Results 1 to 10 of 10
    Reputation: Simpledesign's Avatar
    Being one of the lucky ones. (Santa Cruz Grease Gun works)
    Where or what can I use to grease my bike after the original tube runs out? I have the new style with the straight plunger and toothpaste style (?) tube. I would rather not have to buy a new grease gun just because. My google search just comes up with threads about the grease gun not working.
    '12 Trek Marlin Signature Green
    '13 Santa Cruz Tallboy LT Gulf Blue/Orange
    Reputation: expatrider's Avatar
    Feb 2005
    You can buy tubes of the marine grease that came with your gun. That stuff is pretty cheap. Or you could use something like Phils - I use this cartridge Universal Cycles -- Phil Wood Grease - 3 oz. Cartridge
    Re: Being one of the lucky ones. (Santa Cruz Grease Gun works)
    I don't have the cartridge style though....it's the tube style
    Sent from my Samsung Galaxy SIII using Tapatalk 2
    Feb 2005
    Oh I didn't realize there was a different style gun. Why cant you just get a new tube of grease? I think I have a spare grease gun (cartridge style) which you can have for cheap if you want it.
    The only search option I have come up with is buying the new gun from SC which is $23....I guess I'm hitting the hardware store.
    Ninja Master Powers
    Reputation: DWill's Avatar
    Aug 2010
    You got this with your bike from Santa Cruz?
    I have the other one, the "normal" one that came with Nomad C. It works fine, but I'd rather have this one if it works because it so much smaller.
    I wonder though if it will work with my Chris King bottom bracket grease tool?
    007 is offline
    b a n n e d
    Reputation: 007's Avatar
    Jun 2005
    I bet any standard tube of grease will work. Phil's sells a gun just like that: Phil Wood & Co.
    Feb 2006
    Quote Originally Posted by Simpledesign View Post
    This is the new gun they are supplying - cheaper I guess
    And probably not so demanding on the user...............
    Reputation: Lule's Avatar
    How about using SuperLube multi-purpose grease when your tube runs out. The threads are the same so it should screw right on.
    I've used this stuff extensively when doing marine vessel service. It's translucent, doesn't melt or run, won't wash out, contains PFTE, and has a wide temperature range. Very good stuff.
    Since SC doesn't identify what their grease is, I'd fully exchange the lube in the bearings if switching as they may not be compatible.
    bog
    bog is offline
    Phil's is excellent grease and should fit the gun just fine.
    Phil Wood & Co.
    Tallboy3c : Stigmata2 : Hightower LT
  1. The Santa Cruz grease gun
    By happyriding in forum Santa Cruz
    Last Post: 09-04-2014, 07:21 AM
  2. Replies: 14
    Last Post: 03-03-2013, 07:08 AM
  3. Replies: 4
    Last Post: 01-21-2012, 09:04 AM
  4. Replies: 9
    Last Post: 01-16-2012, 02:04 PM
  5. Santa Cruz Bikes Demo - 4/23 Santa Teresa Park
    By bikemerchant in forum California - Norcal
    Last Post: 04-25-2011, 10:02 AM
