Results 1 to 5 of 5
    Reputation: FrontRanger's Avatar
    '02 Superlight BB question
    Building up a used 02 SL for a friend and am running into a bizare BB/crank issue. SC states that it is a 68X113 BB that is needed. Once installed, however, the LX Hollowtech crank is pulled into the BB shell without ever becoming tight. We put a spacer on the side for now but it pulls the non drive side in just a little too close for comfort. Called LBS and they said yead it needs a 68X121 or 125 spindle length? Doesn't really make any sense. I have never even heard of those spindle lengths. We are using a BB-ES71 68X113 and 03 LX Hollowtech cranks which are definitely a different look than my 02s.
    Any suggestions?
    Do It Yourself
    Reputation: Homebrew's Avatar
    Quote Originally Posted by FrontRanger
    Any suggestions?
    The 03+ LX Hollowtech requires the ES-51 bottom bracket. In order to further differentiate the differences between the levels Shitmano downgraded the bb on LX. The ES-71 is no longer compatable. It's the same spline pattern as the ES-71 but the chainline is different. You will need the 68x121. The good news is the LX is cheaper.
    http://www.jensonusa.com/store/product.aspx?i=BB708B05
    Thanks Homebrew........
    for the info. The BBES51 is offered in lengths from 113-125 according to Shimano's site. SC stated 68X113 the other day. Do you still recommend a 121? Should spindle length vary between a LX and XT BB?(i.e. a XT 113 is shorter than an LX 113)
    Do It Yourself
    You need to use the 121 ES-51 with the M752 LX cranks (fat arms) to get the same chainline as the recommended 113 ES-71 with XT cranks (approximately 48mm).
    Quote Originally Posted by Homebrew
    Thanks again for the info. I will let him know.
  1. Question: BB for 5-spot
    By Acadian in forum Turner
    Last Post: 05-23-2004, 05:39 PM
  2. BB install question
    By jbf in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-04-2004, 07:10 AM
  3. World Class Ti BB install question
    By jbf in forum Weight Weenies
    Last Post: 04-27-2004, 08:10 AM
  4. Shimano ES71 BB on 2000 Superlight?
    By LacticAddict in forum Santa Cruz
    Last Post: 04-11-2004, 06:04 PM
  5. '04 Stumpie BB Question
    By Barley in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2004, 10:41 AM
