Page 18 of 24 FirstFirst ... 8141516171819202122 ... LastLast
Results 851 to 900 of 1158
  1. #851
    Reputation: CrozCountry's Avatar
    Mar 2011
    Don't most reigns come with fox shocks? Are those shocks working better with the maestro?
    Having had RP23 and CTD on the BLT, CTD > RP23. Better say, CTD >>>>> RP23. I never liked the 23.
  2. #852
    please delete. Thanks!
  3. #853
    a question to anyone who has ridden an aluminium nomad as well as a blur lt carbon.
    which one is a stiffer frame?
    think clyde and XL frame with a 160 lyrik, and I'm trying to figure out which one would be more suitable in terms of stiffness.
    hope I'm not hijacking.
  4. #854
    Reputation: grahamt's Avatar
    Quote Originally Posted by p_cycle View Post
    I've had Aluminium and Carbon Blur LT's and a Carbon Nomad, all with similar builds (aggressive AM build with 36's up front), and ridden alloy nomad. Both carbon bikes were a bit stiffer than the alloy versions, although not that much that it really made a huge difference. At the end of the day weight and geometry were the deciding factors for me. I currently back on the Blur LTc as I prefer the shorter wheelbase and handling. Easier to pop off things and more fun. Nomad was more point and shoot.
    PAINT IT BLACK
  5. #855
    Ow!
    Reputation: clydecrash's Avatar
    Apr 2005
    I have 2007? Nomad (Marz 66 RC2 170mm/Fox DHX 5.0 coil) and a Blur LTc (Marz 55 Micro Ti 160mm/Manitou Evolver). The LTc, to me, is much more stiff than the Nomad, and the Nomad is very stiff. I have never ridden a more stiff bike, especially in the rear triangle, than the Blur LTc.
    But, I think they are different bikes for different uses. I find my LTc is more fun on my trails, which do not have extended downs, but lots of rocky ups and downs. Of course, it is fun to take the Nomad on these same trails--as grahamt said, more p and s.
    You are not considering a Nomadc? Just a stiff as the LTc maybe.
  6. #856
    nomad c is way off budget.
    ltc is within reach only because of the current sale.
    I was thinking ltc, with an internal lower cup headset for my 160 1 1/8 lyrik, would keep geometry at around 150 normal headset equivalent and the rigidity of the 35mm fork. concerned about the seat angle with a 160 fork and that it will sit way into the travel.
    no extended downs here as well, but plenty rocky.
  7. #857
    That's effectively my current setup but with 36's. You wont regret it.
    PAINT IT BLACK
  8. #858
    Ow!
    Apr 2005
    Quote Originally Posted by grahamt View Post
    Do you mean zero stack when you say internal? I am considering replacing the EC bottom with a ZS. I think this will work since my fork has a 1 1/8" steer tube.
  9. #859
    Quote Originally Posted by clydecrash View Post
    I've got a zero stack ZS reducer with 1 1/8 steerer.
    PAINT IT BLACK
  10. #860
    zero stack is what I meant indeed.
    ZS49/30 by cane creek to be exact. specs say 4mm height for the lower cup, and the sc official geo accounts for a 529 A-C and 15mm lower cup height.
    so in paper we have only 5mm increase in total stack with a 545 A-C 160 fork.
    pretty close I guess and grahamt verifies that.
  11. #861
    Ow!
    Apr 2005
    I have decided to change to a ZS. Thanks for the replies.
  12. #862
    NoC
  13. #863
    blur ltc large
    RS Revelation Dual Air RLT Ti 150mm
    Fox Float ctd Kashima
    Mavic Crossmax St Wheelset
    Avid Elixir Brakes
    Sram x0 shifters
    Sram x9 Rear Mech
    Sram x7 Front Mech
    Shimano slx crankset
    Specialized Command Post Blacklite
    Raceface Sixc Bars
    Shimano trail spd pedals
  14. #864
    Mar 2012
    Can anyone recommend a chain retention device for a 2 x 10 chainset om my 2011 Blur LTc?
  15. #865
    Quote Originally Posted by zelak999 View Post
    Does your 2x10 setup have a bash guard or no?
    i use a blackspire stinger bb mount on my 2x9 setup but i believe it requires a bash guard.
  16. #866
    Ow!
    Apr 2005
    I use the Bion. C-guide on my LTc. It is working very well so far, but I would not be surprised if it gets ripped off on some ride. I use a bash/32/22 crank. Search the forums for other discussions on its use and failures. If you are using a double crank (no bash), I think MRP has made a device. Check them and the Santa Cruz site for info.
  17. #867
    Mar 2012
    Im using a XT M785 double crankset with 38 & 26 rings.
    Im not keen on the Bionicon and would rather get a E13 style thang.
  18. #868
    It appears your cranks are non bash compatible. The ltc doesn't have iscg mounts (unless you have the one they just released), so a bottom bracket mount is the only possibility. Don't Know of any that work without a bash guard. Have you considered trying a clutched rear derailleur like the shimano shadow or sram type 2. i hear they work pretty dang good.
  19. #869
    Quote Originally Posted by sra1218 View Post
    Here is a solution
    Blackspire - C4 SuperGod | Blackspire
    Blackspire - STINGER | Blackspire
    You need the bb stinger
  20. #870
    Ow!
    Apr 2005
    Well, a BB mount can work, but you cannot really get the roller above the bottom of the crank (which you want to do). Others have used the stinger or similar, and kind of bashed the roller into the chainstay. There are some other threads on this.
    I tried the shadow + on my XC HT which has a double crank. It worked OK, but it made the rear shifting not as easy (I use XTR shifters). I ended up turning the + off, and, yes, using a C-guide. But some really like the +.
    ISCG mounts on the new LTc. Hmmm. Maybe they changed the chainstay a little so that a retention device works better. I seem to remember that Santa Cruz said on their site before for the "old" LTc that is wasn't really designed for a chain retention device.
  21. #871
    Yeah im not sure how they pulled it off but i know the new one has iscg mounts, angled grease ports to prevent damage, and a 142mm thru in the rear. I have heard they only added the 142 due to customer demand, and that they didn't even really notice a difference between the standard quick release and the 142 thru. Id love to have iscg on my blur ltc but it could be worse. Have you though of tryign the sram type 2 over the shadow? I love the feel of the x0 shifters. I bet paired with a type 2 would be pretty darn good.
  22. #872
    Mar 2011
    I will notice the difference every time the rear wheel moves in the dropout and the disc starts rubbing.
  23. #873
    Formerly of Kent
    Reputation: Le Duke's Avatar
    Starting to get parts together for my Blur LTc build.
    So far:
    Blur LTc frame w/CTD Kashima shock - Size Small
    DT Swiss EXM 150 carbon tapered
    DT Swiss 240s 15mm front, 10mm rear
    X9 crank w/ Chris King BB
    Still deciding on 26" vs. 650b. Got plenty of time to do it, though. That's one good thing about being deployed to AFG. I can hunt for deals and make better decisions than I might make back home.
    Also: Anyone have any good ideas for a zero stack, light weight headset that will fit this frame?
    Death from Below.
  24. #874
    007
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    Quote Originally Posted by Le Duke View Post
    So far:
    Personally, there is no way I'd convert the BLT2 to a 650b. Lots of folks have and very few have stuck with it. The BB height is what kills it for most.
    As for a headset, can't go wrong with Cane Creek or Chris King.
  25. #875
    Reputation: TwoHeadsBrewing's Avatar
    I've been really happy with the e*Thirteen TRS+. It's what comes stock on the higher end Santa Cruz packages, and it's a pretty slick setup. Shark fin to keep the chain from dropping off the small ring, roller/guide to keep it from dropping off the top. And it has a taco bash guard underneath to save your big ring. Kind of a pain to get the spacing right, but once you do you just forget it's there and go ride.
    Universal Cycles -- E-thirteen TRS+ Dual DMB Chain Guide
    "Got everything you need?"
  26. #876
    Formerly of Kent
    Hmmm. Good point about the BB height. I ride a HT 29er as my "main" bike, but it has a fairly normal BB height. This would push the BB higher than that, and stepover height might be a little too high with 650b.
    I'll look into it.
    Death from Below.
  27. #877
    Mar 2011
    My LTc has 1CM lower BB height with fat 26" tires. Skinnier 650B tires will probably not even get it to spec, at least nothing that fits in the back. There is also little gain in wheel diameter to be had.
    Measure your BB height.
  28. #878
    Formerly of Kent
    Currently in AFG. I have the frame, fork, hubs, crank, etc. Nothing put together, so I couldn't measure anything even if I was in the country.
    But, you're saying that something like a 2.35 will only be 1cm lower than a 650b tire?
    Seems like there's not much of a discernable size difference, and parts availability will be much better with 26" wheels.
    Death from Below.
  29. #879
    Reputation: mestapho's Avatar
    Blur LT Carbon Setup Thread
    I'm running a 2.35 Nobby Nic and it measures about 28.75 inches in diameter. So there can be quite a difference from a 26".
  30. #880
    Mar 2012
    [QUOTE=TwoHeadsBrewing;10182285]I've been really happy with the e*Thirteen TRS+. It's what comes stock on the higher end Santa Cruz packages, and it's a pretty slick setup. Shark fin to keep the chain from dropping off the small ring, roller/guide to keep it from dropping off the top. And it has a taco bash guard underneath to save your big ring. Kind of a pain to get the spacing right, but once you do you just forget it's there and go ride.
    That looks cool, Is the E13 BB Mount? What year is your Blur LT?
  31. #881
    The guide comes in either BB or ISCG mount. My Blur is the 2012 model, so since it has ISCG tabs that's what I got.
  32. #882
    I've built two Blur LTC's with 650's, one for me and one for my buddy and we absolutely love them. To me, the increase in bottom bracket height went unnoticed after a ride or two but the increase in wheel size is definitely appreciated. I thought the 650 idea was stupid for a while (before I tried it) because it seemed like a minimal increase but you definitely notice it. My Tallboy C used to be my go-to bike when I had 26" wheels on my Blur but I hardly ride the Tallboy anymore.
    As for bottom bracket height, mine is rougly 13 7/8" unloaded. My tires both measure about 27 3/4" tall (Ardent 2.25 and WTB Race 2.2).
  33. #883
    Gangreen
    Le Duke: I just built a new LTc with a "dedicated" 650b front end (fork + wheel) and 26" rear (literally just picked it up, so no pics yet). I've experimented with a 650b Pivot Firebird conversion (front and rear) and found no perceivable downside as far as BB height. Maybe I'm just not good enough of a rider to sense the height increase, in which case, ignorance is bliss. However even the Firebird with it's massive tire clearance would only accept a Neo Moto 2.3 in the back and the tire just felt undergunned for SoCal conditions.
    So I'm starting out with a 26" rim shod with a nice big Purgatory 2.2. I'd like to go for a bigger volume tire but for now it will do. BTW, the new bike has a Cane Creek 40 series headset...trouble free, nice looking and less expensive than the top drawer stuff. Pics to follow soon.
    EDIT: Finally got a ride in on the 650/26 BLTc. Front end feels tall, light and a bit "floppy". I think it would be better with a 650b on the back, but that isn't in the cards for now. Back to a 26" front wheel for now.
  34. #884
    Mar 2011
    Yes and Yes. In my current 26x2.4 rear there is half inch clearance in the swingarm. If you go with a bigger wheel you still need some clearance, so that distance can go down to 1/4". This will also raise the bottom 1/4 inch (6mm). Since the bottom is already lower than spec by 1 CM, you still end up in a bike that is lower than the website charts.
    That brings to your second point: There is not much difference in wheel diameter. There is a price to pay: Less parts availability and deals, less tire clearance for mud (I currently have 1/4" mud in swingarm), less rear travel, etc.
    If you are into 650B a good buy is the X-Fusion Velvet fork, designed for 650B with no clearance issues.
  35. #885
    Formerly of Kent
    How much clearance do you have between the rear tire and frame at full compression?
    Death from Below.
  36. #886
    Feb 2013
    Hi, Im new to the site... just thought id post up my planned build. Im currently riding a 2011 santa cruz butcher. I was planning on getting one more year out of it until i saw the carbon blur frames on sale for such a steal! i plan on weighing my butcher before i build up the blur frame so i can see the weight diffrence. Anyway, Here is my planned build. Everything has been shipped and now im just doing the wonderful waiting game!
    2012 Blur LTC (large)
    Fox Float 36 160 forks...(open bath, have been Pushed)
    Fox CTD rear shock
    Stans Flow rims laced to Chris King hubs
    Avid elixir 7 brakes( 180 or 160 on front and 160 rear)
    Continental Mountain king Protection tire...(tubeless 2.2 rear and 2.4 front)
    shimano XT crank (with single 34 tooth ring)
    strait line AMP pedals
    XTR 10 speed chain
    XT shadow pus medium cage rear derailleur
    xt 10 speed shifter
    xt cassette
    x-fusion hi lo post
    SDG FXR seat
    Chris king headset
    Funn Funnduro stem
    ODI ruffian lock on grips
    Im sure i left off something... and i apologize for the random parts list in no particular order... what would you guys think the bike will weigh around using those parts??
  37. #887
    Quote Originally Posted by Rhood14 View Post
    Fox CTD rear shock
    XTR 10 speed chain
    xt 10 speed shifter
    xt cassette
    x-fusion hi lo post
    SDG FXR seat
    Chris king headset
    Funn Funnduro stem
    I'd guess 28ish.
  38. #888
    Quote Originally Posted by CLMcLovin View Post
    I'd guess 28ish.
    I have similar build on my TR at 28 lbs. You lose the 1.5ish lbs over me going 1x10 so that
    about cancels out the frame weight. I'd say you're just above 28 lbs.
  39. #889
    Feb 2013
    Awesome! Thats around what i was hoping for... i really wanted a bike that climbs better than my butcher and a lighter build. Ive still got my 150mm revelation dual air forks i can throw on if i feel the 160s are to much. My butcher weighs 32.6 lbs on a bathroom scale so im definitely hoping to drop 4 lbs and a bit of it will be tire weight. Right now im running 2.2 and 2.4 trail king ust tires. Stupid heavy!!! Front tire is 1100 grams alone and the rear is around 850 i believe. With the mountain king protection tires im lookin at dropping up to 1 1/2 pounds of tire weight. Anyways... thanks for the response ill keep it updated once my parts start arriving!
  40. #890
    Formerly of Kent
    Does anyone have any data on how much the Burgtec offset bushings a) change head angle for one vs. two bushings (you can do one bushing, or both bushings, correct?) and b) change total suspension travel?
    I'd like to go 650b, drop the BB a hair, and still maintain the vast majority of the 140mm of rear wheel travel.
    Death from Below.
  41. #891
    Nov 2008
    Le Duke - I have one offset bushing (Proshox) in and the BB is between 13.4" and 13.5" depending on the tire profile/tread. I'd guess the HA is pretty close to 67*, but haven't confirmed it with a trust worthy tool. No difference in ride quality to me, and certainly no frame clearance issues.
    Anyway, here's mine:
    2012 Large Blur LTc
    2012 Fox 36 Float RLC set at 150 mm with PUSH'd high volume piston kit (hooray for full travel)
    XT cranks, 175 mm
    Time ATAC carbon body pedals
    36 tooth E13 ring
    Shimano 10 speed medium cage XTR clutch derailleur (<-- best thing since toilet paper and tampons)
    XT cassette 11 X 36
    XCX ST E13 chain guide
    XT brakes (not current gen, but previous model I believe), 160 mm rear, 180 front
    DT Swiss 5.10D hoops laced to 440 rear and Hadley front
    WTB Silverado saddle
    KS 950r dropper post
    Race Face Atlas bar cut down to 760 mm
    Thomson X4 50 mm stem
    Fox Float CTD Kashima shock
    Forte Pisgah 2.3 rubber, front and back
    Checks in at a hair over 29 lbs. Could lose weight with the wheels & tires, but the dam rims won't die, and I'm not a fan of most narrower profile tires. Like to rock a carbon bar, but most of the wider models I'd prefer are way pricey. Great bike overall, especially for the sale price.
  42. #892
    2012 Medium Blur LTc
    2012 RS Revelation Dual Position Air 150mm
    Chris King Headset
    Truvativ Stylo Cranks 22-32-Bash, 175 mm
    Crank Brothers Candy 1
    SRAM X0 Rear Derailleur 9-Speed
    Sram 990 11-34T
    Sram X0 Shifters
    Magura Marta SL Brakes 160 mm rear, 180 front
    Stans Olympic ZTR 355 hoops laced to Chris King Hubs
    Fizik Gobi Saddle
    Thomson Elite Seat Post
    Easton Haven Carbon Low Rise Bar
    Thomson X4 70 mm stem
    Ardent 2.25 front, Ignitor 2.1 Rear, Tubeless
    Attached Thumbnails Attached Thumbnails Blur LT Carbon Setup Thread-photo-1.jpg
  43. #893
    25.6 lbs ^^^
  44. #894
    Threading freely...
    Reputation: polymathic's Avatar
    Oct 2010
    Anyone went from the original RP23 to a new Kashima CTD Trail Adjust on their Blur LTC? Is it worth the upgrade? Thx.
    Threading lightly and respectfully wherever I want....
  45. #895
    Mar 2011
    Quote Originally Posted by polymathic View Post
    My aluminum frame had RP23 and the LTc I got to replace it came with CTD. It was only $50 more than RP23 when you buy a frame. Much better shock, I got my $50 worth.
  46. #896
    Reputation: Pau11y's Avatar
    Just messing around...
    I haven't ridden it yet...maybe this wknd. But the new numbers look very interesting, yeah?
    Blur LTc - unshimmed...
    HTA: 69*
    BB: 13 3/4"
    160mm by Fox 36, and 140mm by Monarch RC3+, 2.4 Conti TK rear tire
    Blur LTc - shimmed down...
    HTA: 67*
    BB: 13 3/8"
    140mm by Fox 36, and 126mm by Monarch RC3+, 2.2 Conti TK rear tire
    Naysayers never apologize. Critics go to their grave thinking everyone else is wrong.
    ╭∩╮( º.º )╭∩╮
  47. #897
    Gangreen
    Yes indeed. Looking forward to results. Are those wheels set up tubeless? I'm curious how the Reynolds work -do they hold air and not burp as well as Stans?
  48. #898
    Gangreen
  49. #899
    Quote Originally Posted by nowshon View Post
    The Reynolds I have on there are the older MTN-C Specials that were being sold for $575 on Chainlove about a year ago. They came w/ qr and 15mm qr. But I found that you can get some DMR Revolver endcaps and turn them 20mm.
    The rims are NOT designed to be tubeless...no bead shelf. But I slapped in some Stans rubber strips and they seal up beautifully.
    Now, I'm looking for rear end caps to turn them into 142mm TA...but I don't think they'll go :/
    ╭∩╮( º.º )╭∩╮
  50. #900
    Mar 2011
    Quote Originally Posted by Pau11y View Post
    HTA: 69*
    BB: 13 3/4"
    How did you get 69* with 160mm fox 36 and that shock? Shouldn't it be slacker than spec (68) which is with a shorter fork?
Members who have read this thread: 8
