country.
    But, you're saying that something like a 2.35 will only be 1cm lower than a 650b tire?
    Seems like there's not much of a discernable size difference, and parts availability will be much better with 26" wheels.
  • 02-22-2013
    mestapho
    Blur LT Carbon Setup Thread
    I'm running a 2.35 Nobby Nic and it measures about 28.75 inches in diameter. So there can be quite a difference from a 26".
  • 02-22-2013
    zelak999
    [QUOTE=TwoHeadsBrewing;10182285]I've been really happy with the e*Thirteen TRS+. It's what comes stock on the higher end Santa Cruz packages, and it's a pretty slick setup. Shark fin to keep the chain from dropping off the small ring, roller/guide to keep it from dropping off the top. And it has a taco bash guard underneath to save your big ring. Kind of a pain to get the spacing right, but once you do you just forget it's there and go ride.
    That looks cool, Is the E13 BB Mount? What year is your Blur LT?
  • 02-22-2013
    TwoHeadsBrewing
    The guide comes in either BB or ISCG mount. My Blur is the 2012 model, so since it has ISCG tabs that's what I got.
  • 02-22-2013
    CLMcLovin
    I've built two Blur LTC's with 650's, one for me and one for my buddy and we absolutely love them. To me, the increase in bottom bracket height went unnoticed after a ride or two but the increase in wheel size is definitely appreciated. I thought the 650 idea was stupid for a while (before I tried it) because it seemed like a minimal increase but you definitely notice it. My Tallboy C used to be my go-to bike when I had 26" wheels on my Blur but I hardly ride the Tallboy anymore.
    As for bottom bracket height, mine is rougly 13 7/8" unloaded. My tires both measure about 27 3/4" tall (Ardent 2.25 and WTB Race 2.2).
  • 02-22-2013
    nowshon
    Le Duke: I just built a new LTc with a "dedicated" 650b front end (fork + wheel) and 26" rear (literally just picked it up, so no pics yet). I've experimented with a 650b Pivot Firebird conversion (front and rear) and found no perceivable downside as far as BB height. Maybe I'm just not good enough of a rider to sense the height increase, in which case, ignorance is bliss. However even the Firebird with it's massive tire clearance would only accept a Neo Moto 2.3 in the back and the tire just felt undergunned for SoCal conditions.
    So I'm starting out with a 26" rim shod with a nice big Purgatory 2.2. I'd like to go for a bigger volume tire but for now it will do. BTW, the new bike has a Cane Creek 40 series headset...trouble free, nice looking and less expensive than the top drawer stuff. Pics to follow soon.
    EDIT: Finally got a ride in on the 650/26 BLTc. Front end feels tall, light and a bit "floppy". I think it would be better with a 650b on the back, but that isn't in the cards for now. Back to a 26" front wheel for now.
  • 02-22-2013
    CrozCountry
    Yes and Yes. In my current 26x2.4 rear there is half inch clearance in the swingarm. If you go with a bigger wheel you still need some clearance, so that distance can go down to 1/4". This will also raise the bottom 1/4 inch (6mm). Since the bottom is already lower than spec by 1 CM, you still end up in a bike that is lower than the website charts.
    That brings to your second point: There is not much difference in wheel diameter. There is a price to pay: Less parts availability and deals, less tire clearance for mud (I currently have 1/4" mud in swingarm), less rear travel, etc.
    If you are into 650B a good buy is the X-Fusion Velvet fork, designed for 650B with no clearance issues.
  • 02-23-2013
    Le Duke
    How much clearance do you have between the rear tire and frame at full compression?
  • 02-24-2013
    Rhood14
    Hi, Im new to the site... just thought id post up my planned build. Im currently riding a 2011 santa cruz butcher. I was planning on getting one more year out of it until i saw the carbon blur frames on sale for such a steal! i plan on weighing my butcher before i build up the blur frame so i can see the weight diffrence. Anyway, Here is my planned build. Everything has been shipped and now im just doing the wonderful waiting game!
    2012 Blur LTC (large)
    Fox Float 36 160 forks...(open bath, have been Pushed)
    Fox CTD rear shock
    Stans Flow rims laced to Chris King hubs
    Avid elixir 7 brakes( 180 or 160 on front and 160 rear)
    Continental Mountain king Protection tire...(tubeless 2.2 rear and 2.4 front)
    shimano XT crank (with single 34 tooth ring)
    strait line AMP pedals
    XTR 10 speed chain
    XT shadow pus medium cage rear derailleur
    xt 10 speed shifter
    xt cassette
    x-fusion hi lo post
    SDG FXR seat
    Chris king headset
    Funn Funnduro stem
    ODI ruffian lock on grips
    Im sure i left off something... and i apologize for the random parts list in no particular order... what would you guys think the bike will weigh around using those parts??
  • 02-24-2013
    CLMcLovin
    Fox CTD rear shock
    XTR 10 speed chain
    xt 10 speed shifter
    xt cassette
    x-fusion hi lo post
    SDG FXR seat
    Chris king headset
    Funn Funnduro stem
    I'd guess 28ish.
  • 02-24-2013
    mestapho
    Originally Posted by CLMcLovin View Post
    I'd guess 28ish.
    I have similar build on my TR at 28 lbs. You lose the 1.5ish lbs over me going 1x10 so that
    about cancels out the frame weight. I'd say you're just above 28 lbs.
  • 02-24-2013
    Rhood14
    Awesome! Thats around what i was hoping for... i really wanted a bike that climbs better than my butcher and a lighter build. Ive still got my 150mm revelation dual air forks i can throw on if i feel the 160s are to much. My butcher weighs 32.6 lbs on a bathroom scale so im definitely hoping to drop 4 lbs and a bit of it will be tire weight. Right now im running 2.2 and 2.4 trail king ust tires. Stupid heavy!!! Front tire is 1100 grams alone and the rear is around 850 i believe. With the mountain king protection tires im lookin at dropping up to 1 1/2 pounds of tire weight. Anyways... thanks for the response ill keep it updated once my parts start arriving!
  • 02-26-2013
    Le Duke
    Does anyone have any data on how much the Burgtec offset bushings a) change head angle for one vs. two bushings (you can do one bushing, or both bushings, correct?) and b) change total suspension travel?
    I'd like to go 650b, drop the BB a hair, and still maintain the vast majority of the 140mm of rear wheel travel.
  • 02-28-2013
    Will Murderface
    Le Duke - I have one offset bushing (Proshox) in and the BB is between 13.4" and 13.5" depending on the tire profile/tread. I'd guess the HA is pretty close to 67*, but haven't confirmed it with a trust worthy tool. No difference in ride quality to me, and certainly no frame clearance issues.
    Anyway, here's mine:
    2012 Large Blur LTc
    2012 Fox 36 Float RLC set at 150 mm with PUSH'd high volume piston kit (hooray for full travel)
    XT cranks, 175 mm
    Time ATAC carbon body pedals
    36 tooth E13 ring
    Shimano 10 speed medium cage XTR clutch derailleur (<-- best thing since toilet paper and tampons)
    XT cassette 11 X 36
    XCX ST E13 chain guide
    XT brakes (not current gen, but previous model I believe), 160 mm rear, 180 front
    DT Swiss 5.10D hoops laced to 440 rear and Hadley front
    WTB Silverado saddle
    KS 950r dropper post
    Race Face Atlas bar cut down to 760 mm
    Thomson X4 50 mm stem
    Fox Float CTD Kashima shock
    Forte Pisgah 2.3 rubber, front and back
    Checks in at a hair over 29 lbs. Could lose weight with the wheels & tires, but the dam rims won't die, and I'm not a fan of most narrower profile tires. Like to rock a carbon bar, but most of the wider models I'd prefer are way pricey. Great bike overall, especially for the sale price.
  • 03-12-2013
    Alan-S
    2012 Medium Blur LTc
    2012 RS Revelation Dual Position Air 150mm
    Chris King Headset
    Truvativ Stylo Cranks 22-32-Bash, 175 mm
    Crank Brothers Candy 1
    SRAM X0 Rear Derailleur 9-Speed
    Sram 990 11-34T
    Sram X0 Shifters
    Magura Marta SL Brakes 160 mm rear, 180 front
    Stans Olympic ZTR 355 hoops laced to Chris King Hubs
    Fizik Gobi Saddle
    Thomson Elite Seat Post
    Easton Haven Carbon Low Rise Bar
    Thomson X4 70 mm stem
    Ardent 2.25 front, Ignitor 2.1 Rear, Tubeless
  • 03-16-2013
    Alan-S
    25.6 lbs ^^^
  • 03-17-2013
    polymathic
    Anyone went from the original RP23 to a new Kashima CTD Trail Adjust on their Blur LTC? Is it worth the upgrade? Thx.
  • 03-17-2013
    CrozCountry
    My aluminum frame had RP23 and the LTc I got to replace it came with CTD. It was only $50 more than RP23 when you buy a frame. Much better shock, I got my $50 worth.
  • 03-19-2013
    Pau11y
    Just messing around...
    I haven't ridden it yet...maybe this wknd. But the new numbers look very interesting, yeah? :)
    Blur LTc - unshimmed...
    HTA: 69*
    BB: 13 3/4"
    160mm by Fox 36, and 140mm by Monarch RC3+, 2.4 Conti TK rear tire
    Attachment 782630
    Blur LTc - shimmed down...
    HTA: 67*
    BB: 13 3/8"
    140mm by Fox 36, and 126mm by Monarch RC3+, 2.2 Conti TK rear tire
    Attachment 782633
  • 03-19-2013
    nowshon
    Yes indeed. Looking forward to results. Are those wheels set up tubeless? I'm curious how the Reynolds work -do they hold air and not burp as well as Stans?
  • 03-19-2013
    nowshon
  • 03-19-2013
    Pau11y
    The Reynolds I have on there are the older MTN-C Specials that were being sold for $575 on Chainlove about a year ago. They came w/ qr and 15mm qr. But I found that you can get some DMR Revolver endcaps and turn them 20mm.
    The rims are NOT designed to be tubeless...no bead shelf. But I slapped in some Stans rubber strips and they seal up beautifully.
    Now, I'm looking for rear end caps to turn them into 142mm TA...but I don't think they'll go :/
  • 03-19-2013
    CrozCountry
    HTA: 69*
    BB: 13 3/4"
    How did you get 69* with 160mm fox 36 and that shock? Shouldn't it be slacker than spec (68) which is with a shorter fork?
