Results 1 to 16 of 16
    Scant abuse
    Reputation: Richard's Avatar
    Angleset for Tallboy LTc
    What Cane Creek angleset do I need for my Tallboy LTc to slacken it 1.5 degrees? Do you buy a specific angle or is the headset adjustable through the range?
    If you have one are you happy with it?
    Thanks to those who can enlighten me!
    May 2010
    The Cane Creek has some bad reviews so I avoided it and went with the Works 100mm EC44-EC49 1.5 angle set for my large TBLTc. Installation was easy and it has been the best mod I've done. The TBLT should've been spec'd at 68 degrees from the factory imo. 69.5 is too steep for an AM bike.
    Here's a link to the Works headset.
    Works Components 1 5 Degree EC44 -EC49 - Tapered Steerer Tube Headset
    Scant abuse
    Thanks dkestar appreciate it!
    Scant abuse
    Quote Originally Posted by dkestar View Post
    Do I need the reducer option?
    May 2010
    Quote Originally Posted by Richard View Post
    I didn't order it for my TBLTc size large. Not even sure what it is for - maybe if you have a straight 1 1/8 steerer?
    Scant abuse
    Cool thanks again, I also have a large with a tapered steerer!
    Reputation: terrassabike's Avatar
    Feb 2007
    I've installed the WC -1.5 degree EC44-EC49 too. If your Fork is tapered, you don't need the reducer.
    Absolutely amazing upgrade for my TBLTc.The bike was amazing but now it's almost PERFECT!
    Licensed to confuse...
    Scant abuse
    Thanks guys!
    I have ordered one!
    Reputation: OneSlowBusa's Avatar
    Stupid question, but what headtube length set is required - Tallboy LTa Size L frame. Thanks!
    If you Google "Judy Butter" to reminisce on the good ole days, do NOT click on images...
    Those of you who've installed a 1.5* reduction HS...how does your 68* HTA TB LTc ride? Any affects on techy climbs...flopping a lot at low speeds, or the front tire plowing around tight switchbacks? TIA.
    May 2010
    Quote Originally Posted by Pau11y View Post
    I had none of the issues you note. I found the slackened TBLT to be way more fun to ride, less twitchy at speeds and climbing was not negatively impacted. Now before my TBLT my 26er was 68 degrees so maybe getting the TBLT more in line with what I rode for years previous made me more comfortable. In any case at 69.5 I really did not enjoy it, at 68 I am and in the end that is what matters.
    So with my crude math and geometry skills I wanted to see how a 1 degree Angleset (68.5) and a 150mm travel Pike would differ from stock. Assuming:
    Fox 34@140 a2c=553mm
    Pike@140 a2c=551mm
    Pike@150 a2c=561mm
    I get a wheelbase ~15mm or 0.6" longer and almost no difference in height at the handlebars, ~3mm. Any engineers care to confirm?
    So 1 degree slacker and 10mm more travel on the front with a slightly longer wheelbase and no change to the cockpit or bb height. Sounds perfect??? Am I missing something??? Unbalanced ride perhaps???
    Would a TBLTa require a different angle set to the carbon?
    Sent from my GT-I9300T using Tapatalk 4 Beta
    Here is what I did with a Pike 150.
    Burgtec Titanium Offset Shock Hardware | Burgtec
    Slacked it out perfect!!
    Dec 2010
    Quote Originally Posted by OneSlowBusa View Post
    I realize this is an older thread, but have the same question.
    Did you figure it out and did you install a Works headset? If so: which one and do you like it?
    May 2014
    Quote Originally Posted by Mainturion View Post
    You need to select the one that closest covers your head tube length, so for the large frame which has a 100mm HT you'd need Set 2 100-107mm, for the XL frame which has a 110mm HT you'd need Set 3 108-115mm and so on...
    If can't be bothered measuring your Head Tube you'll find the lengths on the Santa Cruz site in the Geo tab and selecting mm as the units in the corner.
  1. Question for Tallboy or Tallboy LT owners
    By rdb in forum Massachusetts
    Last Post: 10-30-2012, 09:12 AM
  2. tallboy LT with angleset?
    By cunningstunts in forum Santa Cruz
    Last Post: 10-07-2012, 10:20 AM
  3. Tallboy al vs Tallboy Carbon vs Jet9 vs epic comp
    By SaxMan2001 in forum 29er Bikes
    Last Post: 08-14-2012, 08:41 PM
  4. AngleSet on a TallBoy
    By pachaven in forum Santa Cruz
    Last Post: 03-16-2011, 05:17 PM
  5. Angleset on Tallboy?
    By mr. welcorn in forum Santa Cruz
    Last Post: 01-12-2011, 02:26 PM
