Results 1 to 8 of 8
Thread: Black Magic
    Black Dragon
    Guest
    Black Magic
    08 Heckler.
    Reputation: sooner518's Avatar
    is that a metal headbadge on there? or is it a sticker?
    regardless, I love the ano black
    Black Dragon
    Guest
    Quote Originally Posted by sooner518
    Aluminum. SC could have done a better job attaching it to the headtube.
    Reputation: GQOSE's Avatar
    what Ti spring do u have on there?
    Damn, I like the ano black frame.
    Some Assembly Required
    Reputation: man w/ one hand's Avatar
    Quote Originally Posted by Black Dragon
    My Nomad frame is the same way. I was told to take the head badge and heat the adhesive w/a blow dryer and the put it on and tap it w/ a rubber mallet easy and it will stay w/no problems. A bud of mine had this same problem and he says this solution worked good for him as he was told to use this method by SC.
    Oh I meant to mention how cool the rear triangle looks. All sculpted an' stuff....pretty.
    "Why are you willing to take so much & leave others in need...just because you can?"
    Black Dragon
    Guest
    Quote Originally Posted by man w/ one hand
    man w/ one hand,
    Thanks for the info re: attaching the headbadge more securely. I will give it a try. When you mention heating the adhesive, you are referring to the adhesive that is already on the headbadge, and not referring to adding any new adhesive material, correct?
    Thanks again,
    BD
    man w/ one hand,
    Thanks again,
    BD
    Right you are "Black D". This is mine. Gonna be here tomorrow....if'n UPS does their job.
