    Blur 4x linkage issues
    Is anyone having problems with the vpp linkage coming lose on them all the time? I've lock tighted the heck out of it and am now going to probably use nail polish to try and get better hold with those bolts. Any suggestions? SC's torque ratings do not seem to hold the linkage together.
    Also, creaking... i know SC's are infamous for it but any thoughts on minimization, ive heard of waxing the outside of the bearing where it makes contact with the frame to reduce chances just thought id ask about other suggestions. thanks
    Reputation: honourablegeorge's Avatar
    Sounds liek ou might have an anle that's a shade too long for your linkage.
    You'll get info on that and the creak in the VPP Maintenance thread.
    Check the sticky VPP overhaul pictorial on this very same forum.
    Boyeeee
    Reputation: BCBlur's Avatar
    Which links are you running? I ended up replacing my upper Ti links with the solid single upper and replaced the original lower link with the new forged one. Changing out the upper increased stiffness and changing out the lower one should reduce creaking and maintenance. If you're going to do an overhaul, consider making these changes as well.
