Results 1 to 8 of 8
    Reputation: BTTR's Avatar
    Jun 2012
    Which angle set headset for a Blur LTc?
    Although i haven't rode my Blur LTc since i got the Nomadc, i'm considering making it a good bit slacker.
    I'm considering getting a Works Components or a Cane Creek headset with an angle set so i can slacker it for 1.5 or even 2.
    The thing is i can't figure out which is the correct headset for my Blur LTc frame with a tapered fork
    Any help is appreciated, thanks.
    Apr 2013
    Zs 44 / ec 49.
    Jun 2012
    Quote Originally Posted by dboneslick View Post
    Zs 44 / ec 49.
    Only problem is that i can't find that combination on the works componets site
    Quote Originally Posted by BTTR View Post
    Their site says "most common sizes". I'd imagine they could put together a zs44/ec49 for you if you emailed or called your order in.
    Jun 2012
    Thanks kan, yeah i tought that too.
    BTW, i had emailed works components about this and just got their reply.
    They say the correct headset for me is EC44 / EC49 ...
    dboneslick, perhaps you forgot my fork is tapered??? (or was it works components fogetting?)
    Apr 2013
    I just built a blur LTc. There is a zs44 / ec49 cane creek 40 headset on it. I ordered it and pressed it myself. Call Santa Cruz if you are worried about it.
    If you buy a normal (straight) headset, then ZS44/EC49 is the correct one. But if you get angleset, then you need EC44/EC49 because the upper cup needs to have space for offset hole in it? At least this is my understanding and this is the case with all the Santa Cruz bikes that use tapered head tube (44mm upper bore and 49mm lower bore) AND tapered fork. Which I think is probably the case with all their new bikes excluding Nomad and V10C which both use straight 49mm head tube. For example the correct Cane Creek Angleset for Nomad is ZS49/EC49 (I use this myself).
    Jun 2012
    Perfect, i think that clears it up.
    Thanks to everyone for the help.
  1. angle set headset for SXT and S-W Enduro
    By ashas in forum Specialized
    Last Post: 08-03-2013, 11:17 PM
  2. Angle Headset on a 303 RDH?
    By gurp in forum Yeti
    Last Post: 12-27-2012, 12:41 PM
  3. El Guapo, which angle headset
    By mnigro in forum Titus
    Last Post: 06-24-2012, 06:05 AM
  4. Which angle-ajustable headset for 6.6
    By StanSuarez in forum Intense
    Last Post: 04-22-2012, 11:45 PM
  5. Angle headset on Trans am?
    By ecibis in forum Transition Bikes
    Last Post: 11-24-2011, 10:28 AM
