    07 Superlight Set Up?
    I weigh 185 -190, riding a large SL, What pressure is being run on the rear shock and whats a good Pro pedal Setting?
    Dec 2004
    psi
    I weigh 220 and ran about 155psi in both a Float R and a Swinger 4 way. ('07 SL- east coast slow tight ST). Liked SPV pressure at a minimum in the 4way- frame seems to bob very little and need a little help to be plush.
    My Float is coming back from PUSH monday, so I should learn more next week...
    Reputation: Man-Do's Avatar
    I'm 180 and run it at 140psi. Seems perfect for me. Here are the recommendations though... http://www.santacruzmtb.com/superlig...p?setup=1&x=10
    Tough Guy Extraordinaire
    Reputation: Shmack's Avatar
    I'm 175 and I run 100lbs on a fox rp23 with the propedal set at 2. I tried to run at a higher preasure, but it seemed super harsh. This is my first FS, so I would think that my preference would shift towards being less plush.
