Results 1 to 2 of 2
Thread: Air can on BLT
    Reputation: reformed roadie's Avatar
    Air can on BLT
    Any one go from a HV can to a standard air can on the blur LT w/ RP23?
    For my weight - 195-200 w/ gear - it seems like the rear is a bit too linear.
    Any thoughts or experience with this?
    Reputation: dansMTB's Avatar
    You can make simple easy shims and play around with reducing the volume of the hv air cans. This will let you fine tune and see if air reduction helps you out.
    DW 5 Spot RP23 mod
    Good luck
