Results 1 to 5 of 5
    Reputation: vizsladog's Avatar
    Anybody else think the nickel is very sensitive to rebound in the rear?
    I have the stock float rl and man I've noticed that it likes a lot of sag and very low rebound. Just a click or 2 makes a huge difference.
    I used to run it at 12mm of sag but now have settled on santa Cruz's max recommendation of 15mm.
    Any thoghts?
    Reputation: ATXZJ's Avatar
    Had the same shock on my butcher and it was terrible. I could never get the sag/rebound right for any amount of time. If I set the sag at 15mm, it plowed through travel and bottomed out. Any higher pressure and it would try to buck me off on chattery trails. The rebound seemed to work best around 4 clicks, but who knows.
    If you can get rid of the float and buy a good shock, it will totally change the feel of the bike.
    16 Process 111DL
    15 Process 134DL
    16 Process 153DL
    16 Honzo DL
    16 Private Jake
    17 Hei Hei DLc
    Quote Originally Posted by ATXZJ View Post
    Soundspretty much what happens to me. Sag at 12mmthe and it trys to launch me. I set rebound at 3the clicks and sag at 15mm. It was alot better today. Ill look into a new shock.
    Reputation: jrsbike's Avatar
    I strongly recommend that you take a scenic harbor cruise and when no one is looking throw that shock overboard. Otherwise send it to PUSH. Bluesky Cycling is selling 2011
    Zoke LOs for around $250 which is a geat deal for an excellent shock.
    Quote Originally Posted by jrsbike View Post
    $230. Seriously why did you have to post this? Come on man, killing my wallet!
  1. SC Nickel - Installing Rear Shock
    By bloodninja in forum Santa Cruz
    Last Post: 04-04-2013, 11:18 AM
  2. RIP, No rebound control on Fox rear
    By Miker J in forum Niner Bikes
    Last Post: 05-09-2012, 01:03 PM
  3. Bottoming out the rear shock on SC Nickel
    By Tjay in forum Santa Cruz
    Last Post: 01-03-2012, 10:33 PM
  4. Nickel Rear shock set up
    By simonuk in forum Santa Cruz
    Last Post: 09-07-2011, 02:28 AM
  5. 2010 Fox VAN R position sensitive?
    By morphadron in forum Shocks and Suspension
    Last Post: 03-16-2011, 11:14 AM
