    Reputation: gexas's Avatar
    Any alternatives to the rubber bearing seals for Blur lt2 upper linkage??
    was conducting my annual linkage bearing overhaul and discovered that one of the seals on my upper link was toast. Are there any rubber seal alternatives out there to the SC one's? It looks like you can only get them if you buy the 150 dollar pro pack which i'd like to avoid just for getting a seal.
    all help is most welcome.
    E
    Just contact SC warranty. Its very likley they will sell you just what you need.
    will do. i did last time i needed a seal and they mentioned that they usually want you to get the pro pack. however they did square me away with one. i'll call them today and see what they can do.
    E
    gave them a buzz and they squared me away. my upper link had an abnormal about of wear to the left side of the linkage. i noticed that i had put the bearings in with the blue side out on the left side when you are directed to(in the instructions) to put the black side of the bearing out
    i believe these are angular contact bearings as well and it is very likely that the wear and the mangled seal were a result of the bearings being inserted incorrectly. live and learn as well as a word to future weekend wrenches to avoid doing this.
    E
  1. Linkage/Bearing Maintenance on ASR '09
    By turquoise in forum Yeti
    Last Post: 01-05-2013, 11:25 AM
  2. Replies: 2
    Last Post: 09-25-2012, 12:04 PM
  3. Marine/Boating grease bad on rubber seals, or OK?
    By TheOrangutan in forum General Discussion
    Last Post: 09-12-2012, 09:32 PM
  4. Help! Stuck linkage bearing on a DHR?
    By SummitAP in forum General Discussion
    Last Post: 08-24-2012, 03:54 PM
  5. Linkage/Bearing Squeak on Anthem 29
    By ibrown in forum Giant
    Last Post: 02-14-2012, 09:15 AM
