    Reputation: Mattyd's Avatar
    Dec 2005
    XX1 Cranks on Spearfish
    Does anyone know, will XX1 cranks work with a Spearfish? Maybe run the GXP with problem solvers? Anyone running these cranks?
    XX1 comes in a narrow and wide Q-factor choice. Narrow is Q156 which Salsa states won't work with the SF frame. So go with the wide (Q168) Q-factor and you should be ok.
    Quote Originally Posted by Mattyd View Post
    The Spearfish has a pf30 bb so you should be able to get the xx1 with a bb30 spindle instead of the gxp version. Problem solvers has adapter cups to be used with shimano hollowtech and fsa cranks, but I don't believe they work with gxp, unless they have changed since I bought them 2 years ago.
    SRAM makes thier own PF30->GXP adapter cups - but my above post was referencing using a BB30 crank (and the PF30 BB)
  1. Truvative XX cranks and Shimano XT cranks- Chainguide?
    By hiawatha-de in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-24-2012, 09:31 AM
  2. XO carbon cranks vs. X9 aluminum cranks
    By thesenator in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-11-2012, 05:50 PM
  3. Spearfish 1 vs. Spearfish 2 frame only
    By Andy13 in forum 29er Bikes
    Last Post: 01-31-2012, 05:57 PM
  4. 2011 Spearfish vs 2012 Spearfish 2
    By J3SSEB in forum Salsa
    Last Post: 01-18-2012, 01:16 PM
  5. Shimano M737 cranks vs M950 cranks!
    By cyberbackpacker in forum Singlespeed
    Last Post: 12-15-2011, 12:23 PM
